Hello, my MF01 Mini doesn’t works, the AUX leds are turned off also the tactile switch. I’ve replaced with new fresh battery and doesn’t works. However if I plug the USB-C cable, the tactile switch goes red, but I can’t turn on the LEDs.
This happend on my return of vacation, before 3 weeks of no use, the battery it’s almost dead and the flashlight is no longer turn on.
Did you try removing head and tail cap, cleaning with dry cloth? Did you try another battery? Is there any evidence of battery leakage? Very often a complete disassembly and reassembly fixes the problem.
Hello, somebody could helps me? I need fix my FL. I dissassambled the driver the mosfet looks Ok, no shorts on drain to source. My bet it’s the atmel 20u… but i cant check it. So, any idea.? Somebody has the schematic?
