Hi
I dropped my MATEMINCO TK04 and when I press the switch it does not respond.
The blue switch light is on.
Can anyone help?
Hi
Can anyone help?
“does not respond” the LED stays off, no matter what you do?
This light has Anduril-UI, click and hold and it should ramp the LED up, double click for Turbo mode.
If that doesn’t work, the switch might be dead.
I think it less likely that the drop caused the switch itself to break. Most likely the problem is a broken solder joint.
If you have soldering skills you might want to open it up and look for loose wires or parts.
Some things to check:
I can’t open the driver compartment.
For that kind of light, it looks like you’ll need to press out the driver from the from front. Push the driver wires into the driver compartment, then insert something thin and rigid into the holes to press out the driver. Try a round toothpick or a narrow metal pick.
Note that there is some risk with this kind of operation.
