【New Arrival】Cyansky HS6R Triple Output Headlamp, 1400 Lumens / 170M, Rechargeable Li-ion 18650 Battery, Type-C Fast Charging
17 posts / 0 new
Cyanskyflashlight
Cyanskyflashlight's picture
Last seen: 1 day 44 min ago
Hi everyone. We just launched a new headlamp named HS6R. It is specially built for Outdoor Searching, Rescuing, and Industrial Operations. We offer a special discount on this product for all BLF users. PM me to get a coupon if you are interested.
CYANSKY HS6R is a full metal TYPE-C rechargeable headlamp. It features triple outputs with the main light of white spotlight and auxiliary lights of white floodlight and red light. The main light and auxiliary lights can work simultaneously for free combinations with a max of 1400 lumens.
Moreover, the independent dual switch design for main and auxiliary lights allows single-hand operation extremely easily.
1. 1*LUMINUS SST 40 LED for the main white spotlight, 1* LUMINUS SST 20 LED for auxiliary floodlight, and 1*Everlight 2835 red led with a lifespan of 50,000 hours.
2. Powered by 1*18650 Li-ion battery and compatible with 2*CR123A batteries.
3. Overheat protection against high surface temperature for better user experience and longer lifespan of the light.
4. Independent dual switch design for main and auxiliary lights.
5. Aero-grade A6061-T6 aluminum alloy material shell.
6. Premium type HAIII hard-anodized anti-abrasive finish.
7. Grade 10 Super Impact-resistant PC Lens.
8. Low-voltage warning.
9. Type-C charging, 3 hours for a full charge.
10. Maximum output is 1400 lumens.
11. Maximum beam distance is 170 meters.
12. Maximum runtime on a single charge is 30 hours.
13. Intelligent memory circuit.
14. IP68 waterproof – 2 meters underwater.
15. 2 meters impact resistance.
16. Workable from -30℃ to 50℃.
17. Storage environment: -35℃ to 65℃.
18. 160 grams(battery & headlamp band included)
19. Dimension: 80mm(length)×40mm(height)×36mm(width)
Let’s see the illumination effect at night
Edited by: Cyanskyflashlight on 08/16/2021 - 05:16
CR888
Last seen: 3 weeks 2 days ago
Do you have a link for purchase? BLF coupon?
CR888
middle age man
Last seen: 12 hours 3 min ago
They have it for sale on their website – https://cyanskylight.com/product/hs6r-rechargeable-headlamp/
It’s only 80mm long!
everydaysurvivalgear
everydaysurvivalgear's picture
Last seen: 12 hours 39 min ago
Looks interesting, any reviews of the light?
zoulas
zoulas's picture
Last seen: 28 min 16 sec ago
This is a nice looking light, great design.
BillyBobJoe
Last seen: 7 hours 21 min ago
I like the looks, what price point are we talking?
Cyanskyflashlight
Hey, bro, you can buy it on our official website.https://cyanskylight.com/product/hs6r-rechargeable-headlamp/(link is external). We have a few BLF coupons, PM me
Cyanskyflashlight
You can see the price on our website. If you want a coupon, PM me. We offer a special discount for BLF users.
Cyanskyflashlight
The reviews are coming soon. We will share them with everyone here.
Cyanskyflashlight
middle age man wrote:
They have it for sale on their website – https://cyanskylight.com/product/hs6r-rechargeable-headlamp/ It’s only 80mm long!
Yes, man. Thank you for your attention. Its size is 80mm(length)×40mm(height)×36mm(width)
Cyanskyflashlight
Thanks, zoulas. It is very nice. I love it too.
Oli
Last seen: 1 day 5 hours ago
It looks to have a very tall stainless steel mount and a very wide strap to match. Quite a bit heavier than an average 18650 headlamp also. On a baseball hat as in the picture or on some sort of helmet this may not be an issue. I can’t imagine that weight is going to ride comfortably on a bare head with the single strap or even if there was a additional over the top strap.
Oli
A few numbers don’t add up. Spec shows 85 mm wide. Spec shows 1200 lumens plus 500 on the auxiliary that doesn’t get you to 1400 lumens. Going to need to see some thorough reviews. I don’t like SST40 but which one is it?
Cyanskyflashlight
Yes, Oli, it is specially built for outdoor searching, rescuing, and industrial operations. On these occasions, people usually wear a headpiece or a baseball hat. It is very comfortable wearing a headlamp with headpieces or hats. The weight on a bare head with the single strap might be a little heavy, but we use a tall stainless steel mount and a very wide and adjustable strap, try our best to let the users feel more comfortable.
Cyanskyflashlight
It might be a mistake for the length, it should be between 80~82mm. When the main light and the auxiliary light are in the brightest mode, that can get to 1400 lumens. The reviews will come soon, then we will share them with you here. Thanks for your professional question, Oli.
stephenk
stephenk's picture
Last seen: 2 hours 26 min ago
Looks like a good design, but 10 lumens for red is nothing special.
Cyanskyflashlight
Hi, Stephenk, this red light is mainly used for close-range lighting, so it won’t be harsh on your eyes and will keep mosquitoes away from you.
