Was looking at the Lumintop B01. Output is only a mere 850lm. Is anyone able to bump that output to 2000lm? Change of pcb or change of LED doesn’t matter. Would love it in WW.
Words can be broken,
so can bones.
so can bones.
I afraid battery is not going to last very long at that brightness.
Just get a normal flashlight with a bike mount, done.
Piercing The Darkness YouTube channel – https://www.youtube.com/c/PiercingTheDarkness
If you want a StVZO compliant light, you are not allowed to modify it. The Lumintop B01 is not certified to be StVZO compliant and cannot be used on public roads in Germany.
Ah, I didn’t realize what “StVZO” was.
I’m sure if you could fit an xhp 70.2 it would bump the lumens nicely:). Sure made a massive difference to an old bike light mod of mine.
Yeah I figured. However, I’m not in Germany nor am I subjected to those laws. I just like the dual profile beam.
so can bones.
Was considering that but I will need modification to the pcb or a pcb replacement.
so can bones.
Not an issue. I always carry multiple spare batteries. I have an MT09R mounted on the bike too…
so can bones.
You asked for a “Stvzo Bike Light” and StVZO stands for the German Straßenverkehrs-Zulassungs-Ordnung which is “Road Traffic Licensing Regulation”.
Ah yes, I guessed my usage of it is wrong. Let me rectify the title.
so can bones.
I used to live in Germany and simply bought a STVZO copliant bicycle light, mounting a flashlight onto the handlebar is equally not permitted because the lacking cut-off and beam wouldn’t be allowed like that. This 2000mAh light shall be legal to use in Germany.
compliant tail light
I’m not in Germany. Just looking for a dual beam type light w high output
so can bones.
Apologies, I forgot to read your location on your profile.
I only read the legal requirement and assumed that you or someone you know needs this in Germany.
Mount 3 of ‘em?
Ain’t kidding… much.
3× the output means more than 3× the heat, and that little beastie likely couldn’t handle it for very long before cooking or stepping down something fierce.
Ive been wondering about making my own as well. Maybe using a C8+ and something like https://www.aliexpress.com/item/32563389630.html?spm=a2g0o.store_pc_grou...
