Updated:
The color rendering index (CRI) of a flashlight is the measure of the light’s ability to reveal an object’s true colors, or rather what a user would see when using a natural light source. If you are a Photographer, Mechanic, an EMT, or someone who’s job requires the ability to see “real” colors, having a light source with a high CRI rating is vital to your success.
Acebeam just released the X50 high CRI95 Flashight with 20,000Lumens output, 1.8 hours fast charge, and can be used as a power bank. It is the best to incorporate the X50 High CRI95 flashlight into your tool box.
Learn more: https://www.acebeam.com/x50-photographic-lighting
___________________________________________________________________________________________________________________________________________________________________________________________________
The Acebeam X50 has set the new standards for search lights. This X50 is powered by the customized Li-ion battery pack,which is built-in intelligent adaptive charging with USB Type-C charging port you can fast and full charge the Acebeam X50 in 1.8 hours and discharging function as a power bank with a max power of 36W and protocols of QC3.0 & PD3.0. The X50 is capable of producing 40,000lumens and a maximum beam visibility of 800meters (2625 feet). Added features include a standard tripod socket, single stainless steel switch activation, and mechanical safe lock function. The beam angle is up to 120 degrees, if you need to search a large area ,farm or warehouse, you can hold the torch in your hand with the ergonomically designed handle. This highly recommended Acebeam X50 multipurpose handheld searchlight is perfect for security guards, farmers, and search and rescue teams.
Learn more: NEW!! ACEBEAM X50 MULTIPURPOSE HANDHELD SEARCHLIGHT
Exclusive Coupon to BLF members: BLF10
sales@acebeam.com
ACEBEAM ► https://www.acebeam.com
FB ► https://www.facebook.com/AcebeamWorld
FB Group ► https://www.facebook.com/groups/acebeam
Ins ► https://www.instagram.com/acebeamofficial
YTB ► https://www.youtube.com/c/ACEBEAM/featured
Tiktok ► AcebeamFlashlights
Official Amazon.US ► https://www.amazon.com/acebeam
Official Amazon.UK ► https://www.amazon.co.uk/acebeam
Official Amazon.JP ► https://www.amazon.co.jp/acebeam
Official Amazon.DE ► https://www.amazon.de/acebeam
Official Aliexpress ► https://www.aliexpress.com/store/5879734
Each XHP-70.2 chip puts out 5000 lumens?
And the battery pack has the output of 2.5 5000mAh 21700s?
The battery voltage is strange, 3S li ion would be 11.1V and not 10.8V
The Journal of Alternative Facts™
"It is critical that there is a credible academic source for the growing and important discipline of Alternative Facts. This field of study will just keep winning, and we knew that all the best people would want to be on board. There is a real risk in the world today that people might be getting their information about science from actual scientists."
Utilizes 8 x CREE XHP70.2 LEDs with a max output of 40,000lumens
Maximum beam intensity of 160,000 and maximum throw of 800 meters
sales@acebeam.com
I like this configuration. I think this is going to be my seventh Acebeam light. I look forward to seeing a size comparison picture. This light will go very nicely with my Acebeam X45 that I have used regularly for more than a few years. I like large dedicated throwers, large power throwers, and large flooders, and the same in medium and small sizes too.
I like to charge the cells on an external charger and look at the amps and volts and I know that I can try different cells, and all that good stuff, and I do with that with most of my flashlights. Sometimes I am in the mood to just plug and chug, and not mess with the cells, and I’ve got a few high powered flashlights where I don’t have to worry about the spring loosing its temper and having a poor connection, because the connections are factory soldered.
Rev 22:15
3.6V in series is 10.8V.
I like this..but I’m questioning whether or not that 800m rating is accurate. 5000mah cells would’ve been better but I guess the 50S just doesn’t wanna be in stock. Also, considering that the XHP70.3 is almost out it doesn’t make sense for one to spend so much on a flashlight only to have it be outdated in a couple months.
Edit: Holy crap I just looked at the weight. 690g without batteries
Looks like it won’t be going in any pockets. I think the weight just defeats the purpose of making it compact. Might as well make it bigger or add another cell if it’s going to be that heavy.
It has 8-Cree XHP-70.2’s, 3-5000mah cells can’t push that current load. Molicel INR21700-P42A 4200mAh and it’s 40-45 amp rated. Molicel also list its nominal voltage as 3.6v hence maybe the 10.8v listing. Playing with the Cree Tools it’s going to take 20 amps at 12.2 volts just to get 35,000 lumens with the highest bin. Good electronics and Acebeam can probably do it, but not for long. You’re looking at probably close to 300 watts that’s what 690 grams of mass is helping with. But I’m guessing with this flashlights mass it’ll probably settle down to about 6,000 lumens after the thermal sensor does it’s job.
The problem with these throw rating is that they’re measured at peak output. Once the temp regulation kicks in it will stay in Med2, 6,500lm 30,625cd 350 meters, as seen in the runtime figures.
USB power meter/tester thread
Love Acebeam, but this will probably be $350. I doubt 800 m out of the small reflector xhp70.2. Might meet the lumen rating, but for maybe 1-2 seconds?
That handle is not very attractive.
Just take for example the Lumintop BLF GT4 with four cree XHP70.2 that makes over 30 000 lumens output. https://youtu.be/tM9XL4rRw2A
But yeah it is a heavy flashlight.
Hardusvd70
3х21700? 4x21700 would be better. flashlight is already quite large, mak8ng it little bit large should seriously improve runtime in higher modes
i really like acebeam stuff, really. but 40000 in such size rise question of photoblitz turbo
Updated list of Aliexpress coupons and promocodes | How to choose flashlight, Main things in simple words
Acebeam X50
Hardusvd70
Hardusvd70
Acebeam X80-GT
Acebeam X50
https://m.bilibili.com/video/BV1n44y127nG
https://youtu.be/E1GhNT3VFtU
Hardusvd70
how long turbo last ?
...where Frugal meets with Flashlight!
つ ◕_◕ ༽つ
Step down to lower output after 1 minute.
Hardusvd70
Hardusvd70
X45
MS06
X80-GT
X50
Hardusvd70
With 4 cells they could’ve also went with 5000mah cells making the capacity even higher(12750mah vs 20000mah). Even with the same 4250mah cells it would’ve still made much more sense.
Thank you for the size comparison pics and for the beam shots. I am happy that it has normal modes for normal heat generation and normal run time. But what I’m really excited about is a few seconds of lighting up a large area very bright, and then throttling down to focus on smaller area closer up.
Rev 22:15
Can you choose a warmer tiny or are you stuck with super cool white? Interesting light, imagine it gets warm pretty quick on 40K lumens.
CR888
Wouldn’t be surprised if it lasts almost a minute on turbo. It has a lot of thermal mass and a handle so it can reach higher temperatures without burning your hand.
It looks like 6500k and 5000k are available.
Can you take a photo next to MS06 please?
Images were shared user in China flashlight forum.
Acebeam X45
Imalent MS06
Acebeam X80-GT
Acebeam X50
Hardusvd70
So the 690g is with cells then?
Judging by those photos above, the throw to be somewhere in line with the X45 (maybe slightly less) so yh that 800m rating seems off. Even if it manages about 650m that’s still be good for such a powerful light of this size.
May be more in the range of 600 meters depending on the real lumens output if it is close to the advertised 40 000 lumens. I doubt the 800 meter range. Imalent DX80 measured just over 700 meter with a 92 mm head and around 29000 lumens. X50 has got a 75 mm head.
Hardusvd70
crap, 40,000 lumens? You will soon need a permit to buy something like this.
