Coast Polysteel 700: Zoomie with side COB and redlight
13 posts / 0 new
Markus
Last seen: 2 weeks 5 days ago
A beefy light powered by 4x AA, a very decent zoom and great COB-LEDs. In my video I compare it to a high quality light and demonstrate the difference with beamshots.
Bort
Bort's picture
Last seen: 7 hours 55 min ago
Nice review Smile
At first i was wondering if the cops in the background near the end were called becasue someone was wondering what that person with the flashlight was doing Big Smile
I have a Polysteel 600 and it has some likely similar deficiencies, the identical looking battery holder strips the wrapping from batteries (it was designed for Alkaline single uses so stripping there is no big deal). Also i fried one by using it on high for a half hour. Coast replaced it under warranty.
This one looks like it would have the same problems, though i hope it has temperature regulation which would solve the overheating issue.
The side lights are interesting and the side switch instead of tail switch and the new tail magnet are nice touches.
The Coast branding inside the reflector is humorous.
BTW the runtime confusion you mention is down to 10% brightness, it would sag after a few minutes on alkaline and keep above 10% till the 3 hours and whatever minutes. The ANSI standard is down to 10% output.
The Journal of Alternative Facts TM
"It is critical that there is a credible academic source for the growing and important discipline of alternative facts. This field of study will just keep winning, and we knew that all the best people would want to be on board. There is a real risk in the world today that people might be getting their information about science from actual scientists"
KeepingItLight
KeepingItLight's picture
Last seen: 20 hours 24 min ago
Good stuff.I thought this was a practical, and therefore useful, comparison.
Thanks for taking the time to produce and share.
Markus
@Bort
Thanks! There is a donut shop in the near which makes the police hurry to get to it Wink (cops are awesome in Victorville, just a cheap joke)
I ll do a more extended overheating test but to me the output is just not there to fry much.
I would like to see something like the PS700 from a high quality manufacturer like Sofirn or Nitecore. A utility light in high quality.
Scotty321
Last seen: 13 hours 24 min ago
I used my Polysteel 700 for changing out a fuse holder and battery on my car one night. It was perfect. I would probably tend to keep it on medium on the front LED for longer term use, as the plastic doesn’t seem to be good for venting/heatsinking.
I’ll usually set it at a few degrees off of spot so that I have good throw and spill. If it sits for a few days, the head twist takes a lot of force to start moving again. I actually like that for my purposes, but some reviewers think it isn’t a zoom because they can’t break it free for that initial loosening.
I have the smaller versions of this light that aren’t my favorites but I like this 700 and got two at $20 when they were on sale locally. The smaller ones I always keep a few degrees from spot to get decent throw and spill.
If you want better color rendition and go to HD, they have flashlights that advertise “color correct” this or that. I can’t remember the brands or models, but in some jobs, identication of colors is important. For the price, though, I haven’t picked those up so I don’t know how true the colors are.
Doesn’t LedLenser make the Coast lights?
Bort
Bort's picture
Markus wrote:
@Bort
700 lumens in a plastic case will fry the LED/circuitry
Scotty321
Nitecore makes the MT21C.
Lightbringer
Lightbringer's picture
Last seen: 2 hours 2 min ago
Awww, you didn’t blow it up??
I kinda like those zoomies, like the S11C that has the same system.
Markus
I had it running for 45min on max including both COB during a hot desert night. It got warm, not hot Also the output dropped almost a 50% on all LEDs I would guess.At least on alkaline batteries nothing should fry. Is there a stepdown or even temp control…? I doubt it.
stephenk
stephenk's picture
Last seen: 36 min 46 sec ago
I’ve seen a review showing that the Coast Polysteel 600 steps down to 22% of original output by 6 minutes, which is pretty terrible for a light than runs on AA batteries! The plastic outside casing means that it can’t dissipate heat well, so the heat stays inside the light and can fry internals.
Bort
Bort's picture
Its also delayed frying.
Mine worked fine for a while after my half hour use but then died one day.
Boaz
Boaz's picture
Last seen: 11 hours 53 min ago
Nice review that doesn't glorify or demonize the light .
It's interesting to hear someone on BLFs opinion of a light a friend might show up with at the neighborhood cookout .
I rarely find anything at the local big box stores that I find interesting ..But I'm always willing to be proven wrong. You have to give Coast credit for sticking around as long as they have and making a name for themselves ..  Otoh $40 is kind of steep for a hardware light
Terry Oregon
Terry Oregon's picture
Last seen: 6 hours 34 min ago
stephenk wrote;
Quote:
I've seen a review showing that the Coast Polysteel 600 steps down to 22% of original output by 6 minutes, which is pretty terrible for a light than runs on AA batteries! The plastic outside casing means that it can't dissipate heat well, so the heat stays inside the light and can fry internals.
That would have been me.
PWM on the 600 is about 193 Hz.
Coast is a popular brand where I live, available in many different stores. That's because their corporate headquarters is about a 30min drive from where I live in the suburbs of Portland Oregon.
My reviews: , My personal collection of lights LINK,  J5 Tactical V1 Pro review LINK,  Thirteen Optical Sensors review LINKZebralight SC700d review LINK,  Ray-O-Vac Super Power Sportsman review LINK,  Convoy S2+ color combos LINK,  How To flash D4V2 LINK,  Convoy S21A LINK
