Custom high power spotlight
8 posts / 0 new
patrolgr88
Hi guys i would share with you my experience. I have realized two spotlights for my Jeep installed on the front bumper , each one is composed as follow:
1x Bridgelux V13-B, driven at 2.4A for about 13000 lumen; lens Gaggione LLC66N7 FWHM 20.9°
1x  Cree XHP50.2 HD (12V version) driven at 2.6A for about 3500 lumen; lens Gaggione LLC66N7 FWHM  8.9°
1x  Cree XHP50.3 HI (12V version) driven at 2.6A for about 3300 lumen; lens Gaggione LLC66N7 FWHM 7° (not sure)
For a total raw lumen of 39600 lumen (two spotlights)
https://imgur.com/LIe0vLE
https://imgur.com/Sx4DoM0
https://imgur.com/I6DSKQ9
I made the housing with aluminum flat parts and i add an heatsink in the rear. To control the temperature i use two NTC thermistor. In the following some photos of the realized units. Every comment or suggestion is welcome!!
Edited by: patrolgr88 on 08/16/2021 - 13:31
John_Galt
Last seen: 1 month 2 hours ago
Thats a solid build dude. What drivers did you use? Can you turn on the bridgelux separately from the two xhp50’s?
patrolgr88
Thanks! I relized homade boost converters, one for the four XHP connected in series and other two converters one for each COB (my car voltage is 24V). Yes i can turn on the separtely the COB for flod light and the XHPs for spot. Maybe the light from the XHPs with this lens is far too spot
Skylight
Skylight's picture
Last seen: 18 hours 49 min ago
XHP50.3 ? Where did you get them from?
welight
welight's picture
Last seen: 1 week 2 days ago
do yu have any beam shots?
Cutter Electronics Pty Ltd
Web: https://www.cutter.com.au
patrolgr88
X Skylight: I have corrected the description, the HD are 50.2 while the HI are 50.3 from Cutter.
X welight: not yet, but i will do it ASAP
patrolgr88
Some shoots of the lamp, the camera was set with fixed parameters( aperture, exposure, etc…)
Car headlights:
https://imgur.com/ykyt5kt
Only XHP:
https://imgur.com/MCuCTWn
XHP+ Bridgelux:
https://imgur.com/zgkSt3X
jeff51
jeff51's picture
Last seen: 6 hours 1 min ago
Just thought I’d add your images side by side so everyone could see your results.
GoodWork!
All the Best,
Jeff
