Maybe just buy a new S2+ with SST-40 and 5A driver?
But that’s no fun!
A direct LED replacement yes, but you’ll probably need to play around with centering the LED in the reflector unless you get a compatible spacer, like from here: Kaidomain Misc Parts
I’ve had success with utilizing a larger spacer (eventually by chance the LED gets centered), but it certainly is easier and looks better with the correct spacer.
I’d rather use my flashlight around the house than turn on the lights.
will fit but the centering ring from the XM-L2 will be too big —- you will gain CRI for sure —especially with the 4000k
I believe OP means SST-40, not SST-20 which is smaller and available with high cri.
There I go again —Not comprehending what I read in the OP —— SST40 in my opinion in a S2 makes a terrible beam —but in all fairness I really don’t care for a XM-L2 in them either
If the SST-40 MCPCB is also 16mm, yes.
You are a flashaholic if you are forced to come out of the closet, to make room for more flashlights.
Direct swap but no gain with the stock driver
₪₪₪₪ ΟΥΔΕΝ ΚΡΥΠΤΟΝ ΥΠΟ ΤΟΝ ΗΛΙΟ ₪₪₪₪
My YouTube channel
Flashlights & edc gear
K40M F16
You might want to upgrade the driver as well to get the most out of it.
BG sells the BLF X6 driver, which is an interesting replacement.
Edit, boy these drivers are expensive at BG nowadays, they used to be 8USD or so.
Recent Reviews: Best Flashlights for Light Painting Photography 2022 // Battery and Charger Buying Guide 2022 // Acebeam E70-AL CRI95+ // Antsonamelon RGB Critter 2.0 // Convoy S21E 519A // Wurkkos TS25 // Olight Marauder Mini // Noctigon KR4 // Convoy S21F //
Affiliate links: Olight AU // Olight USA // Nealsgadgets // Acebeam // Antsonamelon
Instagram: @stephenk_lightart
But that’s no fun!
This is a 2-year-old unit that I had in my spares box.
LED is already dead due to some mishandling of the module.
Having been exposed to other lights these couple of of years, I now intend to make this a working light again.
So I’m taking it easy — LED mcpb at the very least.
If you don’t have a Nichia 219B flashlight yet, I would suggest sticking one of these beauties in there: 219B R9080 LED
