WUBEN D1 Super Flood Light
3 posts / 0 new
WubenLight
WubenLight's picture
Last seen: 1 week 2 days ago
WUBEN D1 175 Degrees Super Flood Light
Now use code: NEW20 to enjoy a 20% discount !!!
[Super Flood] A multiangular reflectance lens combined with a high beam and dipped beam.
[High Power] 1100 lumens maximum output and 130 meters beam distance.
[Wide Angle] Wide beam provides 175 degrees super floodlight.
[Power Bank] Charging by Type-C port on a 18650 battery, plus power bank function.
[Super Portable] Dual-way clip, weighs only 109g (battery included), 4.13in x 0.93in.
Don't miss it, shop 20% OFF now!!!
https://www.wubenlight.com/collections/new-products
g_damian
g_damian's picture
Last seen: 3 hours 39 min ago
What’s the UI?
What’s the LED installed?
Is the bezel glued? Is anything glued?
MascaratumB
MascaratumB's picture
Last seen: 1 hour 9 min ago
g_damian wrote:
What’s the UI? What’s the LED installed? Is the bezel glued? Is anything glued?
If this can help: https://budgetlightforum.com/node/77134
LED is eventually Osram P9 or P9, cool white (similar to the H3 headlamp).
The bezel, if not glued it is pressed really hard. I couldn’t get mine off so far.
As for the UI:
Quote:
From OFF
*Press & hold – enters Low
*1 click – turns ON
*2 clicks – enters Stobe
- a) another 2 clicks enters SOS; another 2 clicks enters Strobe; …
*3 clicks – activates/deactivates the W switch LED indicator
*4 clicks – locks/unlocks the flashlight:
- a) while locking the light blinks 3 times
- b) after unlocking, the light turns ON in Moon level
- c) if the switch is pressed while locked, the switch will blink 3 times
From ON
*Press & hold – advances in the sequence Moon > L > M > H > Moon >…
*1 click – turns OFF
*2 clicks (if in Moon, Low or Medium) – enters High
- a) when in High, 1 click turns OFF
- b) when in High, 2 clicks enters Strobe
*2 clicks (if in High) – enters Strobe
- a) another 2 clicks enters SOS; another 2 clicks enters Strobe; ….
- b) when in Strobe or SOS, 1 click enters High
NOTE: if the power is disconnected physically while the flashlight is locked, when reconnecting power, the lock-out will be lost.
I did some other considerations on that thead I linked, and there are some other reviews on BLF.
