Need input to help with D4 purchase SST20
5 posts / 0 new
beam0
beam0's picture
Last seen: 1 hour 22 min ago
Considering a D4 need help to decide on the emitters, right now it’s between SST20 5000K and SST20 4000K 95CRI.
I had previously decided on the XPL-HI 5000K, however that option is not currently available from IO.
XPL 4000K is maybe a bit too warm for me, so the closest thing to stay in the highest output range is SST20, I like that it’s more affordable without the $10 up-charge anyway, and with only a loss of 100lm over XPL-HI. I don’t have any experience with SST20 but I read the 4000K SST40 looks a bit cooler than 4000K XPL. I’ve also read it heats up faster or gets hotter than XPL-HI. Any info will be much appreciated.
Neutral White SST20 5000K
or
Neutral White SST20 4000K 95CRI
or?
zoulas
zoulas's picture
Last seen: 9 hours 17 min ago
A lot of people on this forum are nuts over CRI so opinionsmay be biased. At the end of the day, it’s up to you.
ChrisGarrett
ChrisGarrett's picture
Last seen: 46 min 30 sec ago
I went with the SST 20s at 4K, on my D4V2 and Nichia 219 Cs on my V1.
Not complaining a bit, but I’m not a tint/beam pattern whore.
Chris
metroGnome
Last seen: 1 week 3 days ago
5000K SST20s have a very, very green tint at low power, so between those two options I would definitely go with 4000K. If you’re dead set on 5000K, you could go with E21As if you’re alright with having a bit less output in exchange for excellent CRI and tint. You could also email Hank and see if he has some 5000K 219Cs laying around, too.
buck91
buck91's picture
Last seen: 12 hours 44 min ago
I love the SST-20 4000k in everything I’ve got or put it in. It lacks the rosy warmth of a 219b but it also lacks the cat-puke green of LH351D while still retaining good efficiency. As far as color temp, think of an old P60 module on fresh batteries and then add a healthy bit more towards neutral. Just a dang effective balance IMHO.
