Coast battery swap
3 posts / 0 new
Newfie
Coast battery swap
I have 3 coast lights (g50, g45, poly steel 400). Both g series use the 3 x aaa cartridge while the polysteele uses 4 x aaa.
I’d like to replace the batteries with the USB C rechargeable battery. I was wondering if a 18500 would fit or are there any other options?
PS I can take some pics and measurements if that helps?
jeff51
jeff51's picture
Last seen: 3 days 48 min ago
Depends on how the batteries are configured in the lights.
If your 3xAAA has a battery holder like the one below, an 18650 should be easy to replace it since the voltage is essentially the same.
Doing a swap for 4xAAA might work depending on how the driver is setup and how the batteries are configured in the light.
Pics would help.
All the best,
Jeff
Muto
Last seen: 7 min 59 sec ago
Have a couple cheap lights that use 3AAA and use 18500 with a rubber band wrapped around it to center the battery. The 18500 is non protected/no charger chip onboard.
Works well with great runtime.
HTH
Keith
The difference between Hoarding and Collecting is the illusion of Organization
.“I will get one of flashlight from patrol car”
“History doesn’t repeat itself, but it sometimes rhymes,” Mark Twain
After the Apocalypse there will be only 2 things left alive, Cockroaches and Keith Richards
