FREEME ✌ ASTROLUX WP3 LEP 562lm 2952m 21700 Flashlight Group Buy >>> $179.99 Shipped
303 posts / 0 new
freeme
freeme's picture
Last seen: 2 hours 50 sec ago
ASTROLUX WP3 Group Buy
 LEP 562lm 2952m 21700 Rechargeable Flashlight
For reference, this is my order timeline for our Group Buy.
Note: speed of delivery varies from country to country.
©freemex1thedeals.com
astrolux wp3
Group Buy Price: $179.99 (usual $306.00)
Freeme's Coupon:  Reply on this thread
More Details
Can't wait for our reply??
Special Price: $189.99 (usual $306.00)
Freeme's Coupon:  BGAWP3
Proceed to Store
Description:
Astrolux® WP3 LEP light source has high energy density, and then passes through a special lens reflection system to form a dazzling light column. High and low brightness modes are adjustable, simple and practical. WP3 LEP search light throwing distance up to 2.6 kilometers! , Luminous flux 562 lumens, light intensity reaches 1750000 candela, comes with one 21700 rechargeable lithium ion battery, high-quality drive circuit with temperature control, constant current drive and ensure that the flashlight will not overheat. It is designed for special lighting.
Flashlight Specifications:
NameAstrolux® WP3 2645m Long Shoot LEP Flashlight
MaterialAluminum alloy, black hard anodized surface
Reflective systemAcrylic lens
Light sourceSpecial LEP module, wavelength 450-700nm, lifespan about 10,000 hours
Distance2952 Meters
Intensity2,180,000CD
ModeSingle Click: Low - Medium - High
Triple Click: Strobe
Long Press: OFF
Lumens95lm - 562lm - 562lm
Battery1x 21700 or 1x 26650 li-ion rechargeable battery (21700 Included)
Impact Resistence1.5m
WaterproofIPX6
SwitchBode side, 50,000 press life
Lens Double coated tempered glass lens
WeightAbout 330g (without battery)
Size (±0.5mm)
(head diameter) 59.5mm, (body diameter) 34.5mm, (length) 187mm
Battery Specifications
Item
Astrolux® E2145 21700 Battery
Typical Capacity
4530mAh
Minimum capacity
4500mAh
Nominal voltage
3.7V
End-of-discharge Voltage
3.00 V
Max Discharging Current
28A
Weight
Approx:70±2g
Operating temperature
Charging:0℃~45℃
Discharging:-20℃~60℃
Storage temperature
-5℃~35℃
Storage Humidity
≤75% RH
Size, Diameter22±0.5mm
Size, Length71±0.6mm
Net weight
70±2g
Features:
- High efficiency constant current drive circuit, no noise and no PWM
- Temperature control protection: when the flashlight temperature is too high, the flashlight will automatically reduce the brightness to prevent overheating
- Reverse polarity protection
- Low voltage prompt function
- Battery over discharge protection
Package Included:
1 x Astrolux® WP3 LEP Flashlight
1 x Astrolux® 4500mAh 28A 21700 Battery
2 x Spare waterproof O-rings
1x 21700 to 26650 battery conversion tube
1 x Lanyard
1 x User Manual
1thedeals youtube channel subscribe
1thedeals.comyoutubeAstroluxNealsgadgetsolight
Edited by: freeme on 01/08/2022 - 02:04
freeme
freeme's picture
Reserved.
freeme
freeme's picture
Reserved.
spacemanspliff
interested
TMaxxJJ
Last seen: 16 hours 7 min ago
1.75Mcd – Interested!
freeme
freeme's picture
Hope to bring down the price further. BG will negotiate for a better price this week.
Fingers crossed.
dave1010
dave1010's picture
Last seen: 5 days 18 hours ago
EA02 + LEP = WP3 Smile
If it is an EA02 host, is there any chance of USB-C charging or Anduril too?!
freeme
freeme's picture
Host is total redesigned. USB-C should be possible but Anduril not required.
dave1010 wrote:
EA02 + LEP = WP3 Smile If it is an EA02 host, is there any chance of USB-C charging or Anduril too?!
Th558
Th558's picture
Last seen: 17 hours 9 min ago
Wait..That’s Mateminco? If so, I hope the quality control is good.
Souichirou
Souichirou's picture
Last seen: 6 hours 49 min ago
Very interesting, is it going to be using the newer LEP technology or the original with the mirror ?
freeme
freeme's picture
LumenTodd
Last seen: 8 months 3 weeks ago
Interested
Th558
Th558's picture
freeme wrote:
That’s mirror right?
freeme
freeme's picture
Yes, i will confirm it again for the retail version.
Th558 wrote:
freeme wrote:
That's mirror right?
dave1010
dave1010's picture
Although the beam looks a bit better with the newer style (shine through?), mirror ones seem to perform better.
Both Jetbeam and Maxtoch have switched from mirror to shine through, resulting in lower specs. M1X WP-RX —> RRT M1X and L2K —> L3K. Only 2 examples there but it’s a start of a pattern.
Th558
Th558's picture
I wonder why they’re doing this. Maybe it’s easier/cheaper to manufacture? Jetbeam did drop their prices a bit but Maxtoch didn’t. I also noticed that the L3K is out of stock. Wonder if they’ve stopped selling it or if they’ll release an improved version..or maybe…it’s just out of stock.
freeme
freeme's picture
 Product listed.
freeme
freeme's picture
$169.99 offer valid till Jul 31, 2021.
Price will increase by 10-15% higher from Aug.
Fingers crossed.
Souichirou
I’m guessing its to obscure the laser class restrictions in some countries since its completely enclosed it wouldn’t be rejected/returned upon entry into the country.
freeme
freeme's picture
Olight did mention that LEP with white beam is not allowed in US for regular consumers (pls verify).That is why Odin Turbo is in yellowish green tint.
Th558
Th558's picture
Would the 26350 EA01 tube work on this?
freeme
freeme's picture
Edited: Both 26350 short tube and 26800 tube are compatible with WP3. cool
Th558
Th558's picture
I wonder why there are no 70mm LEPs. All of them seem to be 60mm and under (apart from the $1000+ ones). Maybe they can’t find the right size lens?
freeme
freeme's picture
Due to law of diminishing returns?
Th558 wrote:
I wonder why there are no 70mm LEPs. All of them seem to be 60mm and under (apart from the $1000+ ones). Maybe they can't find the right size lens?
tascagdas
Last seen: 4 days 4 hours ago
im interested. but will purchase after july 24
Kvisten
I’m interested. Any other coupons than bgawp3?
freeme
freeme's picture
Sure, do set an alarm just in case you forgotten about. wink
Shared!
Kvisten wrote:
I'm interested. Any other coupons than bgawp3?
Minwol
Last seen: 8 hours 54 min ago
interested, same size as ea02?
djozz
djozz's picture
Last seen: 5 hours 26 min ago
In order to properly image the tiny light source, the lens must be high quality, much better than your average classic aspheric lens. Tbis quality condition increases even more when going bigger to make a smaller projection. This is getting really expensive, and this is on top of the question how useful a smaller and smaller hotspot of that same limited 500 lumen output remains.
ACP68
Last seen: 22 hours 2 min ago
Interested, will be my first LEP.
freeme
freeme's picture
Shared.
