ASTROLUX WP3 Group Buy
LEP 562lm 2952m 21700 Rechargeable Flashlight
For reference, this is my order timeline for our Group Buy.
Note: speed of delivery varies from country to country.
Group Buy Price: $179.99 (usual $306.00)
Freeme's Coupon: Reply on this thread
Can't wait for our reply??
Special Price: $189.99 (usual $306.00)
Freeme's Coupon: BGAWP3
Description:
Astrolux® WP3 LEP light source has high energy density, and then passes through a special lens reflection system to form a dazzling light column. High and low brightness modes are adjustable, simple and practical. WP3 LEP search light throwing distance up to 2.6 kilometers! , Luminous flux 562 lumens, light intensity reaches 1750000 candela, comes with one 21700 rechargeable lithium ion battery, high-quality drive circuit with temperature control, constant current drive and ensure that the flashlight will not overheat. It is designed for special lighting.
Flashlight Specifications:
Name | Astrolux® WP3 2645m Long Shoot LEP Flashlight |
Material | Aluminum alloy, black hard anodized surface |
Reflective system | Acrylic lens |
Light source | Special LEP module, wavelength 450-700nm, lifespan about 10,000 hours |
Distance | 2952 Meters |
Intensity | 2,180,000CD |
Mode | Single Click: Low - Medium - High Triple Click: Strobe Long Press: OFF |
Lumens | 95lm - 562lm - 562lm |
Battery | 1x 21700 or 1x 26650 li-ion rechargeable battery (21700 Included) |
Impact Resistence | 1.5m |
Waterproof | IPX6 |
Switch | Bode side, 50,000 press life |
Lens | Double coated tempered glass lens |
Weight | About 330g (without battery) |
Size (±0.5mm) | (head diameter) 59.5mm, (body diameter) 34.5mm, (length) 187mm |
Battery Specifications
Item |
Astrolux® E2145 21700 Battery |
Typical Capacity |
4530mAh |
Minimum capacity |
4500mAh |
Nominal voltage |
3.7V |
End-of-discharge Voltage |
3.00 V |
Max Discharging Current |
28A |
Weight |
Approx:70±2g |
Operating temperature |
Charging:0℃~45℃ Discharging:-20℃~60℃ |
Storage temperature |
-5℃~35℃ |
Storage Humidity |
≤75% RH |
Size, Diameter | 22±0.5mm |
Size, Length | 71±0.6mm |
Net weight | 70±2g |
Features:
- High efficiency constant current drive circuit, no noise and no PWM
- Temperature control protection: when the flashlight temperature is too high, the flashlight will automatically reduce the brightness to prevent overheating
- Reverse polarity protection
- Low voltage prompt function
- Battery over discharge protection
Package Included:
1 x Astrolux® WP3 LEP Flashlight
1 x Astrolux® 4500mAh 28A 21700 Battery
2 x Spare waterproof O-rings
1x 21700 to 26650 battery conversion tube
1 x Lanyard
1 x User Manual
