CD4511BE Decoder LED Driver Using Problem
2 posts / 0 new
Glviybalspec
Glviybalspec's picture
Last seen: 3 days 21 hours ago
Hardware:
CL5631BW – 3 Digit 7 Segment Display
The BCDA inputs are wired with 680 Ohm Resistor and the outputs are wired with 680 Ohm Resistors to the 7 Segment correctly.
Problem:
All Numbers shown on the Display are inverted (All segments that should be illuminated are dark and vice versa).
I think the decoder is for Common Cathodes.
Is it possible to change the mode for the decoder to Common Anode? Thank you in advance.
Glviybalspec
kennybobby
kennybobby's picture
Last seen: 4 hours 41 min ago
No but maybe you could use a Common-Anode BCD-to-7 segment driver such as the DM7447,
DM7447 datasheet
Now i used to think that i was cool,
drivin' around on fossil fuel,
until i saw what i was doin',
was drivin' down the road to ruin. --JT
