Any good 18650 chargers with type-c input?
10 posts / 0 new
dropman
Last seen: 11 hours 54 min ago
Looking for 18650 charger with type-c input.
Xtar PB2S would be perfect, but it charges at 2A which is too high for my 18650 high capacity cells.
Thanks.
YuvalS
YuvalS's picture
Last seen: 24 min 38 sec ago
Search for tp4056 on AliExpress and choose a board with a type-C input
for example
If you want you can solder it to a simple 18650 battery holder
My FW repository
My BLF/OL contest entries: 7th 8th 9th
xtarflashlight
xtarflashlight's picture
Last seen: 1 hour 41 min ago
For your requirements of 18650 charger with type-c input, take a look at our VC4L charger
d_t_a
Last seen: 36 min 49 sec ago
some chargers I notice that use USB-C input (note that most of them will not work with USB-C-to-USB-C cables (unless has some resistor?), but works with USB-A to USB-C cables.
eg. these chargers accept type-C input
- Astrolux SC01 (rebranded Yonii TC1) = single-bay charger (2Amp only)
- Astrolux SC02 (rebrand of Yoni ???) = dual-bay charger
- Astrolux VC04 (rebranded Yonii D4S) = 4-bay charger, accepts 3 input-types (has micro-USB, USB-C and even an Apple lightning port)
- Liitokala Lii-M4 = 4-bay charger
- Xtar VC8 = 8-bay charger (can use QuickCharger 2.0/9v input)
- Xtar ST2 = 2-bay “very very fast” charger (can use QuickCharge or USB-Power Delivery input) = this unit works with USB-C to USB-C (required to take advantage of USB-PD)
There would likely be others, but these are the ones I’ve noticed before.
Of the above, the Astrolux SC01 and Xtar ST2 support Li-Ion batteries only, while the others mentioned support both Li-Ion & NiMh.
wle
wle's picture
Last seen: 13 hours 15 min ago
usually they do not really have an ‘input’
i mean they do, but they already come with their own wall wart
what would usb-c add?
    Daniel Behrman, "The Man Who Loved Bicycles".
-Greg Lemond.
ChrisGarrett
ChrisGarrett's picture
Last seen: 5 hours 41 min ago
While not my preferred charging rate for 18650s, but 2A charging is certainly in wheelhouse for high cap 18650s at just over .5C.
Chris
wle
wle's picture
yeah but the power supply that comes with a charger, should be able to supply the current needed for what it can do
giving it more at the input [60 watt usb-c] or whatever, isn;t going to give it more output
wle
-Greg Lemond.
wle
wle's picture
Chris
also i think my 5 year old charger can do 2A on 4 slots same time..
wle
-Greg Lemond.
buck91
buck91's picture
Last seen: 2 hours 19 min ago
for example
$0.34 + $1.41, a little time and solder. Now thats a BLF special!
ChrisGarrett
wle wrote:
Chris
wle
Totally dependent on the particular charger. I think that my two Opus BT-3400s do two at 1500mA and 2000mA, but 4 at 1A, with a 3A WW.
Chris
