If a lithium ion battery exploded in a flashlight would it blow the light apart?
84 posts / 0 new
nottawhackjob
Last seen: 30 min 54 sec ago
Lightbringer wrote:
I remember reading the story (mightta been on CPF) about a guy whose light went supernova as he was carrying it, blew out the front glass and reflector, and shards from same ended up in his leg/foot.
Not Fun.
I had an incident back in my teens with dads car (‘70s Ventura/Sprint). Stomped on the loud pedal to get onto the main drag from a parking garage, pedal got hooked under the floor mat, and I’m rocketting towards the cars in front of me stuck at a light.
Bam! Shift into neutral, reach down, yank back the entire floor mat, and hit the brakes. Over and done in like 2-3sec. Shiite, even I was impressed how well I handled that. LOL
Interesting about the Bolt. Let it burn itself out, eventually, like those Pennsylvania coal mines. LOL
Good Gawd. Sounds absolutely fooking HAIRrowing. I bet ya lost a few curlies or ya GREW sum IDK. LOL Shocked
PS. I gotta sneakin’ suspicion that the floor mat thing is watt’s mainly to blame when people think their throttle stuck wide open all of a sudden. Shocked
“In many things in order to truly understand the small picture you have to understand the big picture first.”
True Color Rendition (TCR)/Simplified Definition: “On a scale of 1 to 10, with 10 being the highest rating, a TCR will equate to what true colors you see in sunlight vs the same object’s colors you see when illuminated with a flashlight. The closer the two are, the higher the TCR rating will be.”
The TCR Reference Standard is the Walmart Ozark Trail OT 50L , Model No. 6103.
It has a TCR rating of ‘10’. $1.00 including batteries.
ShyOne
ShyOne's picture
Last seen: 1 day 9 hours ago
SIGShooter wrote:
ShyOne wrote:
Yes, a flashlight powered by a LiIon battery “could” indeed turn into a pipe bomb.
I DO NOT know the odds of this happening… BUT, I WOULD THINK THEY ARE EXTREMELY SLIM.
It would be an EXTREMELY RARE occurance.
alpg88 wrote:
yes it can and it has, there are several thread with pics on cpf, iirc, in one instance, the light destroyed a balcony glass panel, and made the owner bleed. but it is very unlikely scenario, especially if you do not use crappy cells,
I recall reading the post about the incident alpg88 mentioned above.
I have searched for the thread about the incident but cannot find it.
It was an eye opener for sure…. Wink
CPF posting on Olight incident
Lawsuit on Olight explosion
Another CPF post
Thank you SIGShooter for those links.
I found the one we were referring to above…
TK Monster Explosion
ShyOne
ShyOne's picture
A true Diesel Runaway has nothing to do with a stuck throttle cable
It is a scary thing to behold…. and depending on the size of the Diesel engine can be downright frightening!! Especially if you cannot stop it & it runs until meltdown……
nottawhackjob
I’m thinking if a flash is gonna go Bikini Atoll at least it can turn into a rocket first then explode harmlessly in the atmosphere. That’s why I’m open to drilling a hole in the tail. Shocked
CRC
CRC's picture
Last seen: 21 min 6 sec ago
SIGShooter wrote:
CPF posting on Olight incident Lawsuit on Olight explosion Another CPF post
Great, now im terrified of my flashlights again…
Edit: I put them in my mouth all the time.
Im at least never getting a light that uses these 123 style cells.
Thats four instances of explosions and hydrofluoric acid poisoning ive read about now and every time it seems to be a light using these 123 cells.
raccoon city
raccoon city's picture
Last seen: 10 min 56 sec ago
If you just get single cell lithium ion flashlights, the risk is pretty low.
Or, you could just stick to Eneloops.  :THUMBS-UP:
Geoduck
Last seen: 52 min 5 sec ago
I remember a post on cpf many years ago where a guys light,(probably a Surefire) running 2 cr123 started making a whining noise and he pulled it out of it’s holster and it was extremely hot. He no sooner set the light down on the counter when it exploded blowing out the end and sending the light flying through the air like a missile where it hit a sliding glass door shattering the glass and putting a huge dent in the frame of the door. So a light might not blow up like a pipe bomb but fly through the air like a missile.
CRC
CRC's picture
Or, you could just stick to Eneloops.  alt=:" />
Im just gonna stick to single cell lithium-ion rechargeable flashlights that come with their own battery and charging system and hope for the best.
CRC
CRC's picture
Imagine an explosion with a headlamp Shocked
nottawhackjob
I can’t get my head around it.
Oli
Last seen: 2 days 4 hours ago
On any car with an automatic transmission built within the last few decades and beyond you can turn the key off (while driving) and the steering wheel is not going to lock unless you put the transmission in park and then turn the switch even further to the position where you can remove the key. If you’re on a highway you can steer to the side without issue without power steering fairly easily with two hands. You can get a couple of pumps of the brakes. But don’t pump them, just step on it and don’t let go. You can also just pop it in neutral and the computer is not going to let the engine rev beyond a very safe level. Some cars today won’t go much over 3,000 RPM in neutral. With push button starters you often need to hold the button down for three seconds or press it 3 times on some vehicles if you are in Drive. You should experiment with all of these methods with your foot to the floor at various speeds. Again the steering wheel will not lock. You won’t hurt anything with any of the above. And you can restart the car while still rolling in neutral at any speed if you want to bail out of any of your experiments.
nottawhackjob
Oli wrote:
On any car with an automatic transmission built within the last few decades you can turn the key off and the steering wheel is not going to lock unless you put the transmission in park and then turn the switch even further to the position where you can remove the key. If you’re on a highway you can steer to the side without issue without power steering fairly easily with two hands. You can get a couple of pumps of the brakes. But don’t pump them, just step on it and don’t let go. You can also just pop it in neutral and the computer is not going to let the engine rev beyond a very safe level. Some cars today won’t go much over 3,000 RPM in neutral. With push button starters you often need to hold the button down for three seconds or press it 3 times on some vehicles if you are in Drive. You should experiment with all of these methods with your foot to the floor at various speeds. Again the steering wheel will not lock. You won’t hurt anything with any of the above.
Good to know. Thumbs Up
Also don’t forget your emergency brake in case you’re outta pedal brake from panic pumping it too much. LOL Shocked
raccoon city
Yep, that's what I do.
I like to get high quality cells and chargers to reduce the risk.
CRC
CRC's picture
raccoon city wrote:
Yep, that’s what I do.
Those are two opposing statements lmao.
Im trying to avoid having to know about all that.
That is going beyond my abilities.
raccoon city
Oops.
I obviously misread your earlier post.
So, we have different strategies for acquiring cells and chargers.  :-)
CRC
CRC's picture
If a lithium ion rechargable battery like an 18650 does explode or vent, does it pose the same risks for inhilation and skin contact as the 123 primary cells?
Lightbringer
Lightbringer's picture
Last seen: 5 hours 34 min ago
I had a 14500 just leak in my GTmicro. No kaboom. No earth-shattering kaboom. Just clear ook leaking out from the beastie.
Must’ve caught it fairly quickly, ‘cause no permanent staining of the battery-tube or anything, not even the springs or driver.
Funtastic
Funtastic's picture
Last seen: 2 hours 25 min ago
Does anyone else remember a thread on here years ago of a Skyray King literally exploding?
This guy was using cheap bundled cells, so obviously junk Chinese crap that were unstable
Turned it on for a few minutes on Turbo, heard popping sounds
Turned it off, placed it down and left the room
BOOM!
The shrapnel blew out his apartment window
He had photos of the aftermath. I’ve search in the past for hours and can’t find the thread Sad maybe it was on candlepower
Texas Ace Lumen Tube calibrated with maukka lights
New Zealand store – https://www.piercingthedarkness.co.nz (NZ customers only)
YouTube channel – https://www.youtube.com/channel/UCIUWi2vYp4CWrRkOJM70t_w/videos (Demos for my customers, and reviews)
raccoon city
I don't remember seeing photos of the aftermath, so I'm guessing that wasn't on BLF.
Funtastic
Funtastic's picture
raccoon city wrote:
I don’t remember seeing photos of the aftermath, so I’m guessing that wasn’t on BLF.
I found the thread on candlepower, it’s different to what I thought it was, but still an explosion
https://www.candlepowerforums.com/threads/tk-monster-explosion.262234/
Ah, I see it was already posted Smile
Just a case of using dangerous batteries though
Bort
Bort's picture
Last seen: 7 hours 34 min ago
gchart wrote:
Clearly a case of mishandling here, but it was quite the explosion:
https://budgetlightforum.com/node/75588
Dear god! Those look more like grenade fragments Sad
I think i remember that one, lived in an apartment, insurance did cover it iirc.
MtnDon wrote:
I believe that if something happens tocause a cell in a flashlight to “have an event” the cell will most likely catch fire rather than explode like a bomb. That would, I believe blow out, melt, the tail switch if there is one, or/and blow out, melt the reflector or optics in the front, or/and even theside switch aperature would also vent. No shrapnel flying about, but a “road flare” that could start a fire.
Interesting theory.
JamesB wrote:
There is one case of death caused by an Olight flashlight exploding while the poor user was holding it in his mouth, there has been quite a few documented cases in the past on CPF of catastrophic flashlight explosions, these were mostly used with CR123 in series , also some intances of loud but harmless popped tail switch rubber.
I only use single cell lights, so hopefully that cuts the risk substantially
xevious wrote:
max wrote:
@ Bort,  you need to get a refill on your non-paranoia meds ASAP.
I’m really curious to know how bright is a proverbial flashlight… Flat Stare
The proverbial flashlight is between 100 and 4000 lumens (Olight I3e to Convoy M3C).
kennybobby wrote:
Yes, If a lithium cell exploded in a flashlight, then indeed it would blow the light apart. It would be a Bad Day.
Most quality cells have over pressure vents that will open if the internal temperature goes up due to any of the various failure scenarios; venting should prevent an explosion.
Thats good.
Another CPF post
HF poisoning Facepalm
Thats insane.
Funny how i got many mocking replies in this thread for even asking the question.
The Journal of Alternative Facts TM
"It is critical that there is a credible academic source for the growing and important discipline of alternative facts. This field of study will just keep winning, and we knew that all the best people would want to be on board. There is a real risk in the world today that people might be getting their information about science from actual scientists"
raccoon city
It's a good thread.
I think some people just don't want to think about the remote chance that lithium ion batteries can be dangerous.  :BEER:
Funtastic
Funtastic's picture
It’s extremely unlikely IF
- You care for your batteries and know all the safety precautions
- Don’t use budget, cheap, old batteries
- Don’t be an idiot
raccoon city
- Don’t be an idiot
Yep, it helps to have a safe high quality charger as well.  :THUMBS-UP:
Funtastic
Funtastic's picture
- Don’t be an idiot
Yep, it helps to have a safe high quality charger as well.  alt=:" />
Ah, yes, I knew I had missed something, but that kind of falls into caring for them correctly
Bort
Bort's picture
raccoon city wrote:
It’s a good thread.
I think some people just don’t want to think about the remote chance that lithium ion batteries can be dangerous.  alt=:" />
Thanks Smile
I was just thinking that you and i are old BLFers, back in the old days we were at the basics, while today who knows where the batteries are even coming from, i had to make a thread and ask where Sofirn’s included batteries come from (and apparently its not a first tier supplier)
Funtastic
Funtastic's picture
Sofirn’s 21700 batteries are now from Lishen which aren’t half bad.
The 26650’s are excellent being from PLB who were used by Shocli.
14500’s are questionable and I’ve received many in the past with rust under the wrap. Reported to Sofirn and was ignored. I purchased in bulk 200+
Not sure what the 18650’s are, but tested okay. No idea on how they age though
Sofirn’s 14500 cells with rust
Bort
Bort's picture
!{width:60%}[img]https://i.imgur.com/1BELm8B.jpg[/img]!
Very interesting.
I try to stick to name brand, My 18650s are Sanyo and Samsung. If i replace them (they are getting close to 10 years old) and get some 21700s as well i plan to go with name brand again. The HF thread is more worrying then the explosion risk.
BTW I actually like your posts becasue as a business you have a lot of experiences none of the rest of us have.
Which reminds me you had mentioned in another thread that Convoy are certified lights, what certification do they have?
Also i noticed CE and ROHS on my new Wurkkos WK30, was surprised to see that.
Funtastic
Funtastic's picture
The brands I sell that have CE, ROHS certs are (I don’t sell anything else yet)
Sofirn
Not the D25S, D25L, S11C since they aren’t made by Sofirn
Wurkkos (Sofirn build them)
Convoy
Guess what, I just found out Astrolux/Mateminco refuse to carry out any testing anymore. I’m ditching the brand. They print CE, ROHS on the flashlights, but have no such testing done at all. I would strongly suggest not buying them IF your country requires these certs for your insurance.
Funtastic
Funtastic's picture
oh and Skilhunt has all the safety certs. I just have their headlamps
