TrustFire Minix impressions
32 posts / 0 new
Unheard
Unheard's picture
Last seen: 32 min 58 sec ago
I recently won a TrustFire Minix and have been asked to show it, which I’ll gladly do.
Fig. above, left to right: Nitecore TIP CRI 2017, TrustFire Minix, Fitorch K3 lite
The Minix is a keychain light with a 300 mAh battery and up to 320 lm. It is available in two versions each with a white (5700 K) and either a red (620 nm) or an ultraviolet (365 nm) LED. I like both versions for their use value: The red LED can be used as a beacon while the UV LED has the right wavelength for testing bank notes and documents. So, you have to decide which one is the right one for you.
I got a grey one with UV aux light, and am happy with it. The UV light is really weak, so no headache when using it without protecting glasses (I’m really sensitive here).
Interestingly, the UV light has the blink mode of the red version, so the same firmware is used in both lights even if it doesn’t make any sense. But it doesn’t hurt either.
I’ve measured 5700K, CRI 70. The color rendition is good, I first thought it could be HCRI until I measured it. The beam has a range of 86 m on High, so it’s an all-purpose beam. The spot is not entirely round, also there are rings. Honestly, this doesn’t matter much in the wilderness™.
There’s no PWM in Moon and High. The Low and Mid modes are generated by means of PWM, but at about 15600 Hz I do not notice it.
The UI is very simple: A 0.5 s press brings up white light with mode memory, 1.5 s and you have the auxiliary LED activated. Subsequent clicks switch through the modes. I wish there were no mode memory since there’s no direct Low, but I guess switching it back to Low before switching it off does the job, too.
The light is locked by double-clicking from off. Another double-click unlocks and activates it at the same time. So, it is quite a fast action Thumbs Up .
A single click from off shows the remaining battery capacity (RG-LED in the key, refer to the manual page pictured above).
The Minix features an intelligent temperature control, which is quite unique for small keychain lights. Also, the manual states there’s a low voltage warning. Not sure if it actually offers a LVP.
Charging (USB-C port, cable included) takes one hour. When I watched it, my USB meter showed a max of 410 mA. The Minix was nearly fully charged when it arrived. That makes sense as there’s no way to decouple the battery from the draining electronics, and stocked lights will discharge over time by necessity.
Runtime diagram on High:
Right axis show temperature in degree Celsius. Sorry, forgot it.
Yeah, runtime as stated, excellent temperature regulation. TrustFire can do it Thumbs Up . After 75 Minutes, this thing still was on a good low level.
Love it.
Thanks for reading.
Smile, you cannot kill them all.
Edited by: Unheard on 08/29/2021 - 02:32
Unheard
Unheard's picture
Reserved.
Just because.
raccoon city
raccoon city's picture
Last seen: 7 hours 55 min ago
Does it have any lockout feature?
Unheard
Unheard's picture
Ah, I forgot – yes of course. Double clicking does the trick. Another double click unlocks it. It’s on after unlocking.
raccoon city
Unheard wrote:
Ah, I forgot - yes of course. Double clicking does the trick. Another double click unlocks it. It's on after unlocking.
Awesome!
Thanks for your impressions.
I think I'll get one of these for myself.  :BEER:
longuylander
longuylander's picture
Last seen: 9 hours 45 min ago
Seems very similar to the Fenix E03R in shape and UI, though a little brighter and a little larger battery (and the choice of UV for the secondary light too, of course). Based on the numbers this reports though, the beam is a bit more focused. The Fenix is so floody that I tend to use the high mode just to get any intensity. If the price is right, this might replace the Fenix on my car keys.
raccoon city
Looks like the TrustFire Minix is $18 on eBay.com and $18.25 on AliExpress.
I'll wait until I get a coupon for one of those sites.  :-)
wle
wle's picture
Last seen: 11 hours 52 min ago
i’m supposed to be getting one any day, i won it also
will review
wle
    Daniel Behrman, "The Man Who Loved Bicycles".
-Greg Lemond.
wle
wle's picture
hm i thought it would have both red and UV, now i do not know which one they are sending
or which i would have picked, uv probably///….
wle
-Greg Lemond.
Unheard
Unheard's picture
Have a look at the first picture, top right keychain light:
https://budgetlightforum.com/node/78413
That seems to be a Minix. Not sure if this image was later inserted. Posted 07/21/2021, edited 08/11/2021.
MascaratumB
MascaratumB's picture
Last seen: 6 hours 58 sec ago
Thanks for your review and impressions Unheard Smile I guess I will receive mine in the next days too, let’s see what I’ll get Wink
Unheard
Unheard's picture
Hope you both will be happy!
Feel free to add you reviews here if you wish, but anyway, I’d love to read them.
xevious
xevious's picture
Last seen: 1 day 1 hour ago
I like the shape of this keychain light. It’s more sensible than a tube, which is why Nitecore went with this earlier on with their TIP. But Nitecore botched the UI. What a fiasco. It sounds like this UI solved the problem more sensibly. Press+hold 0.5 sec to turn on. Double-click for electronic lockout. Why couldn’t Nitecore do this? Unreal. I bought several TIP lights for family members. What a disaster. Battery problems. High parasitic drain. None of them are being used now. I don’t trust Nitecore for this type of flashlight any longer.
dthrckt
dthrckt's picture
Last seen: 2 weeks 1 day ago
I would buy one of each if it had a clip
Forsythe P. Jones
Yeah I’ve been skeptical of anything from Nitecore. I have a specific interest in one light (NU05) because of its unique form factor, but I’m not expecting much from it.
The rectangular light that made the most sense to me was the Surefire Sidekick, but Unheard mentions that it has had reliability problems, which seems unfortunate and un-Surefire-like. I hope they can get them sorted. I wonder whether the Sidekick is a “real Surefire” or is something they bought on Alibaba. They dropped the price drastically since introducing it. Before that, though, I’m sure they could have fixed any issues it had.
Funtastic
Funtastic's picture
Last seen: 1 day 18 hours ago
My runtime is way off their rating. I got 35min on High and 58 min on Med. Specs show 56min High, 136min Med. Still need to measure Low. I always state the ANSI spec though
Texas Ace Lumen Tube calibrated with maukka lights
New Zealand store – https://www.piercingthedarkness.co.nz (NZ customers only)
YouTube channel – https://www.youtube.com/channel/UCIUWi2vYp4CWrRkOJM70t_w/videos (Demos for my customers, and reviews)
Unheard
Unheard's picture
Can you post your diagram here?
Funtastic
Funtastic's picture
Room Temp – 20°C without cooling. To get their specified runtime it would of needed to be hotter than the ANSI testing allows of 22 ± 3 °C or perhaps my battery is a dud
Alen
Last seen: 1 week 3 days ago
It’s complicated open the case? Don’t see any screws
for Led access and swap it.
Funtastic
Funtastic's picture
Fairly certain it’s glued. I would have loved a 4000-5000k white led
wle
wle's picture
it’s all glued or at least wedged together[interference fit]
-Greg Lemond.
Funtastic
Funtastic's picture
I’ll have my video review sorted soon. It has very impressive range, I just feel like the low mode is too bright
The runtime is far below the specs. I got 150 min on Low instead of the 327
Alen
I supposed removing the rear cap was enought for pull out all
wle
wle's picture
that is probably how they put it in, from rear cap – but if there is glue it will not come out whole
wle
-Greg Lemond.
Unheard
Unheard's picture
![img]https://i.imgur.com/2Q5vnJs.png[/img]!
Thanks, good analysis of the problem. Steps down too late. The energy management is apparently not perfectly working to meet the stated specs.
Funtastic
Funtastic's picture
That wouldn’t explain why low only got 150 minutes for the 327 stated. I feel like they recorded the moonlight as well
Unheard
Unheard's picture
I’ll measure low on mine, but that will probably take some days.
Funtastic
Funtastic's picture
I really like the light, but wish there was a lower level in between. I’m often using the red because it’s less bright than low
Unheard
Unheard's picture
The lightmeter went out at some point, but the specs are met. This is relative intensity vs. Minutes, low mode. Seven hours later it was still on moon, LED indicator showed yellow.
Your minix might have too much output or too little capacity.
Funtastic
Funtastic's picture
Strange. I measured the battery at 255mAh from a run on Low. Still had battery left to run on moon for 4+ hours, so guessing it would be fairly close to the 300mAh rated battery.
Yours is the UV version. Mine is the Red version which could very well use a different driver
Thank you for your testing. Slightly annoying that the UV and Red versions perform differently
Funtastic
Funtastic's picture
Finally finished
