Luminus SFT40 test
283 posts / 0 new
Tom E
Tom E's picture
Last seen: 1 month 3 days ago
ArtieT59 wrote:
I don't own a gt, wish I did though.. someday.
 It's too bad a 5050 mcpcb was never made.. the sft40 would be a GREAT one for it. But the sbt90.2 driver couldn't be used, could it? That's the only 3v driver for the gt right?
Yes, the SBT90.2 driver could be used. Pretty sure it's a standard size driver, same size as the Q8 driver - not certain but think so. I'm really in a good position to try it - got everything needed. Only tricky thing is the 5050 alignment/focus issues.
Tom E
Tom E's picture
Artie T59 - If I build it, will you buy it?
I got a couple 32 mm 5050 MCPCB's that should work fine in this light. The black centering piece just has to be shaved open a bit more. The driver has no FET right now, but will install a good SIRA20DP, running Anduril 2.
Price will be  a good discounted one. Of course if it turns out a bust, don't worry about buying it. I got the modded carriers already.
So, whatd'ya think? cool
Tom E
Tom E's picture
Ok - wasn't as difficult as I thought with the right tool:
Now it's about a perfect 5050 centering piece, better than the stock one was for a 3535. I had 3 XHP35-HI's I swapped out, and 2 of the 3 centering pieces had holes right between 5050 and 3535 - real sloppy for the XHP35-HI's. Might be because they were from the early, early batch.
ArtieT59
ArtieT59's picture
Last seen: 1 day 9 hours ago
OH HELL YA, Definitely Tom! I will PM you!
[FLF] Five Light Friday https://budgetlightforum.com/node/78749
Check out some of my new lights (picture heavy) and quick first impressions of them here: https://budgetlightforum.com/node/77180
My Sft40 beamshots / comparison thread: https://budgetlightforum.com/node/78100
The BLF GT with SFT40 (2300lm, 2700m+ @ 30 seconds!)
https://budgetlightforum.com/node/79561
ArtieT59
ArtieT59's picture
I don't know about going from xhp35 HI to sft40, but xpl-hi to sft40 and even more so CULPM1 to sft40, i notice that the sft40 is larger (especially than other 4040 footprint emitters), and that the centering rings need to be adjusted / made larger to fit the sft40. Sounds like that fact worked out perfectly in this case LOL
djozz
djozz's picture
Last seen: 23 hours 51 min ago
Would 4 or even 8 18650’s in parallel not be too much for the SFT40?
Tom E
Tom E's picture
djozz wrote:
Would 4 or even 8 18650's in parallel not be too much for the SFT40?
Maybe, yes, needs to be checked. I'll probably use 35E's since I got a lot of them, but still from previous testing, the 35E's do almost as good as 30Q's in many cases. Suppose the limit is about 10 amps - don't want to exceed that. Unfortunately, all my carriers are modded for max amps for the SBT90.2's, so maybe need to take off the bypasses, and of course, use thin LED wires. Will have to find a way of measuring the amps from the carrier as well - not sure I've done that before.
Modded carrier, I've posted details before I assume:
ArtieT59
ArtieT59's picture
I have been seeing more and more batteires like this on 18650batterystore recently, Tom.
https://www.18650batterystore.com/collections/bak-18650-batteries/produc...
I wonder if they would help in this situation? a 6amp battery. Also, i believe Samsung has a 5amp 18650 too.
BatteryMooch has been testing BAK by the way -  New Chinese manufacturer that has been testing well in the 1-2 he has done so far!
ArtieT59
ArtieT59's picture
Tom E
Tom E's picture
Half BAK'ed amps, interesting... Yea, they would probably work, as long as the resistance is as high as the rated discharge amps is low. There's even a spec sheet for them.
The 32E would probably be ok as well - I know I got a couple, not sure how many.
fogofwar
fogofwar's picture
Last seen: 1 day 4 hours ago
BAK batteries are very good for the price and usually have more than the rated capacity. I pass by their factory on the way to the beach.
Tom E
Tom E's picture
The 3350 mAh 10A look good for $4, but sold out.
Too bad I can't get a 9-10 amp regulated driver to fit this thing that can run A2.
thefreeman
thefreeman's picture
Last seen: 1 hour 6 min ago
Tom E wrote:
Too bad I can’t get a 9-10 amp regulated driver to fit this thing that can run A2.
Once the attiny1616’s DAC is supported in Anduril2 we can make low components count linear drivers that will be fairly easy to design boards for. Slap in one or two super SO8 FET and a very low resistance current sense resistor for super low dropout voltage (as close to direct drive as possible) if you’re okay giving up some dimming range (which is probably fine on a big thrower like this).
Tom E
Tom E's picture
Wow, that would be great!!
ArtieT59
ArtieT59's picture
I don't even know what you said here, but it's exciting! Lol. And yea I'll sacrifice lower range anyday on a large thrower for regulated top end and no fear of burning out my led.
ArtieT59
ArtieT59's picture
this may be a dumb question- but here it goes. I thought I have seen you "piggyback" a driver before. If I'm not mistaken, you strip away components from the original driver, and then run leads to a new, smaller driver that has the regulation/UI/etc that you need for the light, and solely keep the original driver "shell" / pcb for its size and fitment.
I imagine you need space in the head to do this, but could something like this be done with say the noctigon K1 driver? Or better yet, a kr4 9amp A2 driver? Because it's cheaper to buy. Because that'd be awesome.
JaredM
JaredM's picture
Last seen: 7 months 1 week ago
A 9A K1 driver piggy backed actually sounds like a great idea. Would still recommend low amp cells to keep the heat down since you lose your thermal path doing this
https://fundrazr.com/osturaband
No affiliation, just a fan.
thefreeman
Even then unless you add some thermal compound, maybe silicone potting to increase thermal dissipation to the original driver/host I think the piggybacked linear driver will step down too fast, before the host is hot, depending on the output level.
See this graph with an SST-40 and 50mΩ of non driver stuff (springs, wires, cell), which is kind of a high number for four cells in parallel, even if they really low CDR.
2~3W is a lot for a board without thermal path to the host.
Tom E
Tom E's picture
Hhmm, I got some high amp lights piggybacked. I always run 2-4 jumpers for ground to the piggybacked driver though - I'm thinking it helps, never proven though. Dunno - on some stock drivers, there isn't a whole of contact surface to the shell, so I' not sure the way I piggyback is much worse.
Here's an Amutorch X9, triple XHP50.2 3V hand burner" that I measured 30.7 amps with a GOLISI 26650, about 10,000 lumens at start:
With a couple other hand burners (cool):
thefreeman
Ah yes but with DD FET there is not a lot of heat generated on the driver, just from the FET Rdson, traces, and 7135.
For a linear driver with the DAC, something like this :
Maybe with 0805 instead of 0603, and bigger case for the opamp, since the board is so big Big Smile
Tom E
Tom E's picture
Dang, that's nice!
ArtieT59
ArtieT59's picture
Damn, you guys are good haha. Very interesting stuff! Freeman- did you just design a BLF GT 3 volt board for this ??? Lol.
thefreeman
Yeah, but it didn’t take me too long, I just placed the components quickly, it’s pretty easy since there is a lot of space, I used 46mm but I’m not even sure what the actual size is ?
Something even better would be a buck driver, especially since the original carrier is 4S ? For high efficiency and full current for the whole battery range, but that’s more complicated of course.
Tom E
Tom E's picture
46 mm is about perfect! I measured 45.6 mm for TA's driver for the GT90, and 45.75 mm for the TA MT09R driver and both fit loosely, so 46 mm is actually better.
The GT drivers has a big (wide) brass button while the MT09R driver has a spring. As long as you have a wide enough pad on the spring side, the brass button can be transferred.
thefreeman
I put a 12mm batt+ pad and the GND ring is 4mm wide, are these sizes okay ?
I can put it up on OshPark, though you’ll have to wait for Gchart’s DAC implementation.
Tom E
Tom E's picture
thefreeman wrote:
I put a 12mm batt+ pad and the GND ring is 4mm wide, are these sizes okay ? I can put it up on OshPark, though you’ll have to wait for Gchart’s DAC implementation.
You got the dims exactly matching - the 12 mm batt+ pad and the 4 mm GND ring - matches the TA GT90 driver perfectly. The MT09R driver is also 12 mm batt+ pad and a 3.5 mm GND ring.
JaredM
JaredM's picture
Not to derail this fellas, but just stumbled across this..
https://m.aliexpress.com/item/1005003246180028.html
5050 3.14mm² assuming 2mm Ø “30W”
Tom E
Tom E's picture
Nice it's available in 5000K and with a round surface - would that be like perfect for an aspheric? Hhhmmmmm. $11 qty 2 shipped.
djozz
djozz's picture
Sounds too good to be true, but I bought two. Did you get them as well?
Tom E
Tom E's picture
I ordered 2 bare and 1 mounted on a 20 mm 2 mm copper MCPCB.
