Are most built-in chargers for flashlights usually incapable of achieving a full charge?
26 posts / 0 new
xevious
xevious's picture
Last seen: 17 hours 16 min ago
I’ve got a few flashlights with built-in chargers. I conducted a test with three of them that I have on hand. None of them topped off the battery to a full charge. One was perhaps at 90% capacity, while the other was a little less than that… but the other, was maybe at only 75% (A Sofirn D25L). And these are all relatively new batteries. When removed, then reinstalled and plugged in, the built-in chargers would take a few minutes and then indicate a full charge was reached. But, inserting into a portable external charger would show otherwise.
So I’m wondering if this is typical, or if the built-in chargers in some flashlights will complete a full charge?
Renato Azevedo
Last seen: 9 hours 3 min ago
Good observation, I taught it was just with me. I have a few new lights from Nitecore, (MH12S, MH11, MH25S) and after charged I checked the batteries at 4,15V. Usually the external charger go to 4,2V. Now thinking perhaps this was by design, to increase the life span of the batteries and I don’t think the difference in real world use would be that much, perhaps a few minutes, but if you really need to get the most out of the battery external charger is a must.
freeme
freeme's picture
Last seen: 5 hours 10 min ago
4.18V end voltage is considered the preferred target value. Value might fluctuate a little, depending the type of battery (low vs high IR) used.
1thedeals.comyoutubeAstroluxNealsgadgetsolight
Bort
Bort's picture
Last seen: 6 min 22 sec ago
Its typical. They seem to either use crummy components or someone forgot to calibrate the damn things.
The annoying problem is that they are often not consistent, i have seen the same charger charge from 4.05-4.2V “fully charged”. No consistency Angry
That said i want your 75% one, i try to charge to 80% for longer battery lifetime.
The Journal of Alternative Facts TM
"It is critical that there is a credible academic source for the growing and important discipline of alternative facts. This field of study will just keep winning, and we knew that all the best people would want to be on board. There is a real risk in the world today that people might be getting their information about science from actual scientists"
Oli
Last seen: 20 hours 32 min ago
When I see the charging rate drop to 0.2a I typically stop charging. I don’t always catch it but I’m happy to stop at 4.1v or even slightly less. Most of the time I don’t drop below 3.5v either.
You can't compare the big flashlight in the sky to the little flashlight in your hand.
xevious
xevious's picture
Thanks. Yeah, I was wondering about calibration… would be interesting to hear if anyone bought multiples of the same light with built-in charging and tested to see if they all charged to the same level.
I had heard that it’s good to only charge fully once in a while, not on a regular basis, to extend battery life. There’s also the matter of rate… even cell phone makers with built-in batteries (not user serviceable) are starting to incorporate adaptive charging (disabling quick-charge and using a much slower rate to “exercise” the battery chemistry differently).
Bort
Bort's picture
Indeed it would
Its not necessary to fully charge at all. The less time spent over 80% the better. That said if you need more power and your going to drain it below 80% quickly then its probably not a big deal.
As for quick charging thats another kettle of fish and charging at 1/4 C (capacity) per hour is probably best for longevity.
story
Last seen: 4 hours 44 min ago
My SP36 is at 4.3v when charging and 4.25v when done. I measured it.
pennzy
pennzy's picture
Last seen: 35 min 8 sec ago
My SP36 goes over too. Most of mine stop in the 4.1X range consistently which is fine with me. I use a USB meter to monitor the charge cycles. I find that the charge indicator light on my Convoy M3-C is all out of whack. but it does charge correctly. My FT03 goes down to a trickle and will stay there for what seems like forever before terminating. I am glad to see 0 milliamps after termination so I don’t have to watch it that closely.
I love internal charging and stopped buying lights without it. Removing the batteries seems archaic to me now and very rarely use lights without it unless I don’t have a similar form factor light with it to use. I won’t gift a light without it. All my car lights and travel lights have it. I don’t own any series cell lights and the meter gives me enough snap shot of what’s going on to feel safe.
jon_slider
jon_slider's picture
Last seen: 29 min 6 sec ago
I dont have a % device.. what are you using, and how reliable is it for LiIon cells?
a while ago someone was using a device that reported %, it was for alkaline batteries.. which is not useful for LiIon..
I rely on a DMM to read Voltage. If the charger achieves 4.1v or above, I consider the battery fully charged. All my chargers achieve that.
I mostly use the Olight Universal Charger. I dont rely on built in charging, because that means I cannot use the light until it is done acting like a charger. I prefer to remove the spent cell, and install a fresh one, so I can keep using the light.
nottawhackjob
Last seen: 7 hours 20 min ago
I’d rather have a built-in undercharge to 4.1v than lean towards full-charge 4.2v or over-charge.
Since flashes are potentially exposed to varying levels of moisture I don’t blame built-in charge designers for limiting their ceiling.
When built-in charging yer obviously minus the charge port cover so now normally isolated electrified components are exposed. About the last thing ya need is raindrops or worse infiltrating internals, right? And the perfect moisture channeling conduit is the USB cable in of itself. Shocked Grad
External chargers don’t typically have potential looming moisture ingress issues so there’s inherent latitude.
‘Course if magnetic charging someday becomes di rigueur then who’ll need USB-Micros or even USB-C’s anyway? Then moisture issues are essentially eliminated. I would bet then built-ins would trend to full charge just like externals.
I think magnetic charging is the wave of the future for higher-end flashes. So all this USB-C hoofarah benefits over USB-Micro is likely relatively short-lived anyway to begin with. LOL
“In many things in order to truly understand the small picture you have to understand the big picture first.”
True Color Rendition (TCR)/Simplified Definition: “On a scale of 1 to 10, with 10 being the highest rating, a TCR will equate to what true colors you see in sunlight vs the same object’s colors you see when illuminated with a flashlight. The closer the two are, the higher the TCR rating will be.”
The TCR Reference Standard is the Walmart Ozark Trail OT 50L , Model No. 6103.
It has a TCR rating of ‘10’. $1.00 including batteries.
xevious
xevious's picture
The percentage is obviously used in place of measured data. I don’t have a specialized device that’s Micro-USB or USB-C to plug-in inline to check on power flow and mAh accumulation. And of course, my stated percentages were an off-handed estimation—I did not conduct a laboratory test starting measured cells at nearly depleted levels, timing of the charge duration, and taking voltage tests of the batteries at regular intervals. So my inquiry was a generalized one.
Essentially I’m actually glad to know that the built-in chargers I have don’t charge cells to their full potential, so as to help reduce wear on the batteries. That satisfies my inquiry.
wle
wle's picture
Last seen: 2 days 1 hour ago
i would guess if they do that, it is because of low precision, cheap components
knowing they buy cheap parts, the designers would hopefully make the errors go towards safety rather than danger (over 4.2V)
and it makes the cells last longer
    Daniel Behrman, "The Man Who Loved Bicycles".
-Greg Lemond.
Oli
You really should have at least a cheap multimeter to be able to measure battery voltage. Various lights do different things at various voltages and it’ll help you identify and understand what’s going on. Measuring the voltage of any new batteries you get or those that have been sitting for a while or even your car battery issues. Even a cheap harbor freight one for under $10 is useful.
jeff51
jeff51's picture
Last seen: 1 week 1 day ago
I have at least 2 that overcharge. One finished at 4.28v measured on the battery after pulling the battery after the charge completed.
The other was higher still, but I don’t remember what the value was.
I would think manufactures might like to aim low. That way any variance will be, hopefully, in a safe range.
I’m way happier with a conservative value.
Take a look at some of HKJs battery draw graphs. Notice how little time is spent above the 4.1v potential.
All the Best,
Jeff
xevious
xevious's picture
I have a Fluke multi-meter, one of the older rugged ones used by electricians with the super thick semi-soft rubber encasing. Trouble is, I don’t have the connector for getting access to the current for measurements on a USB-C or Micro-USB socket.
wle wrote:
i would guess if they do that, it is because of low precision, cheap components knowing they buy cheap parts, the designers would hopefully make the errors go towards safety rather than danger (over 4.2V) and it makes the cells last longer
Yeah, much better to fail in the safe direction (less, just to avoid a mess). I imagine light makers must be cognizant of that, simply for legal reasons.
Really important point, about overcharging. I’m going to test the other light I’ve got with built-in charger to be sure it at least doesn’t overcharge.
Oli
Testing amperage going into the cell through the USB cable is useful but that’s not your primary concern right now. Just being able to test the battery voltage on a loose cell out of the flashlight is a good starting point.
jon_slider
based on voltage, or what?
fwiw, here is a rule of thumb I use
3.6v is 50%
each 0.1v up or down is 10%
Dalamar
Last seen: 2 days 9 hours ago
Fireflies’ built in chargers does fine, but I have a full size charger that stops at like 4.15 or something.
I only like high CRI. Collection:
Fireflies NOV-MU 21 4500k E21A
Fireflies ROT66 219B SW45 D220
Fireflies E07 Copper 219B SW45k? (odd/higher lumen bin with lower r9 and higher cct?)
Fireflies E07 219B SW45k
Fireflies E07x Pro sst20 FA4 4000k
Varmint removal:
Convoy M21A C8 ver SST20 4000k (5a)
Convoy S2+ SST20 4000k  FB4 (3200ma)
Memes:
BLF GT94
Emisar D18 660nm SST20
CRI test dump https://drive.google.com/drive/folders/1kcl_uOhgfpR4RSsa8F4b-UUVP9mkL6Cr...
TheIntruder
Last seen: 3 days 15 hours ago
Just completed a battery refresh on a couple lights:
SP35 – meter wavered between 4.19/4.20 on the cell hot off the stove.
EC01 – same.
I do an initial check for proper function of the on-board chargers before trusting them in normal use.
SC31B mostly sits in its box, but it checked out fine when I first got it.
draver
I’m not trying to be contrary, but who uses anywhere near the number of charge cycles (200-500) quoted for most rechargeables? I’d be very surprised to find that I own a battery that has had 100 charges in the past 10 years or so.
I get it that someone who’s work requires inspections, but do these folks drain and fully charge their cells daily? My EDC gets 2-3 months of use per charge and that is my most used battery. (18650) If I were to ever need to get say, 250 charges out of a $6-$8 battery, I’d consider that money well spent.
I like fresh inventory on most consumables in most categories, and rechargeables are no exception.
jon_slider
whatever works for you is great
my 14500 LiIon in my EDC FWAA needs recharging about every 4 days
TIFisher
Last seen: 9 hours 47 min ago
They are hungry little suckers fo sho! Little bitty light with a big boy appetite.
Bort
Bort's picture
I have probably used 1000+ charges in the last 10 years spread over my batteries.
xevious
xevious's picture
Depending upon how you use it… Lots a turbo? Lots a chargin’. Wink
draver
So around 100 +/- charges per year? If your battery costs $10-$12 and you get 300 charges (3 Years) out of it, $3-$4 a year? Probably not breaking the bank.
