What is the difference? Convoy M21B with 3V XHP50.2 vs M21B with XHP50.2?
8 posts / 0 new
infinity
I was browsing Simon’s store wanting to pick up a M21B flashlight but I came across two very similar lights and am not sure how they differ.
Links below:-
Convoy M21B with 3V XHP50.2 6500K
Convoy M21B flashlight with XHP50.2 @ 6500K
If both lights are 6500K with an OP reflector, could someone please enlighten me on how they are different, or why if one is better than the other.
Thanks.
ggf31416
Last seen: 7 min 44 sec ago
The second one with 6V XHP50.2 has a boost driver (XHP50.2 are 6V LEDs unless otherwise specified). That means that the runtime will be longer and will heat a bit less than the 3V version(which has a linear driver). The output power looks to be the same (6Ax3V vs 3Ax6V, both equal 18W).
It’s possible that the 6V version may be unable to reach turbo when the battery charge is low, that’s a common issue with boost drivers. At some point the 3V version won’t either, I’m not sure which version will reach that point first.
Overall I think the 6V version would be better.
Bort
Bort's picture
Last seen: 20 min 48 sec ago
If you have test equipment you can buy both and experiment on them Big Smile
The Journal of Alternative Facts TM
"It is critical that there is a credible academic source for the growing and important discipline of alternative facts. This field of study will just keep winning, and we knew that all the best people would want to be on board. There is a real risk in the world today that people might be getting their information about science from actual scientists"
infinity
Thank you.
infinity
No test equipment. Not even sure how to experiment. Complete novice here.
BrassCat
BrassCat's picture
Last seen: 14 hours 23 min ago
Quote:
Infinity wrote: The second one with 6V XHP50.2 has a boost driver (XHP50.2 are 6V LEDs unless otherwise specified). That means that the runtime will be longer and will heat a bit less than the 3V version(which has a linear driver). The output power looks to be the same (6Ax3V vs 3Ax6V, both equal 18W).
It’s possible that the 6V version may be unable to reach turbo when the battery charge is low, that’s a common issue with boost drivers. At some point the 3V version won’t either, I’m not sure which version will reach that point first.”
Probable issue with the step up regulator is minimizing cost of components. Inductor, maybe output capacitor. I may learn something here. At first I thought flashlights were using linear regulators (drivers), but have seen so many comments on PWM drivers. Are both being used; linear and pwm drivers? I guess I should not be surprised.
Stan
BrassCat
max
max's picture
Last seen: 2 hours 51 min ago
The answers given above are correct about the drivers being different. But, let me word this a different way.
The reason for the different drivers is due to the first linked XHP50.2 is a 3V (requires 3 volts only to power it) XHP50.2 LED and Simon only offers it in 6500K.
The second linked XHP50.2 is a 6V LED (requires 6 volts to power) and Simon offers it in 3000k, 4000k, 5000k, and 6500k.
Personally i opted for the 4000k color temp M21B solely based on not wanting the 6500k color temp. It's all a matter of preference, I'm not a color tint snob, it's just that 4000k is much more pleasing to my eyes.  laughing
 max
ggf31416
Most flashlights using 7135 chips like the older Convoy models use the 7135 to obtain the 100% mode current and then use PWM over that current to obtain the lower modes. The disadvantage is that efficiency doesn’t improve when using less than the 100% mode, the advantages are better tint consistency between modes (at low constant current LEDs get greener tint but efficiency improves) and lower cost as 7135s are mass produced parts.
The driver used in the M21B 3V uses a FET to archive linear regulation rather than 7135 chips, like the one from Led4Power, that allows obtaining the lower modes without PWM, but extra voltage is still wasted as heat like in traditional 7135 linear drivers. I wouldn’t call it a FET driver because in this community when we talk about FET drivers we usually mean the simpler, higher output ones, which let pass as much current as possible and obtain the lower modes with PWM over that huge current, resulting in poor efficiency when you don’t need turbo (more than one channel like 1+FET will improve the efficiency of this setup).
