recommend light: very compact, standard 18650, neutral tint, with TIR lens
39 posts / 0 new
netprince
Last seen: 3 days 1 hour ago
Hey All,
Just spent a bit of time trying to find this light, anyone have any suggestions?
  • very compact (I like the size of the olight s2r)
  • standard 18650 (prefer non-proprietary battery)
  • neutral tint
  • TIR lens
  • prefer no built-in charging due to water proofing, but not a deal killer
Suggestions?
Thanks!
Edited by: netprince on 06/21/2021 - 15:27
Yokiamy
Yokiamy's picture
Last seen: 8 hours 9 min ago
What kind of TIR and what kind of switch?
Maybe an Emisar D4?
Or are you looking into something like a zebralight?
netprince
I would like the TIR to have no flood, so I can point it at the ground and not accidentally blind people nearby.
No strong opinion on the switch.
Emisar might work. Zebralight too if they have the TIR?
Thanks for the reply
Scallywag
Scallywag's picture
Last seen: 23 min 32 sec ago
Compactness and lack of flood don’t go together very well. Generally speaking, the throw of a light depends directly on its diameter.
Do the Olights require a proprietary battery, or will they work with a standard one? I believe the magnetic charging requires the special cells, but last I looked some would still work otherwise without the expensive olight cells.
A good option might be to pick a reflector light and swap in a TIR; Convoy s2+ is popular for this but not super compact.
JaredM
JaredM's picture
Last seen: 5 min 51 sec ago
Lumintop FW1A. This optic might be close to a drop in replacement for the reflector. Have one on order to test.
Edit: If you are more into a side switch, there may be a suitable TIR to swap into a Skilhunt M200.
Also, off the shelf, but not as budget would be some of the EDC line Armytek lights.
Lightbringer
Lightbringer's picture
Last seen: 3 min 38 sec ago
S11C. Cheap enough to buy 5 of ‘em, especially with a code.
LEDLenser-style zoomie, so even “zoomed in” it’ll be a nice even wall of light with negligible spill, ie, no Bat Signal.
Open it up and it’s a nice wide field of light like any other zoomie.
Whoa…
https://sofirnlight.com/s11c-zoomable-flashlight-lh351d-90cri-p0133.html
Screw the code, they’re 10bux(!!!) and that’s with a high-cri ’351 in there.
Like I said, get 5 of ‘em. You’ll thank me later.
Oli
Last seen: 4 hours 42 min ago
I’ll be watching for that result. I’ve got a new fw1a on the way and I assume it’ll have the new reflector and I will not like it. Sst20 4000k banggood
Lightbringer
Wasn’t someone bitching about the ’1A, that there was some fatal flaw it had or something.
One of the reviews here, can’t recall which or whose…
sesgum
sesgum's picture
Last seen: 1 day 6 hours ago
Second on Sofirn s11c. It is really nice for $10. I got one and love it. Have been using it daily for two months and it has very balanced beam in throw mode. The tint is lovely, the UI is near perfect.
Oli
Lightbringer wrote:
Wasn’t someone bitching about the ’1A, that there was some fatal flaw it had or something….
There are limited LED options now and they changed the reflector, apparently less throw. The inner tube contact issues are there and the switch is too sensitive but can be modified. It’s not for everybody but there’s nothing else like it.
Dirty Water Guy
Dirty Water Guy's picture
Last seen: 12 hours 25 min ago
Wasn’t me bitchin but I recall someone saying that the switch can be hard to find (it’s pretty flush with the body + I’ve caught myself trying to use the usb charger cover as the switch.
Minor quibbles actually, it’s a nice EDC for $10 with a quality emitter.
Lightbringer
Naw, might’ve been the Flasholic or someone.
Ach… youse’re gonna make me look for it, eh?
Lightbringer
Unno, maybe it was the FWAA?
https://budgetlightforum.com/node/77621
He was seriously pist at something about the light…
toddcshoe
toddcshoe's picture
Last seen: 2 days 5 hours ago
Nothing better than the DQG Tiny 4 18650. Smallest 18650 light. TIR, great UI, no blinkies,
Banggood had them for about $40ish. Kaidomain still had some last time I checked.
I have heard a few folks complain about a switch problem but, I have more than I should and haven’t had a problem with a single one.
"Everywhere I go, there I am"
Tubercle
Last seen: 2 hours 16 min ago
Whoa…
I second this. Got the S11c a couple weeks ago for $14 and pleasantly surprised by it. Expected to perform like crap but it’s got a nice tinted high CRI beam that’s useful due to the TIR/zoomie nature of it. Magnet at tail end helps w/ work and the usb-c recharging makes it an every day item and a good gift. I bought another few due to how impressive it is and will give them out. Absurdly good light for the price.
pennzy
pennzy's picture
Last seen: 3 hours 55 min ago
I wish Sofirn would up the lumens a little bit on the s11c.
MascaratumB
MascaratumB's picture
Last seen: 4 hours 41 min ago
ArtieT59
ArtieT59's picture
Last seen: 3 hours 38 min ago
Two suggestions both may be too big but fit the bill on almost every other aspect:
  1. Lumintop X1L, the TIR optic, single emitter. Has an osram LED, so not nuetral. That can be changed though if you are so inclined (it has a culnm1, which means a neutral 5000k sst40 should be able to be reflowed right onto the stock mcpcb 4040 size). this has a Simple UI, not Anduril.
  2. Astrolux EA01, has TIR optic, single emitter. This is a 26650 size battery, at approx. 115mm long, and includes a 26350 tube (can run a more common 18350 battery with included sleeve which makes the light 81mm long). Not Huge, but not a S2rII sized light either. Comes in an option with the sst40 5000k though, off the shelf no mod needed. I have one coming in and i am pretty sure i can get the Olight M2r Pro clip to fit it (i just did it with the Emisar D4s). Also, this has Anduril UI.
There are probably better options of there but these two came to mind. of course one needs mods to fit your list and the other is probly to large diameter, but both are nice lights!
[FLF] Five Light Friday https://budgetlightforum.com/node/78749
Check out some of my new lights (picture heavy) and quick first impressions of them here: https://budgetlightforum.com/node/77180
My Sft40 beamshots / comparison thread: https://budgetlightforum.com/node/78100
ArtieT59
ArtieT59's picture
MascaratumB wrote:
YLP Unicorn 1.0 https://ylplight.com/en/katalog/1/ruchnye-fonari/unicorn-10/[/quote]
Oh man, that is a nice looking light. And probably fits the OP's bill PERFECTLY. good call MB!
netprince
Thanks everyone for the responses. I like the size of the UNICORN 1.0, will look into that… thanks
Tubercle
No recharging function, no zooming, and much more expensive than the s11c. Lolz
MascaratumB
You probably missed the requirements from OP, but here’s a reminder:
Quote:
- very compact (I like the size of the olight s2r)
- standard 18650 (prefer non-proprietary battery)
- neutral tint
- TIR lens
- prefer no built-in charging due to water proofing, but not a deal killer
So, netprince:
- doesn’t mention zooming, refers TIR
- prefers a non built-in rechargeable light
- doesn’t mention money
- refers to a compact light (YLP = 102mm; S11C = 113mm; Unicorn 1.0 is heavier though)
And UI is probably better on the YLP !
Lightbringer
The S11C isn’t a regular zoomie with aspheric lens, but a sort of LEDLenser-type zoom, which is kind of a TIR lens that slides up/down instead.
That’s why there’s no Bat Signal, and it doesn’t seem to lose as much output when zoomed.
At both extremes, the beam looks like it’s from a TIR.
Oh, and it’s feather-light. Thinwall tube, feels like most of the weight is from the cell itself.
MascaratumB
Thanks for the input on this, Lightbringer, as I am not completely familiar with the flashlight!! I was watching a video and, indeed, the beam is not similar to a typical zoomie. Thumbs Up
Still, concerning the options presented by the OP, that light doesn’t seem to be the type of “TIR” he’s looking after, specially after mentioning the Olight S2R !
Besides that, it has a charging port and the moving head, which is not the best for waterproofing (as required) Oops
Scallywag
Scallywag's picture
I forgot all about it: the YLP Unicorn fits everything here.
netprince
Thanks for the additional info on the S11C… I will have to take another look at it… How waterproof is its construction?
Lightbringer
Someone asked me about that as far as regular crappy zoomies, so I suggested “Find the focus you want, then rtv it shut.”. LOL
Lightbringer
Wellp, I wouldn’t use it as a diving light, but for rain, water-spray, etc., it’s fine.
def_nvar
Last seen: 6 days 20 hours ago
what about washing the S11C? after I took a light outside, I like to soap and wash it while washing my hands.
can you do that regularly with this light?
my old 3xAAA LEDlenser has a crack in the TIR, which means water would get in when washing, which means I don’t use it that often anymore.
treellama
Last seen: 4 hours 35 min ago
Following Big Smile
Firelight2
Firelight2's picture
Last seen: 31 min 43 sec ago
NO!
The Sofirn S11C is a zoomable light. Most zoomable lights are intentionally not airtight in order to give a smooth zoom and the S11C is no exception.
This is because cycling the light changes the internal volume. If the light is air-tight, air pressure inside and outside the light cannot equalize. Piston action then causes the zoom bezel to return to whatever position it was in when the battery tube was closed and the light sealed.
The S11C has a small plastic press-fit retaining ring which holds in the optic at the bezel. There is no o-ring there. The pill slides in and is held in place by 2 small screws. Also, I don’t recall seeing an o-ring between the pill and the body tube either.
This means that water should be able to leak into the light from both ends of the sliding bezel. It’s probably ok to take out in a light rain, but anything beyond that could cause issues. I wouldn’t recommend washing the light unless you take special care to avoid water entering the light.
