KR1 W2 off center
8 posts / 0 new
JagerLion
Last seen: 6 hours 56 min ago
KR1 W2 off center
My KR1 arrived with the W2 emitter visibly off center, causing an egg shape around the hotspot. It’s more noticeable than the picture below. How much does this affect throw and what are my options?
I shoot magic into the darkness!
UNBLF
UNBLF's picture
Last seen: 3 weeks 4 days ago
I believe the best option is to email Hank and figure it out. From my experiences Noctigone / Emissar has pretty good customer service.
I recommend against doing anything with the reflector on your own. Most reflectors are coated w/ very soft metal that scratches on even the most gentle touch.
SammysHP
SammysHP's picture
Last seen: 2 hours 6 min ago
You can loosen the bezel slightly and shake it a little, then tighten it again. Repeat until you’re happy.
Frostcream
Last seen: 2 weeks 1 hour ago
I’d definitely do this.
JagerLion
Hey, that worked! Thanks! Took several attempts but the hotspot is quite improved. The best solutions are the simplest.
raccoon city
raccoon city's picture
Last seen: 1 hour 38 min ago
Nice fix, SammysHP!  :THUMBS-UP:
JagerLion
Before and after. W2 is slightly rectangular so the hotspot is centered in an oval now instead of off-center in an egg. Thanks again.
Unheard
Unheard's picture
Last seen: 51 min 8 sec ago
Same with XP-L Hi gaskets. The reflector fits, but the gasket has some play around the LED. Can take some time to get it right.
Smile, you cannot kill them all.
