Beware of Neil's LEP
28 posts / 0 new
Lightenzaza
Last seen: 1 hour 46 min ago
Got it in march with a shockli . Was kept with it’s battery and used maybe once per two weeks . Meanwhile i bought 2 vapcell g53 and installed one in it . Mid june i tried to use it and the battery was at 1.6 ( dead ) . I figured that i got a bad batch of g53, since vapcell was having issues . The vapcell charger ended up repairing the cell . I reinstalled the shockli . I remember putting it in and remembering the charge indicator ( 69% ) . Tested it a couple times still at 69% . Tonight it did the trick again ; battery at 1.6 . It took at lot of trials to have my charger operating the repair ( discharge-repair-discharge ..) ; last time it took 23 hours to repair . Two different batteries having this issue points me to a lep problem . Don’t leave the battery in .
Caught a sickness . I found out i'm not alone .
p12gt, tn12v4, s1, tk15, s2+, pd35tac, fd65, tk35 ue 2018, d4v2, kr4, kr1vn, d4sv2, fw3a, sp31v2.0, sp32av2.0, sp36, sp40, lt1, sp31uv, sc31pro, e07x, tk18
Souichirou
Souichirou's picture
Last seen: 21 min 41 sec ago
It might be just your light, I’ve had mine from Neal’s first batch pre-order and used it for testing and etc with occasional use but mostly sitting with a Shockli 26650 for months without issue.
Oli
Last seen: 4 hours 25 min ago
There may well be an issue with the light. However, people really should be loosening the tail caps of almost any light that has a lithium ion battery in it when they’re not in normal use.
stephenk
stephenk's picture
Last seen: 28 min 32 sec ago
Maybe change the title to “beware of users who don’t lock out their lights”?
ShyOne
ShyOne's picture
Last seen: 7 min 36 sec ago
Agreed, the title of this thread is indeed a bit harsh. Sad
Yokiamy
Yokiamy's picture
Last seen: 5 hours 55 min ago
It still might be a bad cell, Vapcell arent the most reliable cells
djozz
djozz's picture
Last seen: 8 hours 22 min ago
Thanks for the warning.
I have a Shockli 5500mAh in my “Neals” LEP and have not used it for 2 months (not locked out), it is now 3.85V but I’m not sure that it was full when I stopped using it. I’m now charging it up and will put it back when full. Let’s see what the voltage is two months from now.
Cochise334ever
Cochise334ever's picture
Last seen: 15 hours 32 min ago
A lot if people will understand this and Agree.I would guess the minority will not…based on the threads Negative experiences with Neil and Positive.experiences with Neil.
The thread should be titled: Beware of Neil!
I won’t get into my negative experiences which were enough to terminate.my business with him…I am not alone. Wink
Edit: OP…Good luck getting a refund and even a response from him.
ShyOne
ShyOne's picture
Facepalm ^^
Facepalm Facepalm ^^^^
Facepalm Facepalm Facepalm Facepalm ^^^^^^^^
Lightenzaza
Not even thinking about it !
Lightenzaza
It did the same with my shockli .
Lightenzaza
Guilty as charged . I have more than 20 lights unlocked and ready at home .
Souichirou
Yet you clearly have a vendetta or axe to grind with neal, But you neglect to do any research on this light specifically as Vinh from skylumen sold the same light with the same UI etc as the only difference from the original batch between Neal’s and Vinh’s was the “Skylumen” engraved on the tail cap.
BurningPlayd0h
BurningPlayd0h's picture
Last seen: 2 days 2 hours ago
You can measure parasitic drain with a multimeter if you have one. Use a sensitive current setting and place one probe on the negative end of the battery while it’s in the light with the tail cap removed, the other probe on the exposed metal of the battery tube at the tail.
CR888
Last seen: 5 hours 28 min ago
I hate parasitic drain…it’s completely fine in some lights is very minimal, others it’ll drain cells. I twist tail caps to prevent it, but good advice above. Knowing the drain data helps a lot.
CR888
BurningPlayd0h
Yep, whenever I get a new e-switch light I’ll sort of take it on a “test run” and check the battery after a day or two while not using it.
djozz
djozz's picture
I was planning to see how my Shockly battery drains over time in this light, but BurningPlayd0h is right, I may as well measure it:
My copy of “Neals” LEP thrower measures 73 microamps parasitic drain, my battery will drain in 8 years.
So something is different with the copy of the OP
Lightenzaza
My flashlight craziness is too recent for me to be equiped, but i’m starting to feel an itch .
Lightenzaza
Agreed, it was used maybe a week ago and it was still at 69% . It’s like a very rapid drain .
BurningPlayd0h
Regardless of owning flashlights, they’re genuinely a great tool to have around the house!
Lightenzaza
My brother was my goto for electric stuff, so it kept me lazy in that subject . What multimeter do you have ?
Henk4U2
Henk4U2's picture
Last seen: 7 hours 8 min ago
Well I’m happy to see that your objectivity isn’t clouded by your emotions.
History repeats itself: Ceterum autem censeo Carthaginem esse delendam,
You are a flashaholic if you are forced to come out of the closet, to make room for more flashlights.
BurningPlayd0h
Just a cheapo one from Amazon right now, but it’s seemed to do the job for my very non-critical use case. There must be some options between that and Fluke or other high-end ones but I couldn’t tell you what brands are good choices.
sleasys14
Last seen: 1 hour 45 min ago
I have one and have no issues but I loosen the tail.
Photon Master
Last seen: 2 days 8 hours ago
I bought two of the new Lumintop LEPs from Neal and they’re outstanding
Lightenzaza
Please note that my advice is only related to Neil’s unbranded LEP . It is in no way a jugment on other offerings .
TrustFire2021
TrustFire2021's picture
Last seen: 1 hour 3 min ago
hello,
TrustFire T30R use of LEP light source,issued 460Lumen,has a longest beam range of 1100 meters and LED spectrum similar to the broad spectrum of white light,not only to retain the high collimation characteristics of the
laserm,but also to eliminate the harm of monochrome laser,safe and reliable.
More Details: https://ebay.to/2TojyE6
Photon Master
Ah nice… thanks for the warning!
