Scallywag's 9th Annual Old Lumens Challenge - Modified Light Category
15 posts / 0 new
Scallywag
Scallywag's picture
Last seen: 1 hour 40 min ago
I decided I’m going to enter the modified light category. I know which light I’ll try to mod, but I don’t have pictures and haven’t ever opened it yet.
Not sure this will even get finished in time this year.
(For what it’s worth, it’s gonna be the “YM-3030” that I got from Bort.)
This will not only be my build thread, but it will also be the only place I take any notes about the build.
Edited by: Scallywag on 10/10/2021 - 11:35
Scallywag
Scallywag's picture
Reserved.
Notes:
Original driver diameter: 36mm.
Driver mount hole centers are on 32mm diameter.
30mm diameter fits between installed screws.
MCPCB diameter ~26mm. Originally probably XP-G
Battery carrier max cell length 69.74mm before contacts installed.
Battery tube: 42mm internal diameter. usable internal length ~71mm minimum – possibly more depending on what exactly is going on at the head end once the driver’s in.
Plastic reflector: 40mm deep by 57.5mm diameter (lip) or 54mm diameter (below lip) – external dimensions
Plastic lens: 61.5mm diameter, 1.5mm thick
Stock: aluminum MCPCB, ~1.5mm pill shelf…
Head internal diameters:
Top level: 62mm diameter, 10mm deep. Mostly bezel threads, and lens/o-ring lip
Second from top: 56mm diameter 25mm deep (bottom is curved in starting around 20mm)
Bottom level: 46mm diameter, ~12mm usable depth
Pill-shelf threads below that.
Scallywag
Scallywag's picture
Alright, initial disassembly and planning stages.
Overview shot:
The first thing I thought of was the cell carrier. It’s going to need a retrofit for high currents. The springs are suitable for, like, alkaline AA currents at best. I’m pretty sure I can cobble something together with Blue gen3 springs and 1mm copper sheet I’ve got. So I’m not super concerned about that problem immediately, because I believe I have everything I need on-hand already and it’s just a matter of putting in some hours and fiddling.
The next issue is gonna be the driver.
(Not much of a driver, huh?)
I want a new one, I want Anduril, but it’s mounted with two screw holes.
This is the main problem I have to figure out quickly, I think. If I need to order a driver from OSHPARK (or worse, aliexpress), I need to do it soon. I don’t think there’s an open-source driver design with appropriate screw holes in the layout… so I probably need to go with a small driver and rig some sort of adapter. My initial thought is a copper ring (possibly cut from my 1mm copper sheet?) with screw holes drilled into it, and soldered to the ground ring of the driver. (Edit: diameter between the screws is 30mm.) It looks like I’ve got about 5mm of depth to play with in the driver cavity, so the driver itself could potentially sit inside the cavity (with the adapter ring toward the tail end of the light… But I think I may want to do the opposite, for reasons I’ll discuss next:
The next issue is gonna be heatsinking. The shelf is, uh, not exactly the thickest shelf. And it has speed holes in it ;). It’s the shelf pictured above, under where the driver would be sitting. I haven’t opened the bezel so I haven’t measured the thickness, but I’m guessing 2mm, 3mm at most. I’m trying to think of ways to enhance this (possibly again featuring 1mm copper sheet) but I don’t remotely know how to attach any heatsinking I make to the bare aluminum shelf. The only saving grace here is that since I’m replacing the driver, I’ll be pulling all the wires out of the handle, and I can hopefully remove the entire pill to work on it.
Oh, there’s also the tail contact. It’s some sort of spring-loaded brass(maybe?) button, and I have no idea how it would handle any sort of high current. I haven’t tried super hard to disassemble it yet, but what I did try didn’t work.
Stretch goal: auxiliary LEDs in the switch button. (no pictures of that yet lol)
Super-double-stretch-goal: usb charging of some sort. (A man can dream)
Scallywag
Scallywag's picture
So, I started today off by removing the original driver.
This allowed me to remove the handle fully (previously it was tethered by the switch and charger wires):
I then flipped the head over and gave the bezel a better effort, and got it opened without any tools. Shown here with the reflector removed as well, and taped the hole out of habit…
But the reflector is plastic. And the lens is too, but I knew that already.
So I finally removed the “pill”, if you can call it that. Threaded shelf?
The thing is not substantial. About 1.5mm thick beneath the LED – which, stock, was on an aluminum MCPCB. I didn’t bother to check for DTP.
I also went ahead and disassembled the handle
And got rid of the barrel connector.
Looks like a normal microswitch to me.
So, I’m not sure how to proceed. I was hoping the thermal path would at least exist. I found a pair of reflectors on Kaidomain that I think I could make work. But the entire point of this light was going to be building something “too hot to handle” – or rather, so hot-rodded it needed a handle. SBT90.2 probably, or at least something that could hold SFT40 in regulation until the batteries died. I had even considered building a new cell carrier to hold 3×18650 (should fit inside the 42mm tube). I can’t think of a way to improve the thermal path that’s within my means. Adding mass to the shelf is the most obvious thing, but I can’t solder/braze to aluminum. Otherwise, it would be using more room in the upper part of the head to construct a new shelf, and somehow have it fit well enough to transfer heat to the walls of the head. That route would probably also entail going multi-emitter to use a short multi-reflector or something.
Scallywag
Scallywag's picture
Okay, I’ve been staring at the head of this light for over an hour trying to think a way to fix it.
I’m starting to think I can take a shallow reflector, something like this, and put it in the top of the head. Then I build a “shelf” out of copper or some such, and I used the holes in that pathetic stock shelf (from here on to be referred to as “driver shelf” or “driver mount”) to mount my copper shelf with machine screws or something. Long thin nuts and bolts? I think to do this, I should flatten the topside of the driver shelf, where the MCPCB used to fit in and that stuff. It would leave a massive hole in the middle with four “mickey mouse ears” from the existing large holes. Then I could use the existing holes or make new ones to fasten the new shelf.
Okay I’ve thought about this a lot more, and I think I’ve solved it. I think I’ll use a 60mm Fresnel lens in the head, with a focal length of something like 25-30mm. This should give me between ~6mm and 11mm of space to add copper to the shelf. For bonus points, I don’t have to worry nearly as much about what my shelf-mounting-solution looks like on the head end of the shelf; as long as it’s not super tall it shouldn’t be getting in the way of the beam – even if it did some, the Fresnel will probably already be an ugly beam. But no shorting issues. Then I can either rig the current cell carrier for high currents, or build a new one for 3*18650 if I feel like it and have the time. For bonus points, because the new shelf will be attached to the threaded driver-shelf, I’ll be able to do a bit of fine-tuning for focusing the light. The hardest parts will be flattening the topside of the existing shelf, and drilling the holes in the copper because I don’t own a drill press.
Skylight
Skylight's picture
Last seen: 19 hours 39 min ago
Using copper sounds like a good idea. To have a flat reflector you could also try triple or quad reflectors which are usually only 2-3cm tall.
To disassemble the tail did you try some needle-nose pliers, the ones used to remove driver retaining rings? The two holes in the white plastic look like they are made to remove it.
pinkpanda3310
pinkpanda3310's picture
Last seen: 1 day 1 hour ago
Good to see you in the comp Scallywag Beer
Nice idea with the Fresnel lens Thumbs Up looks like it has multiple benefits.
Scallywag
Scallywag's picture
Last night was parts ordering time. OSHPark for a 30mm FET+1+8 board (TA triple channel) and aliexpress for a fresnel lens. Hope shipping is quick.
I’m the mean time, I’m going to spend today daydreaming how to construct a 3-cell carrier. I was thinking about starting on the shelf, but I don’t think I want to bother until I have the fresnel lens in hand. Maybe I’ll change my mind later on that.
Scallywag
Scallywag's picture
I haven’t, and I’m not sure yet how critical it is to even open it. But it’s also the kind of thing I can grab a couple tools and mindlessly mess with throughout the course of a day.
Scallywag
Scallywag's picture
I disassembled the tail-end. While the “button” looks like brass, the spring will need a correction for high-current use. Bypass or Blue spring. If I’m feeling cheeky, I may try to solder the brass button to a Blue spring!
The large plastic part was threaded.
Scallywag
Scallywag's picture
I’ve decided to try baking the battery tube. I first removed any o-rings and hopefully any thread lube using isopropyl alcohol.
(Sorry for any crumbs, that is my kitchen counter.)
I placed the tube on my spare cookie sheet – it is in bad shape, and is normally a crumb tray under my toaster. I’ve used it for baking lights before. I also put down aluminum foil.
I placed it inside the cool oven, and set the oven to 550°F on convection mode, which was what worked for me in the past. I’ll update later when the oven reaches temperature. Depending how it turns out, I may regret it, or I may bake other pieces of it!
Scallywag
Scallywag's picture
Looks like it turned gray. Grayer?
Let’s double check with 4000K, 95+ CRI SST20.
Oh. Ooh. I like that.
Scallywag
Scallywag's picture
I did some thinking and some experimenting today. It looks like if I pack 3 18650s into the cell tube, there is space for a rod over 8mm in diameter between each cells around the outside of the tube, so if I can figure out something for that I could build a carrier pretty easily. I will have to find a way to do this that doesn’t electrically connect the two ends of the carrier. I think my best bet would be 5/16” (because USA Facepalm ) plastic rod and to try to use screws to hold it to a copper plate. But we are talking some small screws here. I’d definitely need to have extra material for the inevitable destruction. Also need to figure out the correct length, and solder springs (Blue springs of course) and/or brass buttons to the plates.
I did find some screws I have high hopes for in my existing supplies. For safety, I will have to have an insulated edge on the + side of the cell carrier, because of contact to the battery tube. In theory it is anodized and “just fine” but I don’t trust that, especially with repeated insertions. Some of the anodization is already pre-worn or faulty to begin with Wink
Hoop
Hoop's picture
Last seen: 30 min 49 sec ago
I think you’ll find there is no difference between 5/16” and 8mm, if it makes you feel any better about not being in some other country.
Scallywag
Scallywag's picture
Okay, so I have done some planning. I will use copper discs at either end of the cell carrier. I can re-use parts of the original cell carrier (the end caps shown in the first image of post #3 ) to simplify my carrier construction. At least part of the end caps will be used to insulate the edge of the positive end of the carrier from the light’s body tube; part of the negative end may be used as well for fitment reasons. The way the carrier currently fits the tube, it slides into but not through the tube; I believe the negative end catches a lip where the tail-end threads are cut. I think I will use Blue springs on the negative and attempt to fabricate small copper buttons for the positive end.
For the tailcap, I’m going to attempt to coat the bare aluminum (see where the spring sits in post #10) with copper. This would allow me to solder a spring to it. I’d then solder either the existing, looks-to-be-brass button to the end of the spring, or fabricate my own from copper (and again, solder it to the spring).
If coating that aluminum works well, I might also do it to the driver-shelf and solder my copper heatsink to it.
