Need help with parts
35 posts / 0 new
negev
Last seen: 9 hours 47 min ago
I want to build a triple with Nichia 219Bs, I can find the LEDs on aliex but can’t find a 16mm triple mcpcb for them. Klaidomain only seems to have 20mm versions, where can I get these?
TMaxxJJ
Last seen: 5 hours 25 min ago
You’ll need a 20mm mcpcb if I remember correctly from my builds without looking back. The mcpcb of a triple sits on the spacer on pill, not within the pill like a single.
negev
Ahh ok, thanks.
NeutralFan
NeutralFan's picture
Last seen: 1 hour 54 min ago
Here are some pics of a spacer that will hopefully help:
I’d rather use my flashlight around the house than turn on the lights.
negev
My plan so far for my first modding adventure is:
1. Get a new S2+ with the SST40 emitter, because that will come with a 12-mode 5A driver already soldered to the pill
2. Put 3x Nichia 219Bs on an mcpcb
3. Swap the SST40 emitter board with the triple Nichia one
It looks like this triple here: http://kaidomain.com/KDLITKER-3TI-Triple-DTP-Copper-MCPCB-for-Cree-XP-Series-or-Nichia-219-Series-or-3535-LEDs-Individual-2pcs
has an option to get a lens with it, so might as well do that unless there’s something else that’s better?
Just not sure about the spacer, where to get it, what size it should be etc. Would be grateful for some tips.
chops728
Last seen: 1 hour 19 min ago
First off the wires on the driver will be too short —- so you’ll have to remove the driver any way —- there use to be a guy selling all the different spacers and pills here on BLF
https://budgetlightforum.com/node/45343
MoreLumens
MoreLumens's picture
Last seen: 5 hours 59 min ago
Spacer is the hardest part to get, but there is choices.
Kiriba-ru has restocked those just while ago:
This shop also sells them:
https://www.mtnelectronics.com/index.php?route=product/product&path=25_9...
They also have aluminum version.
Gunga
Gunga's picture
Last seen: 7 hours 31 min ago
I have an aluminum spacer. Might have some Nichia on a triple too
Speed2z28
Last seen: 1 day 4 hours ago
What’s your overall goal with this project? Is it even worth the money when for a small amount more you can get an FW3A or FW4A with a discount code, and just reflow the factory MCPCB with 219B’s, or just get an Emisar D4V2 with the 219B’s? This was the cost breakdown that I came too,
$17.14 Convoy S2+ sst40 in black
$7.24 three bare 219B’s from Convoy
$3.04 triple 20mm MCPCB from Kaidomain
$1.20 silicone wire from Kaidomain
$12 for copper spacer from kiriba-ru, $4 spacer + $8 shipping
$3 optic
$43.62 total
FW3A or FW4A with a discount code $40, $7.34 for 3 or $8.38 for 4 bare 219B’s from Convoy, a total of $47.34 for an FW3A with reflowed 219B’s or $48.38 for an FW4A with reflowed 219B’s. An Emisar D4V2 with 219B’s is $50 shipped.
Haukkeli
Last seen: 2 hours 38 min ago
$3 optic
$43.62 total
For me the tinkering is funniest part of the hobby. It is also much nicer to use something you built yourself.
negev
Exactly that. I already have one of these built by someone on here (merlot), however I’d like another one in a different colour and with the newer-style square threads so I want to learn to build them myself. Not really bothered about cost. They’ll make pretty cool birthday and xmas gifts too.
MoreLumens
Building triple S2 is like must if you are into flashlights. There is no way around it.
negev
Last night was the first time i went out in the dark with it for a walk. It’s glorious, absolutely glorious. Need to build more of them now!
chops728
Watch out it’s addictive — I think I have some where around 25 Triple/Quads
negev
Is a quad possible in an S2+ or are you just creating too much heat at that point?
MtnDon
MtnDon's picture
Last seen: 53 min 33 sec ago
I don’t think you can find a quad optic that will fit an S2. Maybe make a quad mule?
negev
What gauge of silicone wire should I get to build a triple?
negev
also is there any reason not to just get this: http://kaidomain.com/Triple-Nichia-219BT-LED-Emitter-with-KDLITKER-20mm-x-1_5mm-DTP-Copper-MCPCB-Parallel-w-optics and then now have to reflow emitters onto a mcpcb?
As far as I can tell 219BT and 219B are the same chips
PeyoX
PeyoX's picture
Last seen: 24 min 41 sec ago
Afaik is different CRI
Limited English, still working on it.
negev
Are you sure? The 4500k option says CRI 92..
negev
Also the Nichia website only lists the 219bt-v1 part, there’s nothing for 219b. I think it’s the same chip and the T is just not always used
PeyoX
PeyoX's picture
Oh, sorry. I checked the AliX store lol
MoreLumens
They are Nichia NVSL219BT R9050 D240 4500K CRI92 that Kaidomain sells.
More of those in this thread:
https://budgetlightforum.com/node/78969
negev
Ah thanks for that, will buy the LEDs from Simon then.
Can anyone recommend good types of solder paste and flux that are available in the uk?
JenkinsMatti
Last seen: 4 hours 42 min ago
This may be a dumb question, and if so I apologize; but what do you do with “25 Triple/Quads”?
Why have so many?
JenkinsMatti
Please excuse my obvious ignorance, but I am trying to learn. What is a “quad mule”?
chops728
JenkinsMatti wrote:
This may be a dumb question, and if so I apologize; but what do you do with “25 Triple/Quads”? Why have so many?
Because I’m an Addict Sick
MtnDon
MtnDon's picture
A “mule” is any light that does not have a reflector nor an optic for the led’s. Pure floodlight.
an example.
JenkinsMatti
Well, you said it. Far from me to argue.
JenkinsMatti
an example.
Thank you for a straight forward answer that is easily understood.
Much of this terminology is beyond my understanding until explained.
If I might ask, what brand lights are those in your picture?? I like the look of them.
MtnDon
MtnDon's picture
Emisar is the brand.
(Not my picture. I found it online))
Emisar is from https://intl-outdoor.com/led-flashlights.html
