I have spent time researching what are the best/most efficient/safest chargers for 10440s, but have not found any recent/new chargers for them. Earliest I could find (as in posts or comments) are from early 2019. I am still learning, but I have read that ideally it is best to charge 10440s at 0.2 A. One charger that I found is the Opus BT C3100 as it can be set to have a CC at as low as 200mA. There is also the XTAR MC2 2 which can charge at 2 x 0.25 A at the slowest, but that one can not be manually selected. I would like to know if there is something better and more recent for safely and efficiently charging these little guys? Most chargers that I have found charge at 0.5 A at the slowest, which I know is too fast for 10440s and thus not recommended.
I recently looked for the best charger for 10440, 21700, and NiMh. I ended up buying a Nitecore UMS2 as you can manually select the current all the way down to 100mA, and it supports everything I needed.
Worth noting the Opus BT-C3100 charges and discharges using 2A+ pulses so not ideal for tiny batteries. It can trip sensitive protection circuits even at low selected current. The Gyrfalcon All-44 and All-88 will do 100mA charging. Has very slow termination but mine usually leaves rested cells at exactly 4.20V if that’s your thing. The SkyRC MC3000 will of course go down to 50mA charging but much more expensive.
My Nitecore UM2 and UMS2 can have a manually-selected charging current of 100mA. In some places, even HKJ reports that the Nitecore UMS2 can have a manually-selected charging current of 100mA. For example, https://lygte-info.dk/info/roundCellChargerIndex%20UK.html
Perhaps the UMS4 has a minimum manually-selected charging current of 300mA.
On YouTube there is a video by “Nitecore Store.” The video was made 5 years ago. At a time of around 2:10, manual-selection of charging current was begun. The display changed rapidly, but I saw “100mA” on the screen of the Nitecore UMS2 for a fraction of a second.
