Insulated Garage Doors – Worth It?
28 posts / 0 new
jeff51
jeff51's picture
Last seen: 11 hours 54 min ago
Over in the “What’s the Weather Like” thread there were some BLFs who had insulated garage doors installed. Though I’d share my experience.
I just had R18 doors installed. Three car garage with a double door and a single door.
I have a temp data logger running in the garage to see what was going on temp wise during a 24 hour period.
The doors get full afternoon and evening sun.
With the old single ply metal doors, the inside temp in the early evening often exceeded the outside air temp.
I picked two days for comparison that had very similar daytime highs.
Take a look at the difference.
The Blue trace is the inside temp with the old single ply metal doors installed.
The Red trace is the inside temp with the R18 doors installed. Along with exterior weather flaps and much better bottom weather stripping.
Heck of a difference!
Over 100F inside with the old doors.
Less than 80F inside with the new doors.
It would do even better if I insulate the non-insulated exterior walls and ceiling.
And I’ve got a 2 ton mini-split in there now too. No more death sweats while working in the garage for me. No more frozen finger in the “winters” in Texas.
All the Best,
Jeff
MtnDon
MtnDon's picture
Last seen: 7 hours 8 min ago
Thumbs Up Very cool! Well, cooler than before for certain. Wink
Enjoy. I do enjoy ours.
zoulas
zoulas's picture
Last seen: 9 min ago
This is not only expected but also worth it. Good write up.
dthrckt
dthrckt's picture
Last seen: 16 hours 17 min ago
That’s an awesome write up. Thanks, jeff51, that’s the real way to save resources.
I lined my 1950s stick built garage with reflectix (that’s a brand, I used the bubble wrap with mylar on both sides). Also used for a ‘false’ ceiling.
Used to be impossible to heat. I can work in there all winter now, and it stays much cooler in the summer. 24’×24’ cost ~$700, including the doors.
The look makes people think I’m scared of alien signals, but it worked.
jeff51
jeff51's picture
One always needs to be careful of alien signals. And Black helicopters…
I need to investigate ways to get insulation behind drywall in the exterior walls. One gets full sun all afternoon and evening.
When the sun gets covered by clouds, it’s amazing how quickly the temp drops in the radiated areas.
All the Best,
Jeff
chops728
Last seen: 7 hours 58 min ago
My Garage Doors are both the 2 1/4” insulated and double sided finished on the inside —the walls and ceiling are all insulated as well —- with the temp outside hitting mid 90s and the inside temp set around 74 the garage will stay around 78-80 degrees ——the crazy part is —this is a house that I call my camp and when I’m not there I set the AC on 78 — when I get there the garage is still 80-81 degrees —— but lookout when you open one of those doors — it’s like a vacuum sucking in the heat and humidity
I find they sound so much smoother going up and down also — they seem to dampen the noise a bit in the garage also
Dr scott Diabol...
Dr scott Diabolical - Evil Genius's picture
Last seen: 1 month 1 week ago
Definitely worth it! Mine is only R-3, but even that makes a huge difference. My garage walls and ceiling are R-19. Which is pathetic for Colorado (the rest of my ceiling is R-90). But I can heat the garage up to a steady 50-60 F when it’s -5F outside using a 220v 4800 watt radiant baseboard. 50-60 F is still a tad chilly. But it’s long-sleeve weather instead of parka-n-ski pants weather.
kennybobby
kennybobby's picture
Last seen: 2 hours 9 min ago
Thanks for the tip, i’ve never seen or heard of the reflectix, but it has lots of possibilities.
i bet you don’t need much light in the death rocket garage either. LOL
Installation Manual
And damn Dr evil, is R-90 really a thing? How is that done?
Now i used to think that i was cool,
drivin' around on fossil fuel,
until i saw what i was doin',
was drivin' down the road to ruin. --JT
dthrckt
dthrckt's picture
Installation Manual
It has so many possibilities,.
I even use it for packaging, ice shanty floor, bunny habitats, even an extra layer in the bottom of ice boots…
In the garage it mostly slows air flow. Radiant reflectivity helps,, but mostly traps air. low R value, but that still saves so much fuel.
There are so many lights in my garage. Not good ones, mind you,, but very many. I think about 60k lumens. Next time I will take a pic.
pennzy
pennzy's picture
Last seen: 8 hours 29 min ago
I have been watching building science evolve since the 70s. Generally more insulation is better. Vapor barriers are where it gets tricky. Depending on your climate it can be on the outside or the inside. Usually on the warmer side. Don’t want rot forming in your walls. The latest code is calling for extremely tight building envelopes. Mechanical ventilation is required to get fresh air in. The book is still out on a lot of this.
dthrckt
dthrckt's picture
kennybobby
That’s what i was thinking—that it would help lighten up a dark garage or attic area.
dthrckt
dthrckt's picture
It sure did! Allowed me to just use led bulbs with no fixture.
wle
wle's picture
Last seen: 15 hours 20 min ago
I have a small garage, usually i leave doors open in summer to avoid car engines heating air that then leaks into the house.
In winter i will close doors to keep cold air away from house doors and car engines.
They are not insulated.
The garage is too small for me to ever use it as a work space, so I do not need to heat and cool it.
    Daniel Behrman, "The Man Who Loved Bicycles".
-Greg Lemond.
Scallywag
Scallywag's picture
Last seen: 13 hours 54 min ago
I purchased the low-tier of insulated garage door, I think R-9 or R-13.
Two walls are cinderblock, the ceiling and third wall are insulated with poorly installed drywall. It faces north.
I don’t have any measurements, but the water in the sump didn’t freeze the winter after it was installed.
jeff51
jeff51's picture
One thing to remember about R values in these doors is that an R12 is not twice as much as an R6.
I found this chart. Not for doors, but at least gives some comparison.
That shows relative amounts of heat reduction.
A single ply metal door has an R value of 0 according to one source I found.
So any insulation will make a big difference.
One of the unexpected benefits is how much quieter it is inside with the doors closed. A pleasant surprise.
I went with the belt type openers instead of the chain. Much quieter too.
I need to add lighting.
Any of you have some suggestions as far as shop lights for a garage?
All the Best,
Jeff
pennzy
pennzy's picture
If you just want to retrofit and existing socket this style is bright as hell. There are others in the Vipon deals.
https://www.myvipon.com/product/8684196-LED-Garage-150W-15000-Lumens-Garage-amazon-coupons?sl=&f=deal&search_tid=610706eb5094bb31a505f131
chops728
Another thing that really helps is the newer Weather Strips with the rubber that seals against the door —- Plus a good bottom Rubber that’s not all shrunk up several inches on each end— But I would advise if you keep vehicles — anything that makes carbon monoxide — Have a good Sensor located in the garage — you don’t want to wake up dead
kennybobby
The R value of insulation is the Resistance to thermal energy transfer (mainly conduction). It is additive in that 2 layers of R-6 will give you an R-12 rating.
For example with a given amount of heat or thermal intensity such as from the sun hitting a metal garage door skin, if an R-6 layer will provide a 6 degree temperature difference, then an R-12 will have a 12 degree difference for that same heat flux. Same sized door, same sunlight, same amount of time exposed.
It is similar to electrical circuits where the temperature is ~ voltage, the R-value is the resistor, and the heat flux is the current flow. Double the resistor and current is halved, etc.
dthrckt
dthrckt's picture
All the Best,
Jeff
Adding any insulation helps a lot, if done well.
You can see my cheap lighting solution. I would not recommend it as is.
Cheap as can be, I just wired in new bulb bases off a ground fault outlet, then used cheapo Y sockets to put 4 or more bulbs in every one. They seem stable now, but when I first did it, a few of the Y adapters made a crackling sound in use and looked like they were arcing on the contact points. Dangerous.
If I were to do it again I’d still use bulb bases (cheap upfront, easy replacement), but instead of 4 rows of 3, I would double at least double the number of bases.
LED shop lights would be nicer, but at the time they were a lot more money for same lumens. I also get to try different bulbs or easily upgrade (already went from 60w to 100w equiv and moved 60W to basement).
MtnDon
MtnDon's picture
Re: adding more insulation…. There are diminishing returns when adding more R-value.
This article a good information source
Scallywag
Scallywag's picture
For lighting, I’ve used Costco’s led shop lights. Whatever was cheap at the time.
kennybobby
From a theoretical academic standpoint he uses just one equation for a side wall to base all his economic conclusions, but not one word about the temperature difference expectations across the various insulation thicknesses, [nor the fact that heat loss is mostly vertical, nor the effects of direct sunlight on a metal garage door.]
Seems to me that’s what really matters—if its 95 outside and you want to be 75 inside, then that 20 degrees has to come from either thick insulation or running the AC, which costs more?
Same with heating in the winter, if its 20 outside and you want your wife to be happy, then you need to make up the 55 degree difference, either with extra insulation or running the heater.
dthrckt
dthrckt's picture
I will tell you what else matters. If that temperature differential between periods of time is close enough and substantial, the plastic containers of liquids that you store high will eject liquids, even unopened.
Not fun with brake fluid.
kennybobby
Yes One thing leads to another—now i have a dozen plastic bins to put on the shelves to hold the cans of unopened liquids prone to self destruct and leak. Learned that the hard way too. Sad
jeff51
jeff51's picture
Kennybobby is on point about insulation vs AC. I sized my mini-split to what I could best guess as far as the non-insulated doors and highest indoor temps reached (120F+). If I can find an old temp log, I’ll POST it.
After talking to the AC guys – they were at first thinking 1.5 Ton. We went for a 2 ton unit.
The thing is a variable speed compressor, so it will ramp down if max cooling is not needed.
Had a few super hot days and with the thermostat set for 68F. I wanted to see if the thing could hold that temp during peak heat time. It almost could do it. Inside temp just went up a few degrees. This would give me a good idea of what temp settings would be most beneficial Temp vs run time wise.
Also turns out I didn’t have the settings optimized. RTFM!, so maybe it might have done a bit better. But don’t think I was off by much.
With the new doors, I haven’t had a super hot day for testing. But best guessing, I think the max inside temp with the AC off would end up in the mid to high 80s – maybe low 90s when it’s really cooking outside.
The AC should have no problems keeping up with that. No matter where I set it.
Now as far as energy vs $$. You can buy a heck of a lot of KWH of angry pixies for what a new set of doors costs. Payout will not be in my lifetime (old fart here).
But I needed new doors and openers – the old doors were getting way cranky. This happened not long after I got the new AC installed.
So I felt it was worth the extra bucks to get the best I could reasonable afford.
I’m glad I did. The quality is way nicer than the single ply doors and the added quiet operation and exterior noise reduction is much appreciated.
I’d make the same choice without reservation if given the same conditions.
I’m looking forward to not having stuff in the garage die premature deaths do to super high temps (including me!).
All the Best,
Jeff
kennybobby
It’s funny how often you hear folks talking about insulation…
“ i put R-30 in the attic, but i wish i had only put in R-16”
or “i sure miss paying a higher bill for my utilities”
LOL
dthrckt
dthrckt's picture
LOL
Haha, so right. I actually can’t think of an example of someone saying they installed too much insulation. Jeff’s approach, using data, is a great way to not overspend.
