Where are all the Fresnel lenses?
9 posts / 0 new
zerodish
Last seen: 6 hours 12 min ago
This has been brought up before but I think it is time to bring it up again because of the invention of COB. The bigger emitter you have the harder it is to focus. The problem has been addressed before. Scientists who were trying to focus the suns light into a smaller spot to produce more heat ran into this problem. They solved the problem by designing a lens that did this but the sun was no longer in focus. This is a problem if you are trying to view sun spots but not if you are trying to produce a smaller spot. I will never be able to find the original article which was likely in Science News. So we know the problem can be solved. I’m not trying to make a laser out of COBs I just want a light that has a good throw at high power. The Fresnel lens would have to be close to the emitter. It would then have to pass through other lenses to collimate it.
alpg88
Last seen: 3 weeks 3 days ago
Fresnel is no different than regular lens optical wise, it’s only advantage is its size.
Edmund optics has them as well as amazon and ebay. focusing large cob is not an easy task, nor it makes sense, since you can do it a lot easier with small die led, that is why you do not see it used a lot. ledil seanna lens uses Fresnel, it can do 1* with xp size led, but it wont work with cob.
Unheard
Unheard's picture
Last seen: 1 hour 23 min ago
But to answer the question: One of them is in front of a TrustFire MC1.
Smile, you cannot kill them all.
Scotty321
Last seen: 1 week 22 hours ago
I think the AB L18 also uses a fresnel lens… but the L19 has more throw, and neither uses a COB.
Unheard
Unheard's picture
Yeah, as alpg88 pointed out, it is just a space saving lens. No advantage for large emitters.
The MC1 has an interesting cone shaped spot profile. Not sure why that is. Not bad, just unusual.
warzi1975
Last seen: 4 hours 18 min ago
Alonefire X40 has also a fresnel lens.
Robert
MascaratumB
MascaratumB's picture
Last seen: 58 min 58 sec ago
Brinyte T28 Artemis! (zoomable flashlight)
dthrckt
dthrckt's picture
Last seen: 9 hours 21 min ago
I had never heard of this. Just watched some reviews. If I didn’t have a maxtoch la60 coming this week I would definitely buy one. So unique!
warzi1975
HaikeLite HT08 is also a fresnel zoomie.
Robert
