CYANSKY HS6R headlamp - 1400 lumens - Type-C - dual switch - Floodlight, Spotlight & Red LED’s, the perfect light to search for undead missing flashlight reviewers……
Nice Review. So close to my dream headlamp. If only one red LED was UV, and neither flashed. Also would be cool if it had 3 buttons instead of 2. Maybe someday!
I liked it but the retaining clip was really tough to remove but at least that makes the light secure.
With mine, it is impossible to use both emitters on max…When flood is max and I turn on max spot, the flood emitter gets dimmer.I’ve tested it with different batteries, but everytime the same…Do you also have that?
It’s normal, it’s a current limitation. They have an updated version releasing at some point
