New coming soon! Infrared Flashlight, 5000MW OSRAM IR LED, 5000mW/350 meters, 21700/18650 Battery, Type-C
Hi, everyone. Our new infrared flashlight Cyansky k3-i8 is coming soon! I believe many people will be curious about what kind of product it is. Today we will take a closer look.
Much different from the previous lighting gears, the k3-i8 IR flashlight allows you to monitor your target for a long time, aim at and shoot the target conveniently and precisely without being exposed.
First, Let’s take a look at its appearance.
It is similar to the K3, but a little smaller than the K3.
Product Features
1,1*OSRAM SFH 4770S 5000mW 850nm IR LED with 50,000 hours lifespan.
2,Powered by one 5000mAh 21700 Li-ion battery and compatible with one 18650 rechargeable Li-ion battery.
3,Intelligent and High-efficient constant current circuit.
4,Single tactical tail switch. ,
5,A6061-T6 aviation-grade hard aluminum alloy material shell.
6,Premium type HAIII hard-anodized anti-abrasive finish.
7,Vacuum electroplated aluminum reflector.
8,Toughened ultra-clear glass lens with anti-reflective coating for high light transmission.
9,Anti-rolling design equipped with a removable clip.
10,Maximum power: 5000mW.
11,Beam distance: 350 meters
12,Waterproof Level: IPX8.
13,Impact Resistance: 2 meters.
14,Working Temperature: –30-50℃.
15,Weight: 120g(Without Battery, Battery Weight: 73g)
16,Size: 40mm (Head Diameter) * 25.6mm (Body Diameter) * 148.6 mm(Length)
More info, welcome to K3-I8 Long-range IR Tactical Flashlight (5000mW / 350M) – CYANSKY Light.
Battery and Charge
5000mAh 21700 Li-ion battery with Type-C charging port and compatible with one18650 rechargeable Li-ion battery.
For more information please visit Cyansky website >> K3-I8 Long-range IR Tactical Flashlight (5000mW / 350M) – CYANSKY Light.
I would like to see IR shots of this model...
Hi, the IR shots would be posted in the near future, pls pay attention to our dynamics, thank you, and have a nice day.
End result documented by photos is dynamics
The parameters-to-size ratio looks great. Cant to wait for its tactical use.
