Troubleshooting Nitecore MH25S
22 posts / 0 new
Renato Azevedo
Last seen: 17 hours 46 min ago
Hi guys I have good and bad news
Good: I just received my brand new Nitecore MH25S
Bad: it’s misbehaving
Both in daily and tactical mode it doesn’t do anything when the back button is pressed. It only kinda works if I press both the back and then the mode button, then I can cicle trough the modes, but tactical mode is the worst, momentary illumination doesn’t work, half pressing should give momentary on but nothing happens, doing the same routine of fully pressing the back button and then the mode button it turns on in low mode but tactical should turn on in turbo or strobe.
What I tried and didn’t work:
Fully charging the battery
Checked the plate inside the tailcap but it wasn’t loose.
Tried changing between daily and tactical modes
I didn’t remove the head because from what I know it is glued, and I don’t want to disassemble it because I may have to use the warranty.
I have a MH12S and the tailcap is the same so I tried changing the tailcap and it didn’t work
Could anyone help ?
Edited by: Renato Azevedo on 07/16/2021 - 23:20
Lightbringer
Lightbringer's picture
Last seen: 34 min 2 sec ago
Dual-tube design, right? Edges might need to be cleaned.
Renato Azevedo
Thank you Lightbringer for answering, could you help me understand that?
Sorry, I’m new to the forum, previously I didn’t do any maintenance on flashlights so I’m not familiar with the terms. Could you talk to me as a dumb newbie? What edge could be the problem and how should I clean it?
Also I’m not sure how to check if it is dual tube, do you mean there’s a double wall in the tube? Like an inner and outer tubes ? From the back without the tailcap the tube seems to have only one wall, I can’t find any visible dirt or debris. I’ll try to learn how to post pictures so I can send anything that could help.
Sorry to bother you
Funtastic
Funtastic's picture
Last seen: 4 hours 27 min ago
Clean the edge of both ends of the battery tube, the place where there’s no black anodizing. Could be a poor connection, if not that then I suggest sending it back
Texas Ace Lumen Tube calibrated with maukka lights
New Zealand store – https://www.piercingthedarkness.co.nz (NZ customers only)
YouTube channel – https://www.youtube.com/channel/UCIUWi2vYp4CWrRkOJM70t_w/videos (Demos for my customers, and reviews)
Lightbringer
No bother. There might be a sleeve which fits inside the battery tube that carries the signals from the tailcap (vs the body itself which carries the main current).
They gotta be clean to give good contact on both ends.
Ain’t got the light, so am only guessing if it’s a dual-tube design.
Scotty321
Last seen: 1 week 1 day ago
What battery are you using?
Renato Azevedo
I cleaned the back end of the tube with isopropyl alcohol, no effect, the front end of the tube is glued to the head so I don’t want to dismantle in case I need to send it back.
Thank you Funtastic
Renato Azevedo
Thank you Lightbringer for explaining, I get it now, unfortunately cleaning didn’t help but it was a great tip
Renato Azevedo
I’m using the battery it came with in the box Nitecore NL2150
Thanks for your help
Renato Azevedo
Renato Azevedo
I didn’t realize until now (because I don’t use it much) but the strobe, beacon and SOS modes don’t work.
According to the manual they should work by long pressing the mode button when the light is on.
Don’t now if it helps diagnosing the flaw but, I thought I should mention it.
Lightbringer
Just goggled it, seems the mode button is on the side, not a 2-switch tailcap, so likely no dual-tube design.
Sounds like it might be the switch or the driver. Whenever a light goes mental, I always blame the driver, which is most likely, but no momentary points to the switch.
In short, no idea.
Scotty321
I’ve accumulated three of the newer “i” lights (have two older models too) and the only issue I’ve had was with the older model that’s been in my messenger bag for years that I had to clean the contacts off with. Maybe shine a light down into the tube and see if the contacts for the positive side has any smudges on them. You can dip a Q-tip (or something similar) in alcohol and try to clean it.
If you purchased this from a reputable seller, I might suggest contacting them seeing if you can get a replacement. Hopefully the shipping isn’t too much. Hopefully this is just a rare lemon and you can get up and running soon.
Renato Azevedo
In short, no idea.
Thanks for all the effort Lightbringer
Renato Azevedo
Hey Scotty, thank you for your input
I have looked inside, all looks clean but I tried using isopropyl alcohol with a cotton tip to clean it anyway, unfortunately no luck
I have bought a few Nitecores recently, P30i, MH12S, P20iX and this MH25S, only the MH25S had been giving me headaches so far
I believe it’s an isolated case
I’ve bought from Nitecore’s official AliExpress store, so I’m waiting for their response.
Thanks for all the help
Rusty Joe
Rusty Joe's picture
Last seen: 3 hours 2 min ago
My flashing blue battery indicator button quit woriking just the other day.
Renato Azevedo
Hey guys thanks for all the help, just an update, I had bougth the MH25S from the Nitecore official store on AliExpress, they offered a partial refund, after some negotiation I bought a P20iX (I was going to buy anyway) and they agreed to send a working MH25S in the same parcel. When they arrive I’ll update this thread. Big Smile
Renato Azevedo
Was it a MH25S?
Renato Azevedo
Update: unfortunately Nitecore didn’t send the replacement with the new order, they said it was a mistake. I’m forced to open a dispute in AliExpress before the time to dispute runs out.
Very sad to see this happening as I’m a big fan of the brand
lfb
Last seen: 14 hours 41 min ago
Hi Renato. It’s bad when that happens, but fortunately, you had bought it from AliExpress, so they will send a new light or your money back.
Glad to see another Brazilian guy here Smile
Renato Azevedo
Obrigado lfb
Recently it has come to my attention some strategies a few sellers use.
When you have a problem even AliExpress gives you instructions to first try to solve between you and the seller but the seller keeps stalling until the time to open a dispute runs out (usually 15 days after receiving the product). They keep you negotiating and make promises but unfortunately something always goes wrong. For example they agree to send a replacement with your next order but the item you want is out of stock (even if it appears available for order in their store) A few days later they say it’s back in stock so you make another purchase from them with the written promise to send the replacement with the new order, then out of the blue someone bought all the units of the item you ordered and they have to delay the shipping, a few days go by and the shipping is placed but unfortunately someone else in the company forgot to send the replacement with the new order, another day, they ask you to make another purchase of the product you need replaced but don’t pay so they can alter the price to 1 cent (this is where I was when my suspicion became too much and I opened the dispute)
After reading about this subject I came by a few testimonials of people that lost their money.
One of them made the purchase of 1 cent thinking they would receive the replacement but it never came so they opened a dispute (for the 1 cent order since the previous had expired time to dispute) and the seller settled and gave 1 cent back, nothing else.
The other had opened the dispute but the seller begged him to close the dispute for (product not as described)
and open with another (saying it would be less damaging for him). After that the seller did everything in his way to not pay and the buyer couldn’t prove the new dispute because it had the wrong reasoning and he already had closed the right one.
There are a lot more…
Well not everyone is like that. I had a wonderful customer service with Simon mao from Convoy, don’t get me wrong Convoy is not perfect, but he always answered my messages and really went out of his way to help.
PS. I’m still waiting for him to have some time to tell me the story of how he started Convoy. Great guy
Hope this helps someone else
lfb
Renato Azevedo wrote:
Obrigado lfb
Yes, would only trust on few reputable sellers, like Simon. Other than that, it’s better to place a dispute, just in case.
PS. I have PM to talk about flashlights, if you don’t mind.
