Test/review of Vapcell INR18650 3000mAh V2.0 (Purple) 2021
4 posts / 0 new
HKJ
HKJ's picture
Last seen: 2 weeks 5 days ago
DSC_4486
Official specifications:
  • Model: V2.0 INR18650 3000mah 20A
  • Size: 18.3*64.9mm
  • Typical Capacity: 3000mAh (0.2C discharge)
  • Min capacity: 2900mAh (0.2C discharge)
  • Nominal voltage: 3.60V
  • Max Continuous Discharge Current: 20A
  • End-of-charge voltage: 4.20V
  • End-of-discharge Voltage: 2.5V
  • Weight: 48g
  • Internal resistance: 12mOhm
  • Standard Charge: 1500mA,CCCV 100mA cut-off
  • Quick Charge Current: 4000mA
Vapcell%20INR18650%203000mAh%20V2.0%20(Purple)%202021-info
A unprotected 3000mAh 18650 with fairly high current.
DSC_4484 DSC_4485
DSC_4487 DSC_4488
DSC_4489
DSC_4490
DSC_4491
Vapcell%20INR18650%203000mAh%20V2.0%20(Purple)%202021-Capacity
The two cells tracks nicely and capacity do not vary much with load.
Vapcell%20INR18650%203000mAh%20V2.0%20(Purple)%202021-Temp-10.0
Vapcell%20INR18650%203000mAh%20V2.0%20(Purple)%202021-Temp-15.0
Vapcell%20INR18650%203000mAh%20V2.0%20(Purple)%202021-Temp-20.0
Vapcell%20INR18650%203000mAh%20V2.0%20(Purple)%202021-CapacityTimeHours
Vapcell%20INR18650%203000mAh%20V2.0%20(Purple)%202021-Energy
Vapcell%20INR18650%203000mAh%20V2.0%20(Purple)%202021-PowerLoadTime
Vapcell%20INR18650%203000mAh%20V2.0%20(Purple)%202021-TripCurrent
Vapcell%20INR18650%203000mAh%20V2.0%20(Purple)%202021-Charge
Discharge-Vapcell%20INR18650%203000mAh%20V2.0%20%28Purple%29%202021-pulse-1.0%2010%2010-IR
Conclusion
This looks like a good battery that can deliver a lot of current and it has a low internal resistance.
Notes and links
The batteries was supplied by Vapcell for review.
Graphical comparison to 18650 and other batteries
Table with all tested LiIon batteries
Correllux
Correllux's picture
Last seen: 5 hours 30 min ago
Thanks for another test!  I really appreciate the work and time you put into this for us...have enjoyed your various reviews and used your comparator so many times and often refer friends to your site.
vapcell Dennis
vapcell Dennis's picture
Last seen: 4 hours 32 min ago
Smile Good
d_t_a
Last seen: 1 day 19 hours ago
I wonder if this is the rewrap of the Samsung 30Q6-T.
Using HKJ’s battery comparator discharge graph at various discharge current, this Vapcell 3000mAh v2.0 purple is slightly better (or at least equal) to the Samsung 30Q at all discharge currents.
Comparing it to the Sony VTC6 though, the VTC6 has very slightly more capacity at low discharge currents, but at higher discharge current (7 or 10A or higher discharge current in the battery comparator), this battery has a bit less voltage sag (meaning, it performs a bit better).
Looks like a very good battery indeed. Thanks for the review!
