New Armytek flashlights: Dobermann Pro Magnet USB & Predator Pro Magnet USB are available NOW!
2 posts / 0 new
Armytek
Armytek's picture
Last seen: 2 days 3 hours ago
Hello, guys! We are ready to present our NEW tactical flashlights!
Meet Dobermann Pro Magnet USB & Predator Pro Magnet USB!
_____________________________________________________________________________________________________________________________
Dobermann Pro Magnet USB is a model with narrow beam of light and smooth transition between hotspot and spill. The combination of a compact body and impressive light characteristics makes Dobermann Pro a 2 in 1 flashlight for tactical and day-to-day application.
Impressive features of Dobermann Pro Magnet USB!
The flashlight with 1500 lumens brightness is best suited for solving tasks at medium distances of 100-200 meters (maximum distance of light is 368 meters).
Standard 1 inch diameter body allows the use of additional tactical accessories: any weapon mounts and original remote switches.
Total protection from water, dirt and dust in accordance with IP68 standard — flashlight continues to work even at 25 meters depth up to 5 hours. Withstands fallings from the 10th floor.
2 in 1 flashlight
Tactical flashlight
- Withstands any recoil due to improved springs and installation of the driver inside a reinforced capsule filled with protective compound
- Standard 1 inch body is compatible with any accessories, including original magnetic remote switch and magnetic mount for quick one-motion attachment and removal
Every Day Carry flashlight
- Compact body, convenient holster, steel clip and lanyard for day-to-day carry and use
Predator Pro Magnet USB is a tactical model with narrow beam of impressive throw for specialized tasks and hunting. The new generation flashlight has retained the best characteristics of the previous version, while receiving a high-tech update.
Impressive features of Predator Pro Magnet USB!
Clear central spot with minimal side spill allows to illuminate objects at a distance up to 501 meters. Ideal for use at a distance of 100-300 meters.
Impressive light output up to 1500 lm.
Active real-time temperature control to prevent overheating above +58 °C and warning indication of low battery level.
Advantages of tactical flashlights with magnetic charger:
- Non-flat button allows to easily switch the flashlight with a palm.
- Active real-time temperature control to prevent overheating above +58 °C and warning indication of low battery level.
- Two types of operation: hunting and tactical. Tactical operation for quick access to maximum brightness mode and Strobe mode.
- Magnetic charger in the set.
Order Dobermann Pro Magnet USB & Predator Pro Magnet USB today at armytek.com!
Thank you for choosing Armytek!
Armytek Optoelectronics Inc.
www.armytek.com
Edited by: Armytek on 08/05/2021 - 04:58
ChibiM
ChibiM's picture
Last seen: 18 hours 39 min ago
Exciting stuff!
Thank you for sharing
