EDITED*After using all 3 extensively during the winter I have changed my mind. Fenix is the new winner.
The reason for changing my mind is because the Skilhunt has an extremely irratating 3 flash mode with main light once the battery power dips below 3.3v.
See—-> Skilhunt h03 - light flashing off normal behavior?
Its just starts flashing the main light every 60 seconds 3x in a row. Blink-blink-blink while you are trying to work. Dimming to a lower or the lowest level wont fix the issue. I have completely stopped using the skilhunt at this point. So both my skilhunt are broken!!!
I cleaned the threads on the Fenix over the winter (not sure why a brand new light needed cleaning but oh well) and it resolved the problem at startup of going into a diagnostic mode if you didnt hold the ON button long enough. I now have the hang of it!
Armytek is junk! You cannot push the button with gloves on and its O rings get destroyed when removing cap. I wish I could return it!
Fenix has the most comfortable headstrap by far. Its my goto light at this point and the strap is light-years about the other two. Fenix also has red mode wiich comes after white so I hold my finger over the lens while depressing LONG for red.
So Fenix is the winner!
END NEW EDIT*———————
I bought these 3 headlamps in the last 2 years and my go to light is the skilhunt H04rc.The skilhunt is also the cheapest and it does have a solid well built feel! No regrets here!
The fenix has an irritating HOLD-on HOLD-off UI and if you short press it to turn on it gets stuck in a battery check/test that wont time out for 30 seconds so you cannot turn on light!
The Armytek wizard pro has a mushy-hard to press button that makes it frustratingly difficult to activate the light with or without gloves. (with gloves its almost impossible in winter).
Now the skilhunt h04rc. I find it super easy to activate with mode 2 set to low on short click. It shuts off with another short press. If I want a higher brightness its just a hold down as it cycles modes from low to high. The high cri is awesome. The only thing I wish it had was red mode maybe a mode-3 short press to firefly red (SKILHUNT ARE YOU LISTENING???)
All 3 lights have magnetic charging and I much prefer that over removing a rubber plug and inserting a cable in the dark.
All 3 have nice headbands with skillhunt/fenix being the nicest.
Only 2 have red mode with skilhunt being the loser of this selection.
Fenix UI just plain sucks. You also have to go through white memory BEFORE you get to red (how stupid). The headband is nice but the hard plastic light holder is NOT!
Armytek has supposedly improved the mushy-hard button but do I really want to spend another 100 to find out, NO! Its also the biggest light! You also have to unscrew tailcap 1/4 turn to charge and screw back in to use.
https://i.postimg.cc/TY0ChQT3/20210929-095100-copy-1040x780.jpg
https://i.postimg.cc/mgrV9MrN/20210929-095258-copy-1040x780.jpg
https://i.postimg.cc/VkHgW6ry/20210929-095408-copy-780x1040.jpg
https://i.postimg.cc/nLjkRJBX/20210929-095535-copy-780x1040.jpg
