Need dc connector for SkyRC MC3000
4 posts / 0 new
lordlupulin
Last seen: 1 hour 42 min ago
The dc barrel plug on the end of the switching power supply for my MC3000 got crushed off. Anyone know what size I would order/part number etc? So I can repair?
Edited by: lordlupulin on 09/09/2021 - 21:44
SemiNormal
Last seen: 5 hours 52 min ago
lordlupulin
Thank you! I was hoping to only have to put a new barrel plug on though.
def_nvar
Last seen: 23 min 51 sec ago
just measure outer diameter of the plug…
standard size for barrel plugs is 5.5mm OuterDiameter 2.1mm InnerD (5.5mmx2.1mm)
https://electronics.stackexchange.com/questions/59595/how-can-i-tell-the...
afaik the connector on this device is center-positive.
there are barrel plugs that are designed to be soldered to a cable by hand.
if you don’t have a soldering iron, consider getting one, it’s quite handy.
also order appropriate heat shrink.
otherwise there are barrel connectors that can just be screwed but it’s clunky and a wire might come loose, make a short and fry the power supply.
in any case you just need sidecutters, screwdrivers, needle nose pliers and optimally a multimeter for checking polarity and voltage.
otherwise red tends to be positive and black negative.
