Two Emitter Flashlight
37 posts / 0 new
zoulas
zoulas's picture
Last seen: 53 min 49 sec ago
Its interesting how the only valid combinations for number is LED emitters in flashlights is:
1—Most common
3—Used in FW3A and many others
4—Used in every quad (D4, D4S, etc.)
5+ Used in multi LED lights as in MF01, MF01S, etc
The only LED emitter quantity number that really does not work (and I think we all know why) is 2.
flightless22
flightless22's picture
Last seen: 11 hours 23 min ago
If mean that weird Vokka light, yeah.
A better thought out design is Boroiut D25 and WurkoH20, and while it’s technically 4 emitters IF25 works fine with just 2 (tint ramping). I know there’s many others.
jon_slider
jon_slider's picture
Last seen: 6 min 54 sec ago
does not work why?
Here are a few two LED lights I found by searching:
Fenix LD50
Sunwayman D40C
LED Lenser 880095 ×14
KLARUS-XT20
Nitecore TIP SE Dual
Nitecore TIP2
Mecarmy PS14
zoulas
zoulas's picture
I meant a flashlight as in handheld. The headlamp works with two emitters because its always horizontal .
zoulas
zoulas's picture
does not work why?
Fenix LD50
Sunwayman D40C
KLARUS-XT20
Nitecore TIP2
Lumintop made one too, but I have not found it yet.
You are technically correct. The implementation of those lights is weird at best as you are forced to hold the light a certain way.
I think you will agree, probably less than 0.001 of one percent of the lights out there have two emitters. Its a true odd ball.
MascaratumB
MascaratumB's picture
Last seen: 1 hour 6 min ago
I am not sure how they look like, but here are 2 lights with 2 leds each: Mecarmy PS14 and Amutorch AX3
Scallywag
Scallywag's picture
Last seen: 21 hours 15 min ago
There’s always that one weird Amutorch that was available as either two-emitter with reflectors, or a weird quad (spaced wide, and with aspheric lens)
jon_slider
MascaratumB wrote:
Mecarmy PS14
thanks thats the one I was looking for
pic is a link
mecarmy wrote:
Parametrek
Parametrek's picture
Last seen: 2 days 1 hour ago
You must only mean 1 special case of 2 emitters. Do you mean when there are 2 identical side by side emitters? Because there are a whole lot of lights with a pair of different emitters.
1 white and 1 aux color is pretty common. So is 1 flood and 1 throw. Often an emitters points forward while the other is an anglehead so the light can be both. Having a pair of emitters greatly increases the flexibility of the flashlight and it is pretty popular.
Try the largest, fastest, most flexible flashlight search engine: parametrek.com
58 brands, 2773 models and still growing!
NEW: US battery database and European battery database
zoulas
zoulas's picture
I meant primary not aux.
Also most of the lights mentioned are two single emitters in one unit.
goshdogit
goshdogit's picture
Last seen: 9 hours 26 min ago
I had to make this one myself. Party
See where you’re going and where you’ve been—simultaneously! And at the same time!
Yes, it works! The battery carriers are back to back and insulated from each other.
goshdogit
goshdogit's picture
Lupine makes a couple side-by-side models. Hide your wallet.
Lightbringer
Lightbringer's picture
Last seen: 7 hours 15 min ago
Not space-efficient.
1 emitter, you can size the head/reflector up/down as you want.
3, 4, others, you size the head up/down, and stuff the LEDs regularly in a circle.
5 would be wasteful (quincunx shape) unless the center LED’s reflector/lens is reeeeeally small.
2 is by necessity a 2:1 rectangle. If you stick ‘em in a circular head, there’s wasted blank space above/below the side-by-side LEDs.
Unless you want to buy a 2-emitter light at the Darth Mall.
Only reasonable 2-emitter light would be with 2 cells side-by-side as well. And those are all weirdo designs, so it’s not surprising it’s rare.
goshdogit
goshdogit's picture
Lightbringer wrote:
(quincunx shape)
Good points, LB, and you taught me a new word! Smile
zoulas
zoulas's picture
goshdogit wrote:
Lightbringer wrote:
(quincunx shape)
So, from Algebra 101, we can conclude if A=B and B=C then A must equal C no?
Similarly , if LB taught you, then who taught LB? Its a mystery . LOL
If you go back far enough, you will find a caveman holding what seems like a flashlight. On it will read “Ever Light Bringer Edy.”
Yokiamy
Yokiamy's picture
Last seen: 9 hours 22 min ago
exactly
zoulas
zoulas's picture
Yokiamy wrote:
exactly !{width:50%}https://lh3.googleusercontent.com/proxy/STdtLHjJk19ojaEfwJVahHBv8_0lj_Mg...!
That would be two single emitter lights in one.
Lightbringer
In a pinch, I would “palm” a headlamp, so youse can use a D25 like that.
Scallywag
Scallywag's picture
The Darth Mall.
I think that’s your best one yet.
goshdogit
goshdogit's picture
I chuckled, and I don’t even like Star Track.
Lightbringer
Scallywag wrote:
The Darth Mall.
That’s where I got my last light.
Turned it on, almost got a 2nd bellybutton.
Lightbringer
Dr Smith is displeased.
raccoon city
raccoon city's picture
Last seen: 1 hour 43 min ago
dr_spock_nanu_nanu
goshdogit
goshdogit's picture
The guy with the elf ears who flashes gang signs? I thought his name was Dr. Spork.
raccoon city
Dr. Spork with his 1-emitter light that he got at the Darth Mall (in the Star Track Universe.)
sporky
richbuff
Last seen: 6 hours 28 min ago
One of the first pop can flooders, if not the first, the Niwalker MM15 2 x MT-G2, is a two emitter light. I waited until November, 2014 to latch onto it. The review by Selfbuilt mesmerized me for weeks. So many happy memories!
https://budgetlightforum.com/node/31042
Rev 22:15
MascaratumB
ArtieT59
ArtieT59's picture
Last seen: 1 hour 31 min ago
[FLF] Five Light Friday https://budgetlightforum.com/node/78749
Check out some of my new lights (picture heavy) and quick first impressions of them here: https://budgetlightforum.com/node/77180
My Sft40 beamshots / comparison thread: https://budgetlightforum.com/node/78100
max
max's picture
Last seen: 10 min 17 sec ago
That brings back memories indeed!  Still got a couple of these Niwalker MM15s - one from Vinh - and successfully dedomed my first MT-GT leds with this light to give a bit more throw.
 max
Perception
Last seen: 1 week 18 hours ago
That brings back memories indeed!  Still got a couple of these Niwalker MM15s – one from Vinh – and successfully dedomed my first MT-GT leds with this light to give a bit more throw.
Ooh, I hadn’t seen that before but I kind of want one. I love the MTG-2, and two of them must be better than one.
zoulas
zoulas's picture
MascaratumB wrote:
Manker ML03
https://www.aliexpress.com/item/1005001769454212.html
RovyVon E200 series
https://www.rovyvon.com/collections/multifunction-flashlight/products/e200
Again, both are single emitter lights. 2 in 1 lights.
