HAIKELITE HK07
7*XHP50.2 23000lm 6500K 3*18650
USB Rechargeable Flashlight Group Buy
For reference, this is my order timeline for our Group Buy.
Note: speed of delivery varies from country to country.
Group Buy Price: $84.99 (usual $101.99)
Freeme's Exclusive Coupon: Request in this thread
Can't wait for our reply??
Price: from $90.99 (usual $101.99)
Coupon: To Be Announced
Specification:
Brand |
HAIKELITE |
Lamp beads |
XHP50.2 |
Lumen |
23000LM |
Range |
500m |
Material |
6063 aluminium alloy, stainless steel |
Finish |
Military grade 3 hard oxide |
Lens |
Tempered glass lens, black colour with violet film |
Battery |
Three 18650 power cells (pointed, semi-tipped) |
Charging |
Type-C two-way fast charging port |
Charging time |
3000mAh 3x18650 4 hours approx. |
Light beads |
7 LEDs XHP50.2 |
Colour temperature |
6500K (cool white) |
Waterproof rating |
IPX7 |
Dimensions |
146mm (overall length) x 60mm (head) x 50mm (tail) x 46mm (barrel) |
Weight |
683g |
Operating Instructions:
Infinitely Dimmable: When off, press and hold the switch to infinitely dim up the brightness, release the switch and press again to change the dimming direction and lower the brightness
Extremely bright: when on, double-click quickly in any gear to enter extremely bright, when the torch reaches 55 degrees, there will be temperature control protection, the torch will quickly drop to about 2000 lumens, if it reaches 55 degrees in the high brightness gear, it will slowly drop to about 3000 lumens, it will continue to be bright for a long time, the torch will rise to the high brightness gear when it is below 45 degrees.
Burst flash: when on, double click - extremely bright double click again to enter the burst flash
Battery level indicator: when the battery is below 3.2V blue light flashes, below 3V red light flashes, below 2.8 will automatically shut down
Charging indication function: red light when charging, blue light when full
Mobile phone charging indication: blue light is on for a long time when charging.
Charging power: charging 5V 3A, 9V 2A, Huawei SCP5V 4.5A, two-way fast charging
Infinite dimming/stall mode switch: when on, three clicks for infinite dimming
mode switching between light and stall mode
Stall mode: first 200 lumens, second 1500 lumens, third 3000 lumens, fourth 6000 lumens, double click to very bright 23000 lumens, double click again to enter burst flash.
Lock mode: Press and hold for four seconds to enter the lock function when switched off, and for four seconds to unlock when switched on.
Reminder for safe use:
1. Please use a high quality power battery (discharge capacity >20A).
2. When the battery voltage is too low, please charge it in time. The torch has a low battery indicator (when the voltage falls below 2.8V, the torch will enter the protection function to turn off the torch).
3. Do not shine directly into the eyes of people or animals, and do not shine on moving vehicles or flammable objects. It is normal for the head to heat up quickly, so please use caution to prevent burning your hands.
4. Unscrew the torch and insert 3 x 18650 batteries. Note that the torch requires pointed or semi-tipped batteries.
Do not place the batteries upside down, with the negative (flat bottom) of the batteries facing the spring and the positive (with the tip) facing outwards.
5. Screw the barrel tightly, the torch will flash when it is energised. Tighten the barrel with the appropriate amount of force, being careful not to apply too much pressure.
6. The torch has a small standby current when it is switched off. The current is too low to worry about. However, it is advisable to remove the batteries when not in use for a long period of time. (e.g. if it is to be left for several months)
Package included:
1 x HAIKELITE HK07 Flashlight
1 x Hand Strap
1 x Type-C Cable
1 x Manual
2 x O-ring
Images:
Reserved.
Interested.
man! this would be really cool with osrams or maybe even sst20 or xpl-hi-hi! a warm tinted power "thrower"!
Too bad they wouldnt make "spare" mcpcb's for sale in 3535 footprint too!
[FLF] Five Light Friday https://budgetlightforum.com/node/78749
Check out some of my new lights (picture heavy) and quick first impressions of them here: https://budgetlightforum.com/node/77180
My Sft40 beamshots / comparison thread: https://budgetlightforum.com/node/78100
The BLF GT with SFT40 (2300lm, 2700m+ @ 30 seconds!)
https://budgetlightforum.com/node/79561
That is exactly what I thought…
Interested
Interested, thanks.
Interested
Shared.
This light is so crazy tempting, but I can’t settle for the 6500K. If it was the 5000k, I would be on it like flies on shit. I have the MT09R in 5000K and this one in 6500k would really bother me by comparison. I love the styling and size though, especially the way they designed the head just barely slightly bigger and added that fat SS Bezel.
5000K is definitely much more ideal.
100% agree. I just don’t need a 6500k flooder, or really any more 6500k lights at all tbh.
Interested
In coming...
Interested
Interested
Hi Freeme, thank you for all you do to get us deals. Just a quick question. Can you ask Haikelite if they are willing to put the 5000k or maybe something even warmer in this light? I’m pretty sure there are plenty of people that would love that and feel compelled to buy it. Maybe they are hard to come by right now, who knows. But I figured I’d at least ask if you could ask if that’s a possibility. Thank you.
I need one…
Full Molicel INR-18650-P26A Datasheet
Approximate Diameter: 18.4 mm +/- 0.3mm (May be slightly thicker than most standard 18650)
Approximate Length: 67.15 +/- 0.15mm
Brand: E-One Moli Energy Corp. (Molicel) & New Power Energy (NPE)
Manufacturer Rated Capacity: 2600mAh
Manufacturer Rated Standard Discharge Capacity: 2500mAh (Minimum)
Manufacturer Rated Max Discharge Current: 35A
Nominal Voltage: 3.6V
Peak Voltage: 4.2V
Protected: NO
Style: Button Top
Color: Gray
Origin: Taiwan
Doug S.
My XTAR 21700 has a raised contact of approx 0.5mm.
I believe they are referring to this type of battery for semi raised tip. For true flat top cell, you might to get mentally prepared to apply solder blob yourself.
Doug S.
Hello,
I’m interested in two of them.
sENT.
I just recieved the HK07. It is a flodder, as I expected.
It is a strange U.I. Ramping is similar to Narsil, but not the same. It can also be switched to stepped mode.
It also noticed a slight delay in turning off, after pushing the button.
They state in the manual that thermal regulation is preset to 60 degree, then it drops. After it reaches 45, it will rise again.
It heats up rapidly, on turbo, with Sony VTC6.
I measured temperature after 3 minutes on turbo. Double click to get turbo again and the head is already 75 degrees, handle is 52 degrees, endcap is 48 Celsius. As you ca imagine, you cannot hold it without glove or the included lanyard.
I don’t have measuring device, but by comparing it to the Astrolux MF01s, in 5000k sst20’s, it is pretty similar. And that is a solid 12k lumen. That means that 2 of HK07, side-by-side will do tha stated 23.000
Just started testing mine with some fairly well used 30qs. So far I’m getting output about 10% higher then my MF01S. I’m still playing with it but at this point I much prefer the HK04.
Edit: No, sorry but that’s not accurate, lumen output is going to be higher then that as the HK07 is floodier then the MF01S so my lux readings are relatively meaningless other then determining output is higher then the MF01S which I estimate at about 13500LM. New batteries will also make a difference. Regulation seems to be as claimed or close. I don’t have a suitable light with similar beam and output to use for my ceiling bounce comparison method. Also, It’s the throw and Anduril UI of the HK04 that I prefer. One day I’ll have to get a lumen tube or sphere. 23000LM?, of course not, but I hope someone with more expertise will do an accurate test of this light. I’m curious.
I feel sorry for people who don't have a hobby or interest to escape to.
Interested
Replied.
