Lishen 21700 4000mAh LR2170LA (Purple)
Official specifications:
- Standard discharge capacity: 4000mAh (0.8A charge/discharge)
- Standard minimum discharge capacity: 3900mAh
- Rated discharge capacity: 3900mAh (6A charge / 10A discharge)
- Rated minimum discharge capacity: 3800mAh
- Nominal voltage: 3.6V
- Standard charge: CCCV 2A, 4.20V, 200mA cut-off
- Rapid charge: CCCV 6A, 4.20V, 100mA cut-off
- Max. continuous discharge: 45A with cut-off at 80°C surface temperature
- Discharge cut-off voltage: 2.5V
- Cycle life: 300 cycles to 80% (0.8A charge / 4A discharge)
- Cycle life: 300 cycles to 60% (6A charge / 35A discharge)
/Lishen%2021700%204000mAh%20LR2170LA%20(Purple)-info.png)
This is a high current 21700 cell.
/DSC_4777.jpg)
/DSC_4776.jpg)
/DSC_4778.jpg)
/DSC_4779.jpg)
/Lishen%2021700%204000mAh%20LR2170LA%20(Purple)-Capacity.png)
The two cells match fairly well and maintain fairly stable capacity even at high loads, but the cell get hot at 30A (My holder melted).
/Lishen%2021700%204000mAh%20LR2170LA%20(Purple)-Temp-15.0.png)
/Lishen%2021700%204000mAh%20LR2170LA%20(Purple)-Temp-20.0.png)
/Lishen%2021700%204000mAh%20LR2170LA%20(Purple)-Temp-30.0.png)
/Lishen%2021700%204000mAh%20LR2170LA%20(Purple)-CapacityTimeHours.png)
/Lishen%2021700%204000mAh%20LR2170LA%20(Purple)-CapacityTime.png)
/Lishen%2021700%204000mAh%20LR2170LA%20(Purple)-Energy.png)
/Lishen%2021700%204000mAh%20LR2170LA%20(Purple)-PowerLoadTime.png)
/Lishen%2021700%204000mAh%20LR2170LA%20(Purple)-TripCurrent.png)
/Lishen%2021700%204000mAh%20LR2170LA%20(Purple)-Charge.png)
Conclusion
The cells looks good, but I sort of doubts the continuous discharge rate of 45A, it will probably always be stopped on the 80°C cut-off before the cell is empty.
Notes and links
The batteries was supplied by a reader for review.
Graphical comparison to 18650 and other batteries
Table with all tested LiIon batteries
Nice, thanks! I snagged a few of these for only 10 CNY (1.50 USD) each on Taobao. They are like new but from disassembled battery packs. They seem to be very similar to Samsung 40T which is the gold standard for high drain 21700.
You wrote 45A several times in the review but I assume you mean 35A continuous discharge? I believe they claim 45A only with adequate cooling.
From the datasheet:
Thanks HKJ! I’ve seen these around and wondered what they were like. Your work is most helpful and appreciated.
Oh my mistake, the datasheet does say 45A. Although the Taobao seller I bought it from rated it at 35A and said that active airflow is necessary for 45A.
It’s also confusing because Lishen gave the cycle rating at 35A.
By the way, there is probably a typo in the second image then where it says Rated A: 35.
That’s great! it beats the Samsung 40T at 15-30A with a little less capacity. This is a good alternative
Piercing The Darkness YouTube channel – https://www.youtube.com/c/PiercingTheDarkness
The cell did well at 20A. The hottest cell of the pair reached a hair above +45°C.
At 30A Henrik's holder had a problem. I downloaded the graph, and using an image editor confirmed where the hottest cell would have landed if Henrik's holder were have been up to the task: +53°C. Considering that HKJ's setup presumes 25°C of ambient temperature, this is about the formal limit for li-ion cells.
So, 45A continuous? Nonsense, I'd say. Well, maybe if you stick it in a refrigerator, or use very good cooling. The average output voltage, though, would be rather low, with output voltage plummeting below 3.4V nearly right after the start of the discharge.
Tad off topic maybe, but enough already with the discharge rate thing, by the way. Energy density hasn't seen an improvement for ages by now. Sucks. And that's not to say that I also don't like a lot the sloping shape of the voltage curves for li-ion cells; stable output voltage, à la LiFePO4, is better. We already have super accurate algorithms for estimating state of charge, like coulomb counting and etc., and so we can do with a lot less slope in output voltage curves, which was the reason for batteries with continually decreasing output voltage in the first place. A new battery technology? Perhaps.
Please avoid fully quoting lenghty posts, namely with nested quotes. Trim quotes down to the essential. Helps with neatness and legibility. Thanks.
The human mind, and its programming, is at the forefront of a particular battle of The Light vs evil dark forces. Nearly every human being on this beautiful planet “Earth” has some sort of negative mind programming in its mind. And you better take care of your mind programming, or someone else will in this wicked world.
Viruses DON'T cause diseases! They are better called exosomes, and they are cell cleaners! Watch Virus Theory vs Exosome Theory video and awaken to this truth! Check this article by MD Andrew Kaufman. Read the book “Béchamp or Pasteur” by Ethel Hume for in-depth information.
The datasheet says the cells have safe operating temperature up to 80C
Is there something you don't understand in my comment above? I already know the answer, so here's an explanation:
The temperature graphs which Henrik publishes show the temperature above ambient which the cells reach. He substracts the ambient temperature from his temperature measurements to get temperature above ambient figures.
For this reason, to obtain the maximum cell temperature you must add the ambient temperature to it, 25°C usually.
The figures I posted above, +45°C and +53°C, are temperature above ambient figures. See the + addition sign just after the numbers? It's there for a reason. If we add the usual 25°C ambient temperature to them, we get 70°C and 78°C peak discharge temperatures. What does this tells you know?
Temperature above ambient figures lets you know more easily how a cell would behave in cooler or warmer conditions, particularly the latter. If ambient temperature were to be quite hot, like 40°C, and we add to it the aforementioned temperature above ambient numbers (+45°C at 20A and +53°C at 30A), we get 85°C and 93°C. This means that in such conditions even discharging at 20A continuous would require a bit of cooling to avoid the cells surpassing 80°C.
Thank you so much HKJ, the results looks identical to 40T.
One interesting thing is that LR2170LA is the only Lishen battery does not have the bottom vent, I was always wondering why……
The initial voltage sag 40T obviously beats LR2170LA, it is the reason most people need 40T for. If you don’t care the initial voltage sag, P42A actually beats both.
Nice to finally see a revie from a qualified trusted source! Thanks HKJ!
[FLF] Five Light Friday https://budgetlightforum.com/node/78749
Check out some of my new lights (picture heavy) and quick first impressions of them here: https://budgetlightforum.com/node/77180
My Sft40 beamshots / comparison thread: https://budgetlightforum.com/node/78100
The BLF GT with SFT40 (2300lm, 2700m+ @ 30 seconds!)
https://budgetlightforum.com/node/79561
