[Review] Cyansky K3 || Luminus SFT-40-W, 1600 Lumen, 1 x 21700 || Outdoor Beamshots, Output and Power Regulation Measurements
14 posts / 0 new
bilakos10
bilakos10's picture
Last seen: 1 day 11 hours ago
The flashlight was sent to me by Cyansky for review.
Here's the product's link: Cyansky K3
The flashlight comes in a nice cardboard box.
Here's a closer look at the manufacturer's specifications.
The following accessories are included in the box:
  • Cyansky branded 21700 battery
  • Wrist lanyard (with some nice braiding!)
  • 1 x replacement tailcap boot
  • 2 x replacement o-rings
  • Pocket clip
  • USB Type-C charging cable
  • Carrying pouch
  • User manual.
The carrying pouch is made out of nylon.
The overlapping flap is secured in place via velcro, while a belt loop is present in the rear.
The Cyansky K3 comes with a black matte anodization.
The overall fit and finish is excellent.
Its body comes with parallel knurling for better grip.
The flashlight is dual switch operated.
The rear mounted, forward clicky switch is used solely for controlling the power on/off of the flashlight.
An e-switch mounted in the lower part of the head is responsible for controlling the mode switching.
The switch is made out of sandblasted metal and sits also flush with the surface of the flashlight.
A mildly crenulated bezel is in place to protect the glass lens.
Its worth noting that the bezel and head is a unibody piece.
Looking down the head, we can see a smooth reflector along with a Luminus SFT-40-W.
The centering of the emitter is perfect.
The driver seems press fit and glued.
A brass tab is used as the positive terminal in order to ensure maximum efficiency
The rear switch boot sits below the two metal flaps, which allows the flashlight to tail stand.
The tail houses a copper spring.
The spring board is held in place via a retainer ring.
Here's the tail all taken apart.
And a  close up shot of the forward clicky switch.
Both the front and rear threads are square cut and are anodized, which allows the flashlight to get mechanically locked out.
A detachable pocket clip is also included.
The clip is quite stiff and provides excellent retention.
As already said, the Cyansky K3 comes with a 21700 battery.
The battery also includes a regular USB Type-C charging interface.
Once plugged in, a little indicator LED will shine up inform the user about the charge's state
green: full, red: charging.
User Interface
Being a tactical flashlight, the Cyansky K3 comes with a simple and forward UI.
Here's all the actions supported by the flashlight's firmware:
Turn on/off: Single press (rear switch).
Mode cycle: Single press (side switch) ( Low > Mid > High > Turbo > Low > ...)
Strobe: Long press (side switch)
Mode memory is present.
Low Voltage Warning and Low Voltage Protection is also present. The flashlight will flash 3 times whenever the battery gets low. I measured the cutoff voltage at 2.8V
Output
Here's my output measurements along with the respective current craw per each output level.
The Cyansky K3 push more than 1500 lumens at Turbo.
The manufacturer's specifications seem to be pretty accurate.
Mode spacing is excellent!
Power Regulation
Here's a power regulation graph that I've created for the K3.
What we can see in the graph:
  • Turbo's current draw is proportionate to the input voltage
  • High is fully regulated up down to 3.3V
  • Medium and Low are fully regulated for the whole span of the battery's voltage.
  • Turbo and High will stepdown to Medium once the battery's voltage < 3.3V
  • Medium will stepdown to Low once the battery's voltage < 3.1V
Outdoor beamshots
And here's a few outdoor beamshots.
Bottom Line
The Cyansky K3 is a great tactical flashlight.
Its driver shows signs of great regulation and its Luminus SFT-40-W emitter is basically a dedomed SST40 and is great at producing a good balance between throw and output!
Edited by: bilakos10 on 09/26/2021 - 15:45
Rusty Joe
Rusty Joe's picture
Last seen: 4 hours 6 min ago
Thanks.
My review mirrors your own and will be out soon. Mine seems to have artifacts in the beam, but beyond that, it’s a flawless light.
Rusty Joe
Rusty Joe's picture
I’d change the title from “K6” to “K3.”
TIFisher
Last seen: 1 day 19 hours ago
Nice review, sir. As always, love your beam shots….distances???
Noting the two solder blobs on either side of the anode nubbin on the driver, will the light work with flat top cells?
Dual switch is the real deal killer for me. I just don’t get the trend.
Sirstinky
Last seen: 54 min 42 sec ago
Those are interference bars meant to protect the driver from a cell inserted backwards. I tested this light a while back. No, flat tops do not work. Button top only.
bilakos10
bilakos10's picture
Totally mixed up the naming Smile Thank you for notifying me.
Looking forward to your review!
Rusty Joe
Rusty Joe's picture
How clean is the beam? Mine has some artifacts.
bilakos10
bilakos10's picture
No visible artifacts on mine.
Is there a chance that your emitter is not perfectly centered?
Cyanskyflashlight
Cyanskyflashlight's picture
Last seen: 2 days 22 hours ago
Great review, thank you, Bill. Thumbs Up
Rusty Joe
Rusty Joe's picture
Nope, it’s centered, but for some reason, there are some notable artifacts. Still a top-game light.
Sirstinky
The beam on mine is clean.
Mark je do
Mark je do's picture
Last seen: 1 week 3 days ago
Good job, bro. Maybe add some pictures will be more interesting?
Rusty Joe
Rusty Joe's picture
Unfortunately, there is no way to do that on this forum without uploading to some online host since we can’t upload directly here. And some hate doing that (I certainly do).
Funtastic
Funtastic's picture
Last seen: 2 days 20 hours ago
Cyansky have offered me this to review and I get excellent outdoor photos, so maybe wait for that.
Texas Ace Lumen Tube calibrated with maukka lights
New Zealand store – https://www.piercingthedarkness.co.nz (NZ customers only)
YouTube channel – https://www.youtube.com/channel/UCIUWi2vYp4CWrRkOJM70t_w/videos (Demos for my customers, and reviews)
