Convoy driver problem
8 posts / 0 new
Kyleag89
Last seen: 4 days 5 hours ago
Hi guys I have another Convoy 7135 2.8a driver that is only working on 100%.  I soldered 2 380mv 7135 chips on for a total of 10 chips.  I put it in a Kaidomain p6 drop in to replave the bd39 driver it had.  The soldering went well and was my best job to date I thought.  The same thing happened to me last month while adding 2 chips.  What gives with these older style 2.8 7135s?  Ive soldered many other types of driver with no issues.
treellama
Last seen: 6 hours 52 min ago
Check for shorts against the reflector?
MascaratumB
MascaratumB's picture
Last seen: 8 hours 7 min ago
Probably any contact with the solder from the chips and the pill or something. I would not focus on the reflector but on the driver/ spring/chips.
I had the same issue once, but I never tried to resolve it (the light works well with only one mode).
Kyleag89
Ive never tried anything other than inspecting my joints to make sure they weren't contacting something they shouldnt.  The first light i wanted 1 mode anyways but this new one i want the 4 different brightness modes.  The drop in has an XM-L2 which mounted in a KDlitker E6 host.  It gets very warm quickly!
Henk4U2
Henk4U2's picture
Last seen: 2 min 30 sec ago
If the light has only one mode (“Turbo”) the cause is probably a short with the body. This can occur with any part of the driver that is in direct contact with the black lead to the emitter(s).
You are a flashaholic if you are forced to come out of the closet, to make room for more flashlights.
Kyleag89
Thanks so much everyone I found the problem with your help!  The reflector is touching one of the leads to the LED.  As soon as I removed the reflector the mode groups worked, now to fix my soldering job...  They really don't leave much room for anything inside a flashlight.
MascaratumB
Kyleag89 wrote:
Thanks so much everyone I found the problem with your help!  The reflector is touching one of the leads to the LED.  As soon as I removed the reflector the mode groups worked, now to fix my soldering job…  They really don’t leave much room for anything inside a flashlight.
Glad you made it Wink
After all, my thought about the soldering was wrong!
Hope you enjoy the light now !
NeutralFan
NeutralFan's picture
Last seen: 6 hours 15 min ago
You could also try some Kapton tape.
I’d rather use my flashlight around the house than turn on the lights.
