1x18650 thrower with high CRI?
47 posts / 0 new
negev
Last seen: 13 hours 4 min ago
Are there any 1×18650 tube light throwers with high CRI? It seems like all the throwy emitters have weak CRI, is that just a consequence of how they’re made?
Hikeandbike33
Last seen: 2 weeks 5 days ago
I have a convoy c8+ with sst20 4000k that throws pretty far.
L4M4
L4M4's picture
Last seen: 11 min 28 sec ago
Throwers usually aim for maximum Output, and that’s more the domain of lower Kelvin LEDs, like 4500K and lower – 6500K and High CRI is still pretty rare, because of the high blue light output that comes naturally with 6500K or even higher.
But tbh, I don’t see any advantages in a high CRI thrower, because you don’t see a whole lot to begin with (smal Hotspot) and you certainly can’t see a lot of difference in the colours as well.
For wider beams, that is different, because you use them for close up stuff where you can generally see more
xevious
xevious's picture
Last seen: 1 hour 7 min ago
I agree. A hi CRI thrower is almost a misnomer. You really want neutral white or slightly cooler from that, as the more eye friendly thrower.
negev
That makes sense, what’s the most “neutral” white light that fits my criteria then?
anonymous_user
Last seen: 5 hours 12 sec ago
You can get a KR1 with a SST20 4000K if you really do want the high CRI. If you are fine with just neutral temperature then you can go for one of the XP-L HI or the SST40 in 5000K.
negev
Ehh nah, I want the tube form factor. Similar to the PD32/PD35 from Fenix, I really like that form factor.
JaredM
JaredM's picture
Last seen: 2 hours 13 min ago
Building a KD S3 21700 tube light with a SST20 4000k and 5A or 6A Convoy driver would be your best hiCRI tube thrower. 20-22kcd is my estimate.
Decent CRI from a XPL or XHP35 HI in a 80 or 85 cri bin (good luck finding one these days) will be the middle ground. (maybe XPG2 could be found too). Maybe high 20’s kcd.
A very very good tinted 70CRI XPL HI like a 5D from Hank can satisfy the non-snob. 30kcd should be possible with enough current.
Max throw out of a tube light would be around 60-65kcd with a 1mm² Osram
negev
Thanks, are there any guides you could recommend for doing this? I’m reasonably competent with electronics principles but have never built a flashlight.
JaredM
JaredM's picture
I’m sure there are somewhere here, and plenty of people will happily guide you through any issues too, but it’s really super easy. If you can use hand file, tweezers, and solder two wire joints, you’re set! The host accepts 20mm drivers and 20mm led boards.
The biggest question mark is what driver and UI you want. Convoy’s 12 mode groups are nice for their flexibility.
The light comes pre assembled under the Ekoras brand – model R7. You could start there and swap the emitter later if you like. Everydaysurvivalgear has a review and teardown of the light. https://budgetlightforum.com/node/77360
JaredM
JaredM's picture
Btw, the reason to choose this light over others is that you gain a precious 1-2mm of reflector diameter and also a bit more depth that other tube lights. 21700 is also nice for this style imo since the proportions are better balanced. I’d go to an FW1A (my edc) if you want 18650, but Anduril isn’t everyone’s cup of tea.
negev
Thanks, I’ll have a think about it. I might wait for the S2+ with 219B to arrive first, maybe I don’t need one light that does everything. I could use the Fenix as a thrower and the S2+ for close-up.
negev
The FW1A looks quite short, would it not be better to get something longer in order to have more throw?
negev
Convoy S2+ with SST20 seems like a good option, not sure how far that would throw
negev
Found a good descriptive list of the S2+ emitters here: http://lightpaintingblog.com/flashlight-review-convoy-s2/
Seems like it’s a choice between SST20 (high CRI) or Cree XP-L HI at 4000k, but given what was mentioned at the start of this thread I’m leaning towards Cree XP-L HI in 4000k for more throw/lumens but with (hopefully?) neutral colouring.
Am I on the right track? I guess what I’m really looking for is something similar to my PD32 but that doesn’t turn everything white.
negev
Would love to see max throw distance charted for all of those emitters somewhere.
negev
Looks like a neutral equivalent of the PD32/35 isn’t possible because those emitters only come in 6500k colour, so I’m guessing Cree XP-L HI at 4000k is about as good as it’ll get.
negev
I suppose SST40 might be a good choice too for more power, 5000k is still a bit more neutral than 6500k.
Forsythe P. Jones
Last seen: 39 min 3 sec ago
For a thrower you want a very small led to maximize focus by the reflector or optic, and Osram seems to be the champion of that.
I’d go for a Noctigon KR1 with an Osram W2 led mainly because it’s Anduril and everyone seems to like Hank lights around here:
https://intl-outdoor.com/led-flashlights/noctigon-kr1-tail-e-switch-pock...
I’m sure there are alternatives though. Anyway, look at the candela ratings of the different leds on that page (scroll down) to get an idea of the throw. The Osram would seem to give quite a pencil beam. Next thing after that would be a LEP (white laser).
negev
6000k is too white of a tint, I’m looking for something more neutral.
negev
After more research I’m leaning towards Convoy S2+ with XPL HI in 5000k tint, I think that should be a good balance between throw and neutrality.
negev
Was about to order it but I noticed several reviews where people chose:
XPL HI U6-3A 5000-5200K
with:
7135*6 output current 2100mA
from here: https://www.aliexpress.com/item/1005001981991584.html
rather than 7135*8 which would be the highest output driver. Why would you not want the strongest driver? Surely output can be regulated through the software if you want to run it on a lower brightness.. so I think I’m missing something.
negev
Oh I guess there’s no 80% mode in the software, so maybe some people didn’t want quite so much brightness?
negev
I looked up the max forward current of the Cree XP-L HI v3, 3A, so I think the biggest driver is the one to get. Will wait before ordering though as I’m sure others on here know more than me.
raccoon city
raccoon city's picture
Last seen: 7 hours 27 min ago
How about this?
https://www.aliexpress.com/item/32989670019.html
Only 5000K, but I couldn't find an SST-40 C8 that's any warmer from Convoy or Sofirn.
EDIT:
Oops.
You're looking for a tube light.
They don't throw that far, though.
Rayoui
Rayoui's picture
Last seen: 5 hours 11 min ago
The original version of the driver had no thermal protection. 2.8A is a bit much for the S2+ host and with 8×7135 chips it could quickly reach very high temperatures. 6×7135 is more manageable.
The newest version of the driver does have thermal management but I don’t know if that is what ships with this light.
negev
Makes sense, thanks. I’ll order the 6×7135 then.
raccoon city
Have you checked out the WildTrail (former LuckSun) BLF-D80v2?
https://budgetlightforum.com/node/66255
It's a compact thrower that's kinda close in size and shape to a tube light.
(It fits in my shorts/pants pocket just fine.)
2-26350-P91
2-26350-P91's picture
Last seen: 3 days 13 hours ago
Contact Simon first before ordering. If there is thermal management order the 2.8A version for maxium throw.
Euclid List: Acebeam K60/Jaxman M8 XP-L HI/Jaxman X1 XP-L HI/Fenix SF18/Fenix E05 2011/Convoy M1 XM-L2 OP/Convoy C8 XM-L OP/Jetbeam Jet-1 MK/Olight S2 Baton/Skilhunt E3A Neutral HA3 Slate Blue/Fenix PD40
Feel In Hand: Surefire Z2 McClicky Hard Press Boot/Eagle Eye X9/Convoy BD01/Fenix TK47/Convoy L2 2 Cells/ArmyTek Predator Pro/Fenix PD32 2016
Favorite beams overall no specific order: Jetbeam Jet-u Optisolis 3500K/5000K virence/Jaxman X6 Hunter XHP50 5000K 90CRI/Oveready Defense Light Surefire P91/ Surefire C3 Malkoff M61 SHO 219B 4000K/McGizmo Sundrop Nichia 083/ Jaxman E2 219B 4000K/PflexPro Convoy S2+ 219B 4000K OP Reflector/Emisar D18 219B 4500K Flood Optic/Emisar D18 219B 3500K Flood Optic
Favorite Throwers: PflexPro Convoy L2 XP-L HI 3A/PflexPro Convoy C8 XP-L HI 3A/Fenix TK 47/Convoy 4x18A SBT90.2/Jaxman X1 XP-L HI 3C
Favorite EDC: Emisar D4V2 XP-L HI 5D/ZebraLight SC600 III HI/PflexPro Convoy S2+ 219B 4000K Triple/Lumintop EDC18 XP-L HI 3A/Maratac AA Titanium 219B/Emisar D4V2 219B 4500K/Emisar D4V2 219B 3500K/Zebralight SC64w HI/Sofirn SC21/Zebralight SC62/L3 Illumination L10 219A
Lights coming in: Skilhunt E3A Neutral HA3 Slate Blue/Convoy S2+ 219B 3000K 3500K 4500K OP Reflector/Convoy M21B GT FC40 4000K/Convoy M21B XHP 35 HI 4000K OP Reflector/Convoy L21B XHP 35 HI 4000K/Convoy L21B KW CULPM1.TG/Convoy C8 XP-L HI 5000K OP Reflector
Favorite lights per dollar: Convoy S2+ 219B OP Reflector/Black Lumintop Tool 219B/Jaxman M8 XP-L HI 3C/Jaxman M8 4000/5700K 219B OP Reflector
Favorite Soda Cans: Noctigon Meteor M43 XP-L HI 5000K/Emisar D18 219B 4500K Flood Optic/Emisar D18 219B 3500K Flood Optic/Emisar D18 XP-L HI 5000K/ Fireflies ROT66 219B/Fireflies ROT66 219B V2/Sofirn Q8 XP-L HI/Klarus G30
negev
Okie doke, have requested cancellation and sent a message.
I also have an S2+ with 219B on the way which seems to only have a 7135×8 driver and no other options, so guessing that one has the thermal protection and I’m guessing it’ll work fine with this one too, so I guess it probably doesn’t really matter.
negev
Actually it looks like the S2 is a better choice for throw, the beam is more concentrated.
