My first build - a little advice
45 posts / 0 new
Berkua
Last seen: 6 days 5 hours ago
Hello there, I’m putting together my first build at Mtn. Electronics and was hoping to confirm a few things.
First, I’m looking for a nice balance of performance and battery life. I currently have a Thrunite Archer 1A V3. I like it just fine, but I thought I’d try my hand at building my next flashlight.
Here’s what I’m going to buy. Suggestions and/or advice welcome.
- Convoy S2+ in Black
- QLITE REV.A 7135*6 3.04A LED 17mm DRIVER with Optional guppydrv Universal Firmware
- CREE XM-L2 T6 4C LED on Noctigon 16mm MCPCB
I like a warmer toned light. I’d love something that has a turbo of 600-1200 lumens. I’d also like a nice low moonlight mode.
Do you think I’m on the right track?
Thanks!
Lightbringer
Lightbringer's picture
Last seen: 3 hours 59 min ago
Black? Been done to death… You can get colored hosts (yeah, I know, “black” vs “colored”… LOL ) in red/grn/blu/cyn/vio/orn with the metal switch.
The 4C is absolutely beautiful behind a TIR lens, but in a reflector has a pretty fried-eggy beam, hotspot a bit too yellow and spill a bit too blue.
Grab a 20mm TIR lens. 60° is nice and floody, one of my faves, but get a smaller angle for something throwier if you want.
YuvalS
YuvalS's picture
Last seen: 12 min 16 sec ago
I don't understand how you gets 3.04A out of 6*7135, each 7135 gives 0.35A so 2.1A in total.
Also, for nice low moonlight mode you need a separate channel with a single 7135
My FW repository
My BLF/OL contest entries: 7th 8th 9th
Berkua
Thanks for the heads up about the color of the LED.
Berkua
Just copied and pasted a listing from Mtn electronics website and changed the *8 to *6, no big deal…Like I said, it’s my first build. As such, perhaps you can tell me whether or not I’d need to alter my build to get the results I’m looking for?
“you need a separate channel with a single 7135” … How would I do this?
“6*7135, each 7135 gives 0.35A so 2.1A in total.” … Okay, if I only have 2.1A, so I have to change something in my components? Do I need a different emitter? Or does this just mean I’m have lower current and as a result lower lumens?
If you don’t want to answer in long form, maybe you can share a few links you’ve used in the past to learn about this stuff?
chops728
Last seen: 5 hours 29 min ago
I’ve built plenty S2 lights —- The small footprint LEDs seem to do better in my opinion — SST20 (throwy) XP-G2 (throwy) — Samsung (floody)—-Unless you want some crazy low moonlight the regular Q lite driver works fine with Guppy —— I’d keep it at 3 amps — with all the mode options and Turbo timer it will work fine
I’d buy at least two of each component —— nothing like frying your first driver and have to wait a week for another one
YuvalS
YuvalS's picture
Berkua wrote:
"you need a separate channel with a single 7135" ... How would I do this?
You have to use another driver with 2 channels in case you wish to have low moon mode
Berkua wrote:
"6*7135, each 7135 gives 0.35A so 2.1A in total." ... Okay, if I only have 2.1A, so I have to change something in my components? Do I need a different emitter? Or does this just mean I'm have lower current and as a result lower lumens?
With 2.1A you will have a maximum output of about 800 lumens. No need to change anything just take it into consideration
Emitter Test Results pt4: XML2, XP-E2, XP-G2, and Nichia219! (along with sinkpad tests) | BudgetLightForum.com
BTW you can use the "quote" button to make your comment more readable
My FW repository
Berkua
Good tip, I’ll pick up a couple components…they’re cheap enough.
Berkua
BTW you can use the “quote” button to make your comment more readable
Sorry ‘bout that! Thanks, for the replies. I appreciate the info.
MtnDon
MtnDon's picture
Last seen: 5 hours 12 min ago
All the Qlite 105C drivers I have bought from mtnelectronics use the 380mA version of the 7135 and come standard with 8 of them = 3.04 amps max output. They are quite a decent driver with guppy.
Berkua
Yeah, the *8 is standard, and they remove as many as you want for an extra fee. I suppose if I have the upgraded firmware that allows for any config, *8 would be fine. I was worried that *8 would be too much of a battery drain, even on lower settings. I also read mixed information regarding issues with flickering and heating up when you use a driver with higher amp outputs.
Again, I’m totally new to this, so I could definitely be mixing stuff up.
MtnDon
MtnDon's picture
Personally I would not worry about having 3.04 max. Yes the light will get hot, but you can reduce the output lower if needed.
My very first self built light was an S2, with that Qlite driver with 4 added 7135’s, feeding a triple mcpcb and using a Carclo triple optic plus aluminum spacer that is needed when doing a triple like that. I learned a lot and went onwards from that.
Are you wanting something that throws or floods more? Tube lights like the S2, S2+ don’t make the best throwers, IMO. I like the triples as you can swap the optic if you decide you want wider or narrower beam. Plus three of the same emitter are more efficient than a single with the same current.
One thing to be aware of when working on an S2 is that the brass retaining ring that screws into the brass pill to secure the driver will not fit over that driver. That is, the inner opening of the retaining ring does not have a large enough opening to clear the 7135’s on the side of the driver that faces the cell. The ring has to have the inner hole diamter filed larger or the driver is just soldered to the pill.
Once you get used to soldering iron use, you can easily remove 7135’s from a driver like the Qlite. You can also add your own.
Berkua
Great information, thank you! Yeah, I am not well practiced with a soldering iron. This is a fun build that allows me to practice and learn a bunch of new skills.
I’m not looking to illuminate something that’s super far away … I’m more interested in a nice flood with a tiny bit of range. A nice EDC that I can use to walk my dog a night, night walks in the woods, working on my car or tractor, around the house, etc.
Berkua
One other question I had is regarding thermal compound/adhesive. I’ve, again, seen differing opinions about whether it is best to use thermal compound or a permanent bond with thermal adhesive. My gut is leaning toward thermal compound, so it is easier to make adjustments or completely change my build at any time.
Any recs on this?
I was going to buy Arctic Ceramique 2 Thermal Compound from Mtn. Electronics. It’s inexpensive and you get quite a bit for your money. I know many people recommend Arctic Silver 5 Premium Thermal Compound, but if I could get something decent for less, I’d rather have a lower cost entry point in the beginning.
Thanks!
YuvalS
YuvalS's picture
Berkua wrote:
One other question I had is regarding thermal compound/adhesive. I've, again, seen differing opinions about whether it is best to use thermal compound or a permanent bond with thermal adhesive. My gut is leaning toward thermal compound, so it is easier to make adjustments or completely change my build at any time. Any recs on this? I was going to buy Arctic Ceramique 2 Thermal Compound from Mtn. Electronics. It's inexpensive and you get quite a bit for your money. I know many people recommend Arctic Silver 5 Premium Thermal Compound, but if I could get something decent for less, I'd rather have a lower cost entry point in the beginning. Thanks!
For 3A maximum current it does not really matter. Unless you want to keep the light on turbo for a long time, heat dissipation is not a real issue for you.
You can use a 2$ thermal paste from AliExpress, it is a week adhesive so can be removed if you want to
My FW repository
Berkua
Okay, I decided on a different LED that looks to have a decent description of color accuracy, tiny, and output.
Here’s my build lineup. I may throw in some glowing gaskets, etc., but what do you guys think in terms of a basic first go?
  • https://www.mtnelectronics.com/index.php?route=product/product&product_i...
    — Nichia 219C D280 on 16mm MTN DTP CU – 80+ CRI 3000K
    — R8000 CRI Rank (~80 CRI)
    — 3000K 3-step MacAdam centered ellipse temperature
    — Low vF allows for tons of output and easy regulation, even at high amps
    — Similar output to an high-bin cool-white XP-G2, but with much better CRI and tint; also easier to hit 5A+ due to the extremely low vF requirement
I feel pretty good about my choices. I’m not looking to reinvent the wheel. Hopefully I learn a bunch and can come back with a better project after this one. Smile
chops728
You’ll need a different centering ring —off the top of my head I can’t remember which one works with the S2 reflector
https://www.mtnelectronics.com/index.php?route=product/product&path=25_8...
Berkua
Oh, thanks! A short would be bad Smile
chops728
Always check from the + of the driver to the Host for a short before trying to put a cell in it —I’ve cooked a few drivers hurrying
Nachtfeuerzeug
Nachtfeuerzeug's picture
Last seen: 1 day 3 hours ago
Hello!
Good light platform to experiment with.
I really like adding a TIR, 60° or 45°. Heck, buy both. I like the 45° for better throw.
https://www.mtnelectronics.com/index.php?route=product/search&search=tir
What I like about these is:
  • the diffuse but focused (?... lol) pattern;
  • no issue with shorting the system with an aluminum reflector
I'd still use the insulator/centering ring for optimum vertical adjustment
Here's one of my posts with TIRs from another manufacturer:
https://budgetlightforum.com/comment/1722178#comment-1722178
EDC
FW3A, SST20 4000K || S21A, Crescendo Mtn20DD, LH351D 4000K || SP32A, SST40 5000K
Recent/ongoing Mods:
S2+, TexAven 17mm, LH351D | S21A, Crescendo 20mm, XPL HI 5000K | L2 w/Mtn17DD Zener Guppydrv, XHP-50 | C8+ OP, DD XHP-50
SP32A w/SST40 5000K | TIR Upgrades | EagleTac clip | Ultrafire C2 w/6A 20mm & LH351D | S2+, Biscotti, Nichia 219C 2700K |
Reviews:
Sofirn SP31 v2.0 Tactical Flashlight (Cree XPL HI) || Sofirn SD05 Scuba Diving Flashlight || Sofirn SC31 USB Rechargeable (XP-G3) || Sofirn SC31 Pro 5000K
Berkua
Nachtfeuerzeug wrote:
Hello!
  • the diffuse but focused (?… lol) pattern;
I’d still use the insulator/centering ring for optimum vertical adjustment
https://imgur.com/icCY9A3
https://imgur.com/Vb42S1x
Here’s one of my posts with TIRs from another manufacturer:
Thanks, I am pretty pleased with the setup. I’m a bit disappointed that the S2+ hosts seems to be out of stock in most cookies right now, but there’s always next time.
I’ll definitely be grabbing a diffuser, they look great.
I had to go elsewhere for the right sized spacer/insulator.
Now to get practicing on my soldering skills while I wait!
chops728
What kind of Soldering Iron/Station do you have
Berkua
I know it’s not the best or anything, but I picked this up on Amazon. Cheap and hopefully will last a tiny bit.
Anbes Soldering Iron Kit… https://www.amazon.com/dp/B06XZ31W3M?ref=ppx_pop_mob_ap_share
chops728
You might be alright soldering to that brass pill of the S2 but I don’t think that will heat up enough for heavy copper
Berkua
It’s an Amazon purchase…I can return for free. Do you have a different budget recommendation? I want to do it right, and if this soldering iron is going to give me poor results, I don’t want to use it.
Thanks for telling me.
chops728
I’ve been using these for years —- I use genuine HAKKO tips —- they work well and cheap enough to replace when they fail ( they last a couple years with moderate to heavy use)
https://www.ebay.com/itm/371993129984?hash=item569c84b400:g:4O4AAOSwkJVg...
These are the 2 Tips I use all the time —I have 2 stations— one with each tip
HAKKO T18-B shape – B
HAKKO T18-D32 shape -3 2D
Berkua
So, I just got my build parts today, and I’m a bit disappointed. I bought a 17” driver to go along with the Convoy S2+, but the retaining ring doesn’t fit back on once the driver is seated. The 7135 chips are in the way.
I got the QLITE REV.A 7135*8 DRIVER.
Is this a normal occurrence?
Please let me know if there is anything I can do.
Thanks!
Nachtfeuerzeug
Yes, that is common. Before the S2+ came out, there was the S2 & S6 and we all had to solder in the driver.
The 12 group, ramping and 4 mode 17mm drivers are easier to install in the S2+ and I like the retaining ring quite a bit. They do, however, come lose and you won't have the issue with soldering. You picked a good driver and Guppydrv is nice.
EDC
Reviews:
Berkua
The 12 group, ramping and 4 mode 17mm drivers are easier to install in the S2+ and I like the retaining ring quite a bit. They do, however, come lose and you won’t have the issue with soldering. You picked a good driver and Guppydrv is nice.
Okay, that makes sense. I looked into it a tiny bit, and it seems the soldering iron needs a bit of help with the thicker brass pill. Many people suggest preheating the pill somehow. I even saw a suggestion to use a butane torch and melt the solder directly, without the use of a soldering iron.
Have you found that a soldering iron won’t get the brass hot enough for a solid connection?
chops728
If it’s a good enough Iron it will work fine — try tinning a little spot in a couple places on the pill —then it will solder pretty easily
MtnDon
MtnDon's picture
Sometimes I tin a couple of spots before assembly, using a torch. Then the two pieces can be sldered at the tinned spot with less trouble, less heat/time. An iron that can get real hot at highest setting with a broad flat tip helps.
If you do pretin be careful not to get solder running into the place where you want to fit the driver. If you do, that will need removal. Not a real big deal but nice to avoid if possible.
