AMUTORCH TORCH E3 & E4 will be upgraded soon, what colors or functions are you looking forward to? Your comments and suggestions will be greatly appreciated.
*When there are more than 100 IDs commented, we will draw one person form them to send a flashlight for free.
*When there are more than 150 IDs commented, we will draw two persons form them to send a flashlight for free.
*When there are more than 200 IDs commented, we will draw three persons form them to send a flashlight for free.
1- Remove/replace the standard washer in the tail switch. If used for shim, correct the design in future models.
2- Reversible battery tube with provision for a pocket clip – can then be used head-up or down.
3- Driver cavity to be increased to at least 6mm. This is because of #4.
4- Use proper high-efficiency driver, not series resistor V drop. If the cavity is deeper, we could change the driver.
5- Use AR glass, or at least high transmittance. The lens produces ringed artifacts. Also, design for 1.5 to 2mm thick, not 1mm. Too fragile.
7- What’s with the chalkboard unridged/smooth (unknurled) anodized finish? Not very grippy nor pleasant to hold in hand.
8- Replace all ‘O’ rings from silicone to Butyl N, the standard. And design with proper sizes, not the overly small thickness diameter that tears too easily.
I for one care little for your lights – just screams “cheap” economical design. Do not put me down in your “giveaway”.
BTW, look about your competitors. They have better selection of emitters and are going forward with better UIs. Lacklustre thought in making those 3 lights at low outputs and the latter 2 with the same SST40.
For the E3S, I think the main thing I missed was a shortcut to moonlight from off.
Having the stepped and ramped modes available at the same time is a unique experience, but it might be more useful to put them into separate mode groups (that the user can switch between) so there are more interactions available to use for shortcuts.
I’d love to see standard Carclo optic with AR coated glass lens in E3S/E3. Also, purple E3 with Anduril. Someone around here has even designed the driver for you
I second this. :heart_eyes: It is way to rare as a flashlight color.
Maybe also some sort of gold or sand color. The E4 would be nice in aluminium and copper, too.
The button covers should be white or transparent with some aux leds behind. Aux leds would look great also behind the optics.
Anduril is a nice firmware but if you don’t want it you should improve your firmware with a lower moonlight mode and a bit more evenly spaced modes. Four or five modes are perfect if there is also a fairly low mode and maybe a very low moonlight mode.
