Convoy C8+ but which emitter/driver?
Hello
I plan to add a [specifically] Convoy C8+ to my collection but unsure which one to get.
What I’m after in this case:
- tighter beam
  • beam that is most likely to cut through low levels of fog (to ping floating objects)
Not important in this case:
- Colour warmth
- CRI
  • Stated lumens
Ta
B
CULPM1
Thanks
73
M0PTP
You might try the KY CSLNM1.FY orange-yellow light. It should be good at cutting through fog without as much backscatter as some of the 6500 k lights tend to have.
I use an SST-20 in 2700k with a 5 amp driver for the same purpose. You still get good color rendition and little backscatter, but I bet the above osram orange-yellow will be a tighter beam.
captainkirk
Interesting suggestions and food for thought. Thanks.
So can the .fy (amber) osram take as much current as its white w1 brother?
In this case ( for fog penetration)it is important ” Colour warmth” (temperature). You should use warm led as possible.
