H17fx driver not working
2 posts / 0 new
kltye
Hi all,
Long time flashaholic, first time custom light builder. I purchased an h17fx driver, plus a Samsung LH351D and a Nichia 219c from mtnelectronics. After putting it together, it didn’t work, so I disassembled it, and found that my cold solder joint on the LED board caused the negative lead to disconnect. Unfortunately, fixing that didn’t fix the light, and from using a voltmeter to test the output of the driver, I’m not getting any voltage when supplying 3.7 volts from an 18650 cell.
Did I toast the driver by turning it on without connecting an LED to it? If not, am I missing any troubleshooting steps? I’m supplying voltage directly to the brass button and the outer ring of the driver to test the driver directly.
raccoon city
raccoon city's picture
Last seen: 42 min 20 sec ago
Location: Palm Desert CA ~ West Coast is the best coast
Thanks for joining the gang, kltye!
209_milla
