New Sofirn TIR thrower: IF22A SFT40 2100lm 629m
104 posts / 0 new
pennzy
pennzy's picture
Last seen: 28 min 24 sec ago
Thanks for reporting Tom. I put some DC fix on mine for G&S. Not bad. Running it on high seems not to overheat. Plenty of flood with a little throw.
Tom E
Tom E's picture
Last seen: 1 hour 10 min ago
JaredM wrote:
Do you have an EA01 with sst40 to compare optics and throw values? Or FF E01?
Well, I got a FF E01 w/SST-40 (not an EA01), but the TIR optic is different - you can see the LED, but the other differences like the smaller width optic in the E01, and SST-40 vs. SFT-40 has big differences in throw.
JaredM
JaredM's picture
Last seen: 37 min 16 sec ago
I thought I remembered you having an ea01 or the mateminco equivalent.. my bad.
I’ve been wondering how the FF might do with the SFT.. how close to 100kcd it could hit. My assumption is 220% throw vs an old bin sst40. It oughta be much more pocketable than the if22a.
Tom E
Tom E's picture
No, you are right! Just found it. Facepalm
roostre
Last seen: 3 hours 10 min ago
Tom E wrote:
I just took some #'s on the IF22A and got:
  • on a 40T1 (old rev, better) at 4.18V: 9.0 amps w/tailcap removed
  • lumens: 1730 at start, 1740 at 10s, 1680 at 30s
  • throw: 113 kcd (772 meters)
The initial rise in amps is interesting. I've only seen this with higher resistance springs, but I seen the rise with a jumper on the batt- to tube, so eliminating the one spring in the tail. There must be something else in the circuit that reduces resistance as it heats up initially, and confirmed a bypass on the tail spring will boost amps, boosting lumens and kcd.
Could it be possible that as the battery heated up, that the battery's internal resistance decreased allowing a slightly higher voltage to deliver a little more current and increase the brightness before the voltage sag eventually caused the brightness to decrease?
How many flashlights does a "real man" need?
None, real men are not afraid of the dark.
JaredM
JaredM's picture
Not likely on this timescale at this current. The only thing with a ntc behaviors would be semiconductors. Either the led of fet.
JaredM
JaredM's picture
If you get a chance, I’m curious how all three of these lights compare using the same lux meter and tested back to back.
Tom E
Tom E's picture
JaredM wrote:
If you get a chance, I'm curious how all three of these lights compare using the same lux meter and tested back to back.
Ok, I'm not sure of the point, but:
FF E01 SST-40 5700K, stock except running A2, on a 40T @4.21V:
  • at 5 secs, 5 meters: 49 kcd
MT01/EA01 SST-40 5000K, A2, tail 20 AWG bypass on a 26800 @4.21V:
  • at 5 secs, 5 meters: 85 kcd
IF22A SFT-40 6500K, tail 20 AWG bypass on a 40T @4.21V:
  • at 5 secs, 5 meters: 116 kcd
Tom E
Tom E's picture
Ohh - tried the MT01 TIR optic in the IF22A and got 124 kcd, though the beam looks different, most would probably say worse - larger hotspot but a bright spot in the center of the hot spot. The optics appear to be designed differently in the center. The IF22A has a larger diffused spot in the optic.
MT01 w/IF22A optic: 73 kcd  -  beam looks softer, hot spot not as well defined.
(same 5 sec delay, at 5 meters, same cells as-is, not re-charged)
SammysHP
SammysHP's picture
Last seen: 4 hours 23 min ago
Tom E wrote:
I just took some #‘s on the IF22A and got:
The initial rise in amps is interesting. I’ve only seen this with higher resistance springs, but I seen the rise with a jumper on the batt- to tube, so eliminating the one spring in the tail. There must be something else in the circuit that reduces resistance as it heats up initially, and confirmed a bypass on the tail spring will boost amps, boosting lumens and kcd.
The lens appears to be uncoated, so it may be possible to get a 5% or so bump by replacing it with a double coated AR. I say “may be” because it’s hard to judge the quality of the glass used.
Lens size: 23.5 mm x 1.94 mm
MCPCB size: 23.5 mm
I’ve noticed the same in my stock IF22, even at lower levels:
(Turbo might be cut off slightly because I’ve moved the light quite a bit when pressing the button so I’ve cut off the first 1-3 seconds.)
JaredM
JaredM's picture
Tom E wrote:
Ok, I’m not sure of the point, but:
MT01 w/IF22A optic: 73 kcd – beam looks softer, hot spot not as well defined.
Thanks Tom. I was interested in the differences between the two larger optics.. basically the question if they are identical or not.. and what the throw ratio was stepping down to the E01. It’s a rare light and not many reviews or posts talk about it, so I wanted a head to head comparison. So thank you!
What this suggests, thanks to your extra testing with swapping the optics around, is that we can expect mid-high 70s kcd for the E01 with an SFT40. I think this is a sweet spot of sorts for maximum throw while staying quite pocketable. Above 34mm head really isn’t comfortable, at least for me as a slender person who wears Levi 511’s. YMMV
Lumen9000
Lumen9000's picture
Last seen: 5 hours 58 min ago
“Is that an ea01s in your pocket or are you just happy to see me?”
JaredM
JaredM's picture
I don’t think you’d mistake the two
