Trustfire MC3 is a magnetic charging tactical flashlight with high performance.It’s has extremely high reliability and operability,up to 2500 lumens,with intelligent temperature control and low voltage warning,have 5 working modes,.powered by a 21700 rechargeable li-ion battery; Adopting magnetic charging technology,IP68 level dustproof and waterproof,can be used in complex and changeable output environment. One-button quick mode switch on the neck,magnetic function on the tail and anti-drop height up to 1 meter,let you use it in outdoor and work environment with confidence.
Trustfire MC3 has extremely high reliability and operability, up to 2500 lumens, with intelligent temperature control and low voltage warning, powered by a 21700 rechargeable lithium ion battery; one-button quick mode switch on the neck, magnetic function on the tail and anti-drop height up to 1 meter, let you use it in outdoor and work environment with confidence. Must buy this.
