My flashlight got a 'little' too hot
45 posts / 0 new
ChibiM
ChibiM's picture
Last seen: 11 hours 4 min ago
Was doing my Imalent MS18 runtime tests again, and while the 4 brightest modes went without a problem,
the 10,000 lumen mode had some issues.... some hot issues...
Keep in mind that you would notice this much earlier when you are holding it in your hand, and outdoors with a wind it may not reach these temperatures.
But I noticed a strange smell that just got stronger, and then I even heard the flashlight ticking. So I thought something was wrong because I remember having this same problem with my Q8 a few months ago.
Here are 2 thermal images I quickly took
I quickly took a fan and pointed it at the light to cool it down.... pity the MS18 didn't turn on the fan by itself.
Edited by: ChibiM on 10/13/2021 - 03:19
puglife2
puglife2's picture
Last seen: 11 hours 48 min ago
This is fine, aluminium melting point is 660°C
ChibiM
ChibiM's picture
That's good to know Big Smile
pol77
Last seen: 8 hours 17 min ago
Solder melting point on the other hand is much lower, depending on the solder type. And if the external temperatures were so high, it is very likely the internal temperatures were very close to that point.
mortuus
mortuus's picture
Last seen: 17 hours 13 min ago
wow 130c? i cant imagine what the inside was… not really healthy reaching those temps….
...where Frugal meets with Flashlight!
              つ ◕_◕ ༽つ
zoulas
zoulas's picture
Last seen: 6 hours 25 min ago
What about the melting point of the other components.
chops728
Last seen: 3 hours 40 min ago
Yeah — Like those cells producing their own heat plus the lights heat — Not Good — Boom
Agro
Agro's picture
Last seen: 8 hours 9 min ago
Well, it looks like Imalent quality has not changed over the years.
Renato Azevedo
Last seen: 1 week 3 days ago
That’s really unfortunate, did you contact Imalent? I’m curious to see how they handle this
kennybobby
kennybobby's picture
Last seen: 3 hours 3 min ago
i don’t know that light—does it have any sort of control to step down or shut off?
Now i used to think that i was cool,
drivin' around on fossil fuel,
until i saw what i was doin',
was drivin' down the road to ruin. --JT
Bort
Bort's picture
Last seen: 1 hour 6 min ago
My biggest concern would be the batteries, if you wreck a light that sucks but explosions and HF gas or the potential or long term hidden damage to the batteries is what scares me.
The Journal of Alternative Facts TM
"It is critical that there is a credible academic source for the growing and important discipline of alternative facts. This field of study will just keep winning, and we knew that all the best people would want to be on board. There is a real risk in the world today that people might be getting their information about science from actual scientists"
snakebite
snakebite's picture
Last seen: 1 week 5 days ago
lucky you caught it.
thermal runaway of li ion is not pretty.
pissed off batteries plus tightly closed aluminum tube = pipe bomb!
bad design if its driver allowed this.
hey lets just dd 18 xhp-70 in this to one up the other guys.
who cares if a few explode.
MascaratumB
MascaratumB's picture
Last seen: 2 hours 24 min ago
Mine got really hot but it was after continuous use for some time and then the activation on the 60.000 and 100.000lumens.
Then a “HOT” signal appeared in the OLED screen, the fans were already working and the light eventually shut off (I guess, i can’t remember if it was me that clicked or if it shut off, but I’d bet on the second one).
But yes, it turned really HOT! I wouldn’t expect it to behave differently (on these levels).
On 10.000 lumens, it is weird and not good Oops
xevious
xevious's picture
Last seen: 9 hours 30 min ago
Wow, good thing you caught this before the batteries reached critical. I wonder how many hours were burned off the LED at this point!
ChibiM
ChibiM's picture
The fans turn on with the higher modes, but not the 10,000 lumen setting.
The runtimes for the other high/turbo modes are less than 1 hour each.
CollectEverything
CollectEverything's picture
Last seen: 6 hours 43 min ago
Well that’s a pretty stupid design if the light can reach dangerous temperatures on the levels without fan activation! Facepalm
Collection: TN42, TN40S, Catapult V6, SP36 BLF, sc700d, sc64c LE, D4V2 CuZn, D4V2 CuTi, D4V2 Al x2, KR4 Al x2
Wishlist: Acebeam K75, Zebralight sc600w mk IV plus, Convoy M3-C
raccoon city
raccoon city's picture
Last seen: 5 hours 5 min ago
Wow, if any flashlight needed a thermal stepdown, looks like the Imalent MS18 does.
wle
wle's picture
the leds may be damaged also
    Daniel Behrman, "The Man Who Loved Bicycles".
-Greg Lemond.
Firelight2
Firelight2's picture
Last seen: 3 hours 48 min ago
Possibly.
But on the other hand, LEDs are designed to accept heat during operation and reflows. They’re pretty tough. And the operating life of an LED tends to be orders of magnitude larger than the rest of the flashlight anyways. If an LED loses half its operating life from misuse it will still likely last much longer than the rest of the light.
My biggest concern would be the batteries blowing up. And if that didn’t happen, overheating might cause the rubber switch boot to melt, or the solder on the driver and/or star to melt.
Sirstinky
Last seen: 16 min 19 sec ago
The electronics like inductors, FETs, caps, resistors, .etc and leds would survive that, but the solder joints wouldn’t if using sn/pb solder for reflow…wires coming loose can cause shorts and that’s what kills things. Shame on imalent for omitting a continuous cooling loop for turbo on that near $700 light capable of hundreds of watts of output.
Firelight2
This.
And it should have had a temp sensor that automatically turns on the fan and/or reduces output when the light gets too hot no matter what brightness setting the operator is using.
CollectEverything
Firelight2 wrote:
This.
Before seeing this post, that’s how I assumed an MS18 would work. Guess not…
Firelight2
Does seem a bit strange that a $700 light lacks a core safety feature that has been standard on $50 light for several years now.
… at least I assume this is the case based on the original poast. I don’t actually own an MS18 myself.
MascaratumB
ChibiM, can you please tell:
- how long did you let the flashlight ON in the 10.000 lumens level?
- did this issue happenned after using the light the higher levels (22/30/60 or 100.000lumens) [meaning ,with accumulated heat]?
- or was it from “Off” [meaning, with the flashlight “cold”]?
I am checking how mine behaves from “off”/cold (setting it on the 10.000lumens and letting it be there for a period of time), with the batteries around 13.5V (and decreasing from there), meaning , they are not full!
After 15 minutes on 10.000Lumens, the head temperature is ~41ºC (near the bezel), he tube is not warm (~32.7ºC near the switch, ~30ºC on the tube).
The fan did not activate.
zoulas
zoulas's picture
It’s kind of like complaining to Ferrari that you were driving 200mph and you had a tire blow out. I think its part of the adventure. To play, you have to pay.
LuxWad
LuxWad's picture
Last seen: 6 hours 52 min ago
This is totally different, this very expensive flashlight is lacking a basic safety feature that could potentially lead to serious injury of the user – this is entirely preventable. This is more akin to your Ferrari being equipped with an automatic transmission and simply not shifting into a higher gear or something simple and dumb like that – it just shouldn’t happen at all.
Granted, perhaps this is not normal and is a malfunction, but is still an issue that should not be present
My Review Channel - https://www.youtube.com/luxwad
chops728
The first thing they’ll say is — You’re suppose to hold a flashlight not Tail stand it on 10000 lumen mode —- I’ve played around with small lights like a S2+ with a fet /triple — tail standing at over 5 amps will produce some serious heat —- but will this kind of power there should be some kind of timer / thermal step down
Sirstinky
If you watch YouTube videos of this light in action on turbo or any higher modes, the fan kicks on automatically when it hits a certain temp. The fan itself is entirely inadequate for dissipating 400 ish watts, so it’s mainly there to keep things from self destructing. There’s a malfunction in this MS18 perhaps, and yes, it could be bad.
mortuus
mortuus's picture
its just too much lumens in a light to be any practical, whats the point light gets so hot it turns into a bomb ?
              つ ◕_◕ ༽つ
Agro
Agro's picture
No, timer is a poor solution. If it was a $10 light I wouldn’t complain about timer…if it was a $20 light I would have mixed feelings. But it’s a $700 light. There shall be thermal control.
As said before, it’s been a standard in $50 lights for years. Actually in BLF lights for $30 as well.
There is no excuse to shipping such undeveloped UI in expensive light.
But it’s Imalent. Powerful but badly developed lights for a high price.
will34
will34's picture
Last seen: 1 day 24 min ago
Sometimes we disable temp protection on purpose because when it’s on the flashlight doesn’t even reach 45°C but the immalent takes it to another whole new level Big Smile
