Lead free solder. How do you feel using this?
37 posts / 0 new
luminarium iaculator
luminarium iaculator's picture
Last seen: 4 min 28 sec ago
So far I’ve been using Sn60Pb39Cu1 from Stannol. This one is one of the best for our job. Super shiny solder joints.
But… There is always but…
I don’t know do you have similar symptoms but lately i feel headache after several hours of soldering job is completed. I have well ventilated space but no matter for that I guess that I inhale something bad anyway… Maybe lead in solder is poisoning me? Doesn’t matter… When I was younger I did not felt any headache. Now after 40 I guess I started noticing all kind off stuff that I did not felt before…
I want to try lead free solder wire and I want to order top product right in a start…
So would something with S-Sn99Cu1 markings do the job?
Any recommendations would be great or your experience of how you changed(if you changed) from lead to lead free solder.
I mean is it harder to solder with lead free, how do you feel about solder joints (are they better, worse or same like with leaded one), any other good of bad symptoms that can occur by using lead free solder?
Edited by: luminarium iaculator on 10/05/2021 - 11:56
thefreeman
thefreeman's picture
Last seen: 14 min 5 sec ago
I don’t think there are lead fumes at the temperatures we work with, flux is definitely not good though, install a fume extractor regardless of the alloy used.
For lead free hand soldering I think the one commonly used is SAC305.
There is also BiSn, I like to use it because the lower melting temperature (140°C) makes it easier to work with, especially on MCPCBs.
Can you recommend which BiSn to buy?
thefreeman
Chipquik Sn42/Bi57.6/Ag0.4 is what I use.
jeff51
jeff51's picture
Last seen: 1 day 13 hours ago
It’s the flux fumes that get to me after an extended session. Unless I take some measure to suck them away from my work area.
Haven’t tried any lead free solder yet. The early versions were a pain to work with when re-flowing joints on motherboards.
All the Best,
Jeff
flightless22
flightless22's picture
Last seen: 11 hours 40 min ago
For me the cause was poor posturing, poor lighting and inadequate ventilation. I still use leaded solder but I no longer get headaches, eye strain or feel malaise after I have better lighting, a better fume ventilating/extracting and a standing magnifier help to stop the slouching.
Sari33
Last seen: 48 min 3 sec ago
Have you tried use this alloy on pcb drivers as button top or it blackens with false contact on the + battery like Sn60 / Pb40 ?
kennybobby
kennybobby's picture
Last seen: 10 hours 17 min ago
i find the lead free to be a pain to solder and it tends to ball up instead of wetting the surfaces. It might be okay for wave soldering on production lines, but for repair and mod work it is not as easy to use.
Now i used to think that i was cool,
drivin' around on fossil fuel,
until i saw what i was doin',
was drivin' down the road to ruin. --JT
Did you tried low melting point lead free solder like above mentioned Sn42/Bi57.6/Ag0.4 ?
I have difficulty to find mentioned one on my market.
On my market there is only S-Sn99Cu1 whatever that means Question
thefreeman
Here is a table of different alloy properties
Ag content decreases slightly the melting temperature compared to SnCu.
The issue with BiSn is that if it’s contaminated with lead the melting temperature decreases a lot, down to 95°C in the right proportion (rose’s metal) and it makes weak joints, if you plan to solder on existing joint you have to check if it’s leaded or lead free first.
I did use it to make solder blobs a button contact but I don’t trust it to keep a low contact resistance, I’ll swap with gold plated constacts as soon as I receive them.
kennybobby
i’ve not tried it, but it has a low melting point and that should make it easier to use as long as the flux will remove oxides and allow proper wetting.
The S-Sn99Cu1 is almost pure tin, at 99% tin and 1% copper.
Sirstinky
Last seen: 6 hours 30 min ago
I tried it a while ago, and maybe I got cheap stuff, but I hated it. I tried some quality 60/40sn/pb and never went back. Now I only use 63/17 Kester 44. The lead-free melted too hot, does’t flow well, and the joints oxidized too fast. The high melting temperature was the main issue. My smaller pieces got heated too hot for my liking to get good joints and wetting. I’m sure there are really expensive brands of lead-free (I hear some places are banning leaded sder) that work great, but I’m stuck on the leaded stuff. Just use it in a well ventilated area and wash your hands after use.
Firelight2
Firelight2's picture
Last seen: 5 hours 22 min ago
My preferred solder is Mechanic’s Solder paste.
It has lead in it, but it’s very easy to work with. Much better than Chipquik.
BrassCat
BrassCat's picture
Last seen: 1 week 6 days ago
Hello my fellow nsolder freaks. In manufacturing you must (?) be lead free. Those of us occasional users still have leaded solder. suck the fumes away! it is the flux. Not sure if any lead is in the flux fumes, we melt the solder, not vaporize it.
I prefer to use solder with some silver in it. It works a lot better for me. Leaded or lead free.
BrassCat
There is a thread where Led4Power said that he uses lead free solder for everything he does and that it has better properties than leaded we mostly use here.
I think someone could do solder joint tests for our flashlight modding purpose: Lead vs Lead free solder strength test… Someone like Djozz with “touch” for doing experiments. Thumbs Up
BrassCat
BrassCat's picture
Sounds good for a test. Way back, I wound two solenoids (springs) from solder, leaded and silver tin lead. Pulling the leaded solder, it stayed pulled, no strength. The silver / lead / tin “spring” had resilancey, it went most of the way back to original. I also find it to tack better. And someone may comment, don’t use the solder to hold the connection, it needs to be mechanically attached first. This goes back to chassis wiring, point to point. Now surface mount, it is the mechanical attachment also. Will be interested in the test results.
BrassCat
Correllux
Correllux's picture
Last seen: 23 min 50 sec ago
Not a test, per se, but some of those pertinent qualities are listed here: https://budgetlightforum.com/node/51628
I’m in agreement about source of irritation being the flux rather than the lead. Active fume reduction/movement is pretty much standard at pro benches and you can get decent cheaper units these days for $45 to $80 without going all in on a commercial unit ($$$). It’s been a long time since I’ve done enough soldering for a length of time to really bother me, but it used to get me a little with sinuses and a headache…most of that was acid core and non-electronics rosin core, though.
Bob_McBob
Last seen: 10 hours 47 min ago
It also has terrible thermal conductivity which may be an issue for LEDs. That’s why Clemence uses indium for his low temp Nichia reflows.
https://budgetlightforum.com/node/51628 Thumbs Up , although not all are listed here for example the one I use is Sn60Pb39Cu1 which could be similar to Sn60Pb40 which has melting point 183 / 191 °C, solidus / liquidus and 535 kgf/cm² of Tensile Strength at Break which is one of the best from the table.
Also the one that thefreeman mentioned Sn42/Bi57.6/Ag0.4 could be similar to Bi58Sn42 from mentioned table which has lower melting point 138 / 138 °C solidus / liquidus and 565 kgf/cm² Tensile Strength at Break which seems like the best properties for our modding job if we look the table – very low melting point and excellent tensile strength! But lower thermal conductivity…
The question is: Should we use Bi58Sn42 instead Sn60Pb40? Bi58 has very bad thermal conductivity at 19 W/m⋅K while Sn60 has 49!
So real question: Is thermal conductivity more important than lower melting point and Tensile strength properties? If that is not so important than Bi58Sn42 is winner here?!
Yes. This certainly is an issue if we repair over existing setup but it should not be an issue if we do build from scratch?
thefreeman
True but he uses BiSn for the wires IIRC, his MCPCB are so good that when using high temp solder for the wires, or even SnPb, it can reflow the indium. I also use indium for the non DTP LEDs but I’m not sure it matters that much vs SnPb or SAC.
It shouldn’t, all the drivers I’ve made where soldered with BiSnAg (paste and wire)
Shouldn’t matter for things that don’t produce a lot of heat.
I do need to check if it has an effect on dc/dc regulators with integrated switches on my drivers, which also produce heat (not as much as an LED), on one of my driver the regulator I used went into thermal protection at high current, I’ll need to test if it does the same with SnPB or SAC. (It’s possible it was also inadequate thermal design).
Barkuti
Barkuti's picture
Last seen: 1 day 18 hours ago
There are many lead free solder alloys. I don't know what Led4Power uses but, in my experience, Sn99.3Cu0.7 just sucks.
Sn63Pb37 has always been the golden standard for electronics work, and for me it continues to be so. Right now I am using Sn60Pb40 I got from AliExpress, which is veery close but not quite.
I currently find little to no reason to do away with leaded solders, at least for our usage. As far as I know it all started with RoHS, which excluded !!! batteries; so at least in this respect I don't give a damn about it.
Concerning the above solders, no one noticed Sn91Zn09? Its resistance is lower than that of Sn63Pb37 or Sn60Pb40, so higher conductance, while its thermal conductivity is also better (22%/24.49% higher). It also is a good alloy for soldering over aluminium, according to this Kester's 2600 aluminum soldering flux document.
Solder alloys @ Wikipedia adds the following information about Sn91Zn09:
KappAloy9 Designed specifically for Aluminum-to-Aluminum and Aluminum-to-Copper soldering. It has good corrosion resistance and tensile strength. Lies between soft solder and silver brazing alloys, thereby avoiding damage to critical electronics and substrate deformation and segregation. Best solder for Aluminum wire to Copper busses or Copper wire to Aluminum busses or contacts.[54] UNS#: L91090
Deleting a just published post causes the forum thread answer notification to fail. Thus, if you need to change your just published post, edit it. Thanks.
Please avoid fully quoting lenghty posts, namely with nested quotes. Trim quotes down to the essential. Helps with neatness and legibility. Thanks.
I recommend saying no to Covid vaccine. Listen to your soul. Innocent
Keanu Reeves may need your help. Join his Telegram channel here.
led4power
led4power's picture
Last seen: 1 day 2 hours ago
I'm using Stannol Sn95Ag4Cu1 0.8mm wire (Manuf. nr: 593410), silver makes a lot of difference, and this alloy has 4% of it. 100gr spool can last for years, so it's a very bad idea trying to save some money on solder wire/paste.
Avoid any kind of cheap no-name junk from Aliexpress etc., most of them have no silver (even if they claim they do), and contain so much impurities/junk that soldering is not possible.
Barkuti
Barkuti's picture
led4power wrote:
… it's a very bad idea trying to save some money on solder wire/paste.
Well, I believe quite differently. Since I believe that I can buy BBB stuff (bueno, bonito y barato in spanish, which translates as good, beautiful and cheap/affordable), that's what I get.
While kind of off-topic I buy stuff like this. Yes, $4.05 for a 100g roll right now. Still, the last time I bought solder wire I paid like $3 for a 100g roll 1¾ years ago, and I even got two rolls for the same money (first roll arrived late, after I had won the unsuccesful delivery dispute; I wanted to give seller his money, so I bought another roll and told him not to send me the item, but he did anyways). Innocent
I can also find other solder pastes and wires with ease in AliExpress, there's plenty of good stuff you just have to find the right product and sellers (i.e. believe correctly).
led4power
led4power's picture
Your link is for leaded solder wire, of course they are cheaper, not just because the don't have any silver in it, but they also have 63% of tin compared to 95-96% for lead-free solder wires.
Lead-free Stannol with 3-4% silver content is ~14€ per 100gram (with tax), you obviously have never tried Stannol or similar wires, so you can't compare how good or bad stuff from Aliexpress is.
And I'm talking about lead-free soldering, not leaded.
I'm sure many people who tried to switch to lead-free soldering bought some random silver-less junk from Aliexpress were disappointed with soldering results, and decided to abandon lead-free stuff.
Thanks guys for nice discussion and replying… Thumbs Up Beer
So lets continue… If we compare Lead free solder Led4Power recommended to this table https://budgetlightforum.com/node/51628 we will see that Sn95.5Ag3.8Cu0.7 (which is the most similar by properties to Sn95Ag4Cu1 Led4Power recommended has highest “Tensile strength at breaking” at 600 kgf/cm² and better thermal conductivity at 60 W/m⋅K but it has low Tensile Elongation at Break of 16% while classic Sn60Pb40 has 40% if mentioned elongation at break is important for our hobby?
So I will have to try mentioned Sn95Ag4Cu1 and decide… Silver and copper in Soldering alloy can’t be bad right?
But question is can we use Sn95Ag4Cu1 as a “repair component” over lets say Sn60Pb40? I am sure there will be no problem for scratch builds but how it would behave if we merge it with leaded solder? Cause I’m sure plenty of guys here fix those Cheap(and no so cheap) flashlights for their friends etc…
texas shooter
Last seen: 9 hours 8 min ago
Seeing you all as a group know your solder. My question is what solder flows best with repairing already existing traditional Pb/Sn base.
kennybobby
As Barkuti said in post #21,
WHY? Because that is the eutectic point for this mixture, that is to say that it melts from a solid to a liquid at the lowest temperature (361 F) of any other mix of the two elements.
Barkuti
Barkuti's picture
Well this is true, I never tried any good unleaded solders.
In fact, the only unleaded solder I've ever had is a roll of Sn99.3Cu0.7 alloy which I bought many many years ago in an emergency from a local chinese market store. I could do the repair, but it sucked. The roll is still lying on my repair table, and as usual it still sucks butt. Big Smile
Concerning the question from luminarium iaculator and texas shooter, how about using a traditional Sn/Pb solder to fix Sn/Pb solderings? I provided a link up there, just in case.
If you mix a quality unleaded solder with a standard Sn/Pb alloy, you'll end up with some sort of solder mixture. If you care to somehow remove most or all of the original solder alloy and redo the soldering with the good unleaded one, sure there will be no problem. It may still be perfectly fine even if you mix it. I remember having redone some solderings in a connector long ago, removing and replacing pesky Big Smile Sn99.3Cu0.7 with standard Sn63Pb37, and all was good. The inverse procedure should be fine too.
I will report when I receive mentioned Sn95Ag4Cu1 0.8mm wire from Stannol(Germany) which is probably the best manufacturer on Europe market.
Barkuti has real BLF spirit… If it ain’t cheap I don’t wanna buy it Wink Beer
Edit: Last several hours I tried to find recommended Stannol lead free wire online without any luck so I took “Armack Lötdraht Typ26-3 Sn95Ag4Cu1” and chosen 0.8mm one from ebay.
Hope that it will come fast and that it has good properties although it is not from Stannol but from Armack?! Since I never heard for that brand it could be just OEM for some retailer by Stannol?
Barkuti
Barkuti's picture
Barkuti has real BLF spirit... If it ain't cheap I don't wanna buy it Wink Beer
Edit: Last several hours I tried to find recommended Stannol lead free wire online without any luck so I took "Armack Lötdraht Typ26-3 Sn95Ag4Cu1" and chosen 0.8mm one from ebay.
Well, not exactly. But of course there are reasons for it, and I have to draw up a plan to fix it. Wink
Just out of curiosity I made a search in eBay. Now that AliExpress has gone downhill real hard, it's been a pleasure to use eBay advanced search again.
I think you found this stuff: “Typ32-3” search @ soldanshop24.
Funny to see how the title description reads Sn95Ag4Cu1 in some cases, and Sn95.5Ag3.8Cu0.7 in others. The product photographs are the same, reading Sn95Ag4Cu1, though.
Reputable seller. Price wise won't say a thing in this regard.
Rayoui
Rayoui's picture
Last seen: 3 hours 27 min ago
I exclusively use Sn63Pb37 solder. I don’t have much experience with lead-free solder other than what comes on pre-assembled electronics, and that stuff is the worst. It’s difficult to melt and it’s got the consistency of peanut butter when it does.
Sn63Pb37 is extremely easy to work with, melts at a low temperature, sticks right to the pad/part and is eutectic which helps prevent cold joints when soldering parts that might have a chance of moving while the solder is still cooling (like LED power leads).
Lead-free solder is primarily used in manufacturing environments where workers would be exposed to MUCH higher amounts of lead than what a hobbyist with a soldering iron is going to see. I don’t know anyone that has a wave soldering rig in their garage.
I’m unconcerned with slight improvements in tensile strength and elasticity since I’ve never had a component in a flashlight fall/tear off after being soldered properly with Sn63Pb37.
Improvements in thermal conductivity are nice, but probably immeasurably miniscule. For my uses, it’s not worth the extra cost or sacrificing the ease of use of Sn63Pb37.
Sn63Pb37 is my ol’ reliable and I’ll probably keep using it forever unless I have a compelling reason to purchase something different.
