S2+ running quite hot
16 posts / 0 new
negev
Last seen: 8 hours 39 min ago
I have two S2+ that were sold with thermal regulation, after ~30min on full power they are both too hold to hold, is that normal?
zoulas
zoulas's picture
Last seen: 6 hours 47 min ago
Yes, mine does the same. Actually after 15 min on high.
stephenk
stephenk's picture
Last seen: 1 day 1 hour ago
Yes, Convoys with thermal regulation do run hot. That’s normal, and not really an issue in normal use (I usually run them on 35%)
Be aware that the older 8*7135 drivers have no thermal regulation, and will get very hot to touch if left on 100%, but have been tested on this forum to not exceed temperatures that are dangerous to li-ion batteries.
max
max's picture
Last seen: 1 hour 13 min ago
Yes it is normal, depending on the driver and battery of course.
For example, the S2+ that Simon is selling in his AliX store, some come with his 5 amp drivers (your choice of 4 mode or 12 mode-groups), but in either case it's the 5 amps that matters concerning heat. As he mentions repeatedly these drivers have temperature control of 55 degrees C (131 degrees F). As you have found out 55 degrees C is to hot to hold. This should not be surprising?
So, 55 degrees C is HOT in my opinion, so your post asking the question if a little puzzling to me. At this temperature it's too hot to touch, in my experience anything over about 45 degrees C (113 degrees F) is to hot to touch w/o experiencing burns.
In my very recent experience, the temperature control is not perfect and I've seen 71 degrees C (160 degrees F) measured at the light's head. This was after running only running 10 minutes. And the more time you let it remain at 100% the temperature migrates to the body and tail of the light so I had to use gloves to pick up the light and switch it off.  Also, even the 2.8 amp drivers (7135*8) will drive an S2+ to be too hot to hold after 30 minutes.
So please explain to me why you are asking about the S2+ and thermal regulation and you not thinking why this would be too hot to hold?  Did you think the thermal regulation was set at a much lower temp than 55 degrees?
Just wondering and trying to help.
 max
Lightbringer
Lightbringer's picture
Last seen: 44 min 5 sec ago
All of my S2+es are 2.8A or less, no “hot” (haha) rods.
Used one via ceiling-bounce to light up a dark room for 5-10min. Got so hot I literally couldn’t even grab it long enough to shut it off, had to use a teeshirt as a pot-holder of sorts to just grab it and poke at the tailswitch to shut it down.
Even so, I had to wait a rather long time for it to cool down enough to even pick it up.
Yah, they get hot and in a hurry. Great thermal path, gotta admit.
negev
It’s not a problem for me, I didn’t know what temperature they were set to so was just curious. It’s easy enough to kick it down to 30% when it starts getting hot. I actually prefer this over the aggressive temperature throttling of my Fenix because you can run on max output for longer. Would be really interested to see the output curve.
max
max's picture
Yea, you can view the S2+ description here as an example:
https://www.aliexpress.com/item/1005001939842575.html?spm=a2g0o.cart.0.0.1e193c00Fa02XZ&mp=1
Although these run hot just as the come from Simon, I quite often buy these and do the sense resistor mod and up the output to 6.6 to 6.8 amps.... now they run hot within only a couple of minutes and that's fine with me. I then step-down to 30%. But bright as heck for the first two minutes!  BTW, i measure tail cap amps and in these hot-rod lights the 30% level is around 3 amps.  If i need a light that needs to stay on for 30 minutes or more than i use one of my other dozens of lights (I'm a flashlight-aholic).... i have lots to choose from.
 max
zoulas
zoulas's picture
After 15 minutes on high, mine gets hot enough where I can barely hold it by the tail cap.
wle
wle's picture
Last seen: 14 hours 12 min ago
yes mine gets pretty hot at 2 minutes
also depends on ambient temp, and whether or not you are holding it, and how much/tightly
your hand will keep some of the heat in
    Daniel Behrman, "The Man Who Loved Bicycles".
-Greg Lemond.
negev
Are there any output curves for the S2+? Would be quite interesting to see how the output regulation compares to a Fenix light
mortuus
mortuus's picture
Last seen: 11 hours 33 min ago
u cant compare convoy to fenix really.
...where Frugal meets with Flashlight!
              つ ◕_◕ ༽つ
negev
I’m just interested to see how much step-down there is with the convoy light when it’s only regulating above 55C.
mortuus
mortuus's picture
if both are the same size it cant be that big difference beteween them but i dont know since i dont own any fenix lights.
              つ ◕_◕ ༽つ
zoulas
zoulas's picture
I think the S2+ step-down is when you physically put the light down. I don’t think it has any ATR. It’s a $9 light. My personal favorite.
wle
wle's picture
SUPER FOR THE MONEY S2+
-Greg Lemond.
lfb
Last seen: 2 hours 55 min ago
Output and regulation depends on the LED and driver used, but usually sits around 35% mode. Fenix usually uses both timed and temperature step down, so the flashlight only gets hot if you activate turbo repeatedly. Another difference is that buck driver is more efficient, generating less heat, mainly with full battery.
